Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #4051
    Manchester, N.H.
    96 332IS 6466 turbo
    I bought my new from a link that Notorious VR posted a bit ago. I think its Ractronix or something. Just didn't want to take a chance with garbage. I want to say it was the same price anyway.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #4052
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by rajicase View Post
    This look legit? Looks good to me.. Anyone else?
    http://www.ebay.com/itm/GENUINE-WALB...VZRV2k&vxp=mtr
    I bought that one and installed it in the 540 a few weeks ago. Looked 100% beyond question legit.
  3. #4053
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by tptrsn View Post
    Sweet thanks!
  4. #4054
    DeWitt, Michigan
  5. #4055
    Feb 2012
    1995 BMW M3
    Wheel hopped and snapped my drivers side half shaft.
    Miserable night.
    Drove the POS 70 miles home with one axle shaft. God that was miserable. Poor diff managed to get me about 2 miles from my house, then lost speed going up a hill and the diff wouldn't lock up enough to get the car going. Drove another car to the house, got a tow strap, and yanked the pile up the hill.
    If anyone has a 95 M3 half shaft please LMK. Need one ASAP.
  6. #4056
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
  7. #4057
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Dam that sucks. Smh if it's not one thing it's the next. This was at the track?
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
  8. #4058
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Are the 96+ axles different? That sucks dude.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
  9. #4059
    milKt's Avatar
    Yes,
    96+ have the "thickness" and will work.
    I recall some thinking the meaty center would make them stronger
    but regular failure point for turbo torque is elsewhere.
  10. #4060
    Virginia
    97' m52 turbo
  11. #4061
    Manchester, N.H.
    96 332IS 6466 turbo
    I may have a stock 95 kicking around
    1996 332IS
    Built 3.2
  12. #4062
    DeWitt, Michigan
    If I remember correctly, my non-M axle I recently broke at the drag strip snapped where the splines enter the outer CV joint. I'm interested to know where the M axles normally break.
  13. #4063
    Manchester, N.H.
    96 332IS 6466 turbo
    The cages break inside the joints. The splines will not break on the M's
    1996 332IS
    Built 3.2
  14. #4064
    DeWitt, Michigan
    Thanks!
  15. #4065
    Virginia
    97' m52 turbo
    I dunno, I'm kind of enjoying my 7-10 psi after seeing all Raj has been through.
    bad luck maybe
  16. #4066
    Jul 2004
    Austin, TX
    AA turbo 332i
    Check O’Reilly, Axles around $100 with lifetime warranty last I checked
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  17. #4067
    milKt's Avatar
    Quote Originally Posted by jjjjjjj View Post
    check o’reilly, axles around $100 with lifetime warranty last i checked
    boom!!!!
  18. #4068
    Virginia
    97' m52 turbo
    cant go wrong with that
  19. #4069
    milKt's Avatar
    advanced auto #78915 - 79.99
    o...o...o... O'Reilly's #BM8051 - 137.99
    both, Limited Lifetime Warranty
  20. #4070
    Feb 2012
    1995 BMW M3
    Not sure I trust Oreillys or advanced axles.
    Has anyone actually used them on a car making 650+whp?
    Warranty is fine, but I don't want to be replacing my axles all the time.
  21. #4071
    Feb 2012
    1995 BMW M3
    If anyone has a pair of 96+ M3 axles Ill take those as well.
    LMK what yall got want something ASAP
  22. #4072
    Apr 2015
    Tennessee
    1998 BMW 328i
    Butters and I went thru this when i broke a half shaft. I work at oreillys and ill tell ya don't buy our axles. The fitment isnt right.
  23. #4073
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by XnWarden View Post
    Lol figured as much.
    Thanks for the heads up.
  24. #4074
    milKt's Avatar
    TRuck ... with an "F"
  25. #4075
    Vancouver, BC Ca
    1993 325is
    You'd better hope you didn't nuke the diff. At the very least you should change the diff fluid. Bet it's burnt to shit!
Page 163 of 186 FirstFirst ... 63113138153154155156157158159160161162163164165166167168169170171172173 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
