I don't think we have room for a 3.5 inch tube. My 3 inch DSS shaft is as close as I think it could be to the plastic gas tank.
Oh boy I just poked a 900whp cts v on Facebook and now we gonna run in 20 minutes :0
Boost gods don't let me down. I hope he is out of nitrous lol
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
Wish me luck :0
Kick his ass seabass!
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
I foresee raj texting me in about an hour asking how much more injector he has hah.
1989 535i - sold
1999 M3 Tiag/Dove - sold
^exactly^
900hp ctsv, he better have texted you already.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
1989 535i - sold
I bumped the base pressure up to 60 and turned it up one more psi.. sennnndddding it.
1 psi? You must mean 10. Don't go easy on him
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
I cant. Don't have enough fuel..
Ugh he won. He got me by 1.5-2 cars at 150. But I guess considering he's making 900whp I can't whine too much..
That's impressive! See how much boost are you on now? I've lost track.
Ctsv is also 20% heavier so it needs 20% more power.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
So me and zack are discussing getting me more fuel.
My plan is to add an in line 044 pump and that should be enough pump for 8-900whp.
Then we plan on bumping my base pressure up to 73 which should give me 1150ccs of fuel which I hope to take to 750+ whp XD
bosch 2200's are 56$ each. Just sayin.
1989 535i - sold
Doesn't he need pumps in parallel versus in series to keep up with the demands of ethanol? Can't see 8-900whp being made on stock lines w/o the pressure cranked up, and even then you'll hit the pump reliefs before you make it (saw one white wagon do it with a BAP, tried to copy that setup and ran out of fuel)
With e85, me thinks it's more of a volume thing ie. pumps running in parallel, larger feed/return lines to support your goals. At least in my experience that's how it worked for me. Twin 485s will support more power than any of us are making, with the right components around em!
