Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #4201
    Apr 2015
    Tennessee
    1998 BMW 328i
    Tag team bitches.
    The outside world from BFC FI are going to confirm this BMW group is a bunch of homosexuals and transgenders. We will run for office.
    Maybe we should have our own government here on BFC/FI.
    We could vote, have parties, campaign the whole 8 yards. Its been getting a bit boring. That could stir the pots.
    Sent from my E6782 using Tapatalk
    Maybe if you smoked the pots instead of stirring them it wouldnt be so boring
  2. #4202
    DeWitt, Michigan
    '97 540i/6, '97 328i
    In all seriousness, MilkT had a huge role in this venting business here on BFC. Back in 2012 or 2010 he started up a good thread about this. It ultimately solved my issue with oil getting into the pipes. Obviously the practice has been around for some time. MikeR probably brought it to BFC attention. But, Craig started up a nice discussion about it.
    Would you happen to remember some key search terms to help home in on one of the best threads on this topic? Searching something like "turbo oil drain vent" turns up a ton of most likely irrelevant stuff...
  3. #4203
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have never needed a vent. Bottom mount, 4 different turbos, 3 different manifolds, gravity drain on some, 2 different scavenge pump systems on others. Always used a restrictor, always ball bearing turbo, boost as high as 24 psi.
    HPF was an early user of vents. They found it necessary only on high boost cars. Their kits all used scavenge pumps and mostly used journal bearing Precision turbos (jb tend to require more oil). Search HPF drain vent.
    I don't see any reason why a vent would hurt, so adding on should do no harm. I don't think a scavenge pump is relying on suction so a vent won't cause it to suck air. I think scavenge pumps work best with the drain line to them sloping gently down from the turbo. I would not ask one to pull the oil uphill, but they can pump uphill for the return.
  4. #4204
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by tptrsn View Post
    "turbo" and "scavenge" in "FORCED INDUCTION" will do the trick.
  5. #4205
    Manchester, N.H.
    96 332IS 6466 turbo
    You also haven't ran a Precision JB turbo. I had no issues with mine till 20#. Being all the manifolds I have run, have been a 20# min. When I was running a Garrett, didn't need one at all.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  6. #4206
    DeWitt, Michigan
    Quote Originally Posted by milKt View Post
    Thanks!
    My Precision turbos were a pain in terms of oil burning too. My China turbos have been perfect other than the one I have on my E36 is beginning to smoke pretty badly at times. I'm probably going to play around with venting the drain like this since I've never tried it.
  7. #4207
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I love being from the state that's about to elect a kiddie diddler to the US senate...
    Sent from my SM-G900V using Tapatalk
  8. #4208
    milKt's Avatar
    Innocent... until murdered in his front yard by an upstanding citizen.
  9. #4209
    Feb 2012
    1995 BMW M3
    Lets fuck here on the carpet baby
    making love tonight
    when the drugs dont kill, they make things better
    getting puff from district lines
    cock dance
    cock dance
    Kiss is rough but it aint enough,
    I feel like pussy cocaine
    kiss is rough but enoughs enough
    I feel like... pussy cocaine
    keep your clothes landing line
    bend on over for a sixty nine
    sexy music on to make you hard
    keep your cash for the boulevard
    Pussy cocaine
  10. #4210
    Aug 2012
    CT
    Twin turbo LS E36 M3
    kids got talent.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  11. #4211
    Apr 2006
    Minnesota eh?
    86 325es
    Your only supposed to use the term murder for humans and famous lions.
  12. #4212
    Aug 2017
    Savannah, GA
    E36 M3 Turbo, 2015 GTI,
    I like the way you think.....
    Ken
    95' Dakar M3
    (GT35) 500whp+ and no clue what I'm doing....
    Steedspeed Twin-scroll Manifold, Wiseco 8.8:1 CR, K1 Rods, Supertech Valvetrain, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) Twin-Scroll 1.06 AR, Schrick Cams, TRM Tuning, 6 Speed Transmission, UUC Twin Disc Clutch, HFS-6 W/M injection, Zeitronix, Coilovers, Chassis Stuffs.
  13. #4213
    milKt's Avatar
    Correction welcomed.
  14. #4214
    Feb 2012
    1995 BMW M3
    DSS driveshaft vibrates like a MFER. It is way beyond anything I have ever experienced. Entire car shakes, windows rattle, console is shaking at 90+ mph. I expected some vibrations, this is way beyond tolerable. I got under the car and can see the DS physically spinning out of round. No way that's normal.
    Talked to the guy I bought it from and he said it was smooth with zero vibrations whatsoever.
  15. #4215
    Jun 2005
    New England
    Your description is a little worse than it should be. Maybe the bolts are not tight. Dss often sends the wrong bolts — too short, sae instead of metric, etc and you have to fix the problem.
  16. #4216
    Mar 2012
    Renton, Wa
    98 m3
    Try switching the adapter orientations.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  17. #4217
    Vancouver, B.C., Canada
    '97 M3
    The dreaded DSS vibration is more of a scary sound than a shake.
  18. #4218
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Yea nah, shouldnt be doing that at all.
  19. #4219
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by vollosso View Post
    Like rotating 180*?
  20. #4220
    Mar 2012
    Renton, Wa
    98 m3
    Yeah or something
    1989 535i - sold
  21. #4221
    Jun 2005
    New England
    Its worth a try. The balance could be off. A few people have gotten the shaft rebalanced and said it helped. Or it could be something simple like your adapters not being seated perfectly or not being tight enough. Even if all is good, a long 5 speed shaft won't be nearly as smooth at high speed as a stock shaft. The shorter 6 speed shafts are better, and the carbon fiber ones probably the best since CF can absorb a little vibration.
  22. #4222
    Feb 2012
    1995 BMW M3
    Updates:
    Cars been running good.
    Giving the sced and nitrous v8 losers the sauce.
    Graduated! XD
    Got a job in a cardiac icu so I'm stoked
    Gonna be making real money so I can have shiny car parts now instead of these hand me downs XD no more building a turbo M3 on a pizza delivery budget
    Gonna pick up all the hoes in my new lambo
    Lots of winning
  23. #4223
    milKt's Avatar
    BTW
    Congrats on your new Senator!!!
    Quite a feat.
  24. #4224
    Feb 2012
    1995 BMW M3
    BTW
    Quite a feat.
    Hell yeah even Alabama says no to the ChoMo.
    Also , im gonna take up modeling. Look how sexy I am.
  25. #4225
    Aug 2012
    CT
    Congrats on graduating. That’s some real shit
Page 169 of 186 FirstFirst ... 69119144159160161162163164165166167168169170171172173174175176177178179 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
