Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #3826
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    Quote Originally Posted by tptrsn View Post
    Sounds like a 4L80e is what you want then. Will they fit in the E36 tunnel?
    There was a guy on the forums who did a budget 6.0/4L80E swap and said the 80E fit better than a 60 in the E36 tunnel. Still took some massaging on the fender and he had to change the shift linkage to make it narrower
    Sent from my VS988 using Tapatalk
    '93 325is: ZF swap, Borla Type X muffler, cat delete, X Pipe, Tune, Powerflex bushings (subframe, diff, RTAB, LCAB), Apex ARC8's, Raceland Ultimos, Corbeau seat, Renown steering wheel, M3 front and rear bumpers, BMW motorsports moulding, Euro tails, Depo headlights (soon to be retrofitted)
  2. #3827
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by tyr283 View Post
    A 4l60 has a big servo sticking out the side so yes a 4l80e should fit better. A 4l80 is almost identical in size to a th400 just longer and we know a th400 fits without drama.
  3. #3828
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    If it is computer controlled will it work without a motor that uses a compatible ECU?
  4. #3829
    Aug 2012
    CT
    Twin turbo LS E36 M3
    The most satisfying feeling on this entire planet is pulling a ratchet shifter on an auto.
    The 80e will be much harder to fit then a 400
    you can control the 80e with a micro quiet independent of the engine or tied into the engine ecu if it's a ms3
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  5. #3830
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I think a Microsquirt setup going for around $350 with a harness these days if you wanted to run one as a trans controller independent of the ECU, not bad. MS2 could probably be done even cheaper than Micro I think.
    Alternatively, I think I've read somewhere that there are full manual valvebody kits for 80s...
  6. #3831
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by dburt86 View Post
    why would a 80 be harder to fit than a 400? They are pretty much the same in all the side to side dimensions, just longer.
  7. #3832
    Aug 2012
    CT
    I can't rememebr but I know the one guy that did it murdered his tunnel
  8. #3833
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Grinded the shit out of my caliper and got the 15 " wheel to fit on the drivers side. Now just gotta do the pass side.
  9. #3834
    Vancouver, B.C., Canada
    '97 M3
    Post before and after picks.
  10. #3835
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by rajicase View Post
    The wheels fit ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  11. #3836
    Feb 2012
    1995 BMW M3
    Yes they fit. I'll get pics on the passenger side.
  12. #3837
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Pics of the sparks rocketing into your mouth.
  13. #3838
    Feb 2012
    1995 BMW M3
    Would you like pics of anything else rocketing into my mouth?
  14. #3839
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    Only if you're still servicing truckers at truck stops
  15. #3840
    Manchester, N.H.
    96 332IS 6466 turbo
    John Holmes wrapped with a 10 sec slip.
    1996 332IS
    Built 3.2
  16. #3841
    Feb 2012
    1995 BMW M3
    Holy shit yall . I think I might have found the issue :0
    The flange that connects my drives haft to trans is totally mangled. Half inch steel flange is twisted like a freaking pretzel.
  17. #3842
    DeWitt, Michigan
    It's hard to tell for sure from the pics, are all three ears twisted the same, as if it was just from pure torque action?
  18. #3843
    Apr 2006
    Minnesota eh?
    86 325es
    I sheared all the bolts off drag racing with my M20 and the flange looked like that.
  19. #3844
    Feb 2012
    1995 BMW M3
    All three ears are twisted. Yes.
    Oh well ..
  20. #3845
    Apr 2006
    Minnesota eh?
    86 325es
    could be worse, when I sheared the bolts it broke the alignment pit off the output shaft and the flailing driveshaft ripped a 4" gash in the trans tunnel.
  21. #3846
    Feb 2012
    1995 BMW M3
    Damn! Yeah I'm lucky then. Especially considering how long I was driving it like this. A few hundred miles at least.
    Well next time it's on the road it'll be with a DSS ds, 210mm diff, and 15" hoosiers!
  22. #3847
    '97 M3
    My driveshaft did that but with more twist and with cracks. I feel fortunate that it held together long enough for me to find the damage. Wheel hop sucks.
  23. #3848
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    Yeah well I'm hoping that once I get some 15" Hoosiers on the rear I won't be hopping. My entire rear end is solid mounted, everything is new.
    I was really pussyfooting off the line too. I never launched it at the track. I'm sure if I had this would have been much worse lol.
  24. #3849
    milKt's Avatar
    pics
  25. #3850
    Aug 2012
    CT
    My car never hopped with the hoosiers.
Page 154 of 186 FirstFirst ... 54104129144145146147148149150151152153154155156157158159160161162163164179 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
