Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #3201
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Couple pics from right before engine went in.
    This turbo requires a hell of a lot of grinding to fit. Must have removed 3/4" of material between the block and the cover and there is just enough clearance for a folded up piece of printer paper to get stuck between the cover and the block XD
  2. #3202
    Vancouver, B.C., Canada
    '97 M3
    I'd want more clearance than that to allow for expansion due to heat.
  3. #3203
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    Meh it worked on my last motor.
    I don't feel comfortable grinding any more material off either the block or the cover. The side of the block is now concave from all the material I removed and the compressor cover is extremely thin where I shaved it down. I would like more clearance too, but I'm gonna have to live with this.
  4. #3204
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by rajicase View Post
    Its probably not safe. You should just cut your losses and gift me the car
  5. #3205
    Feb 2012
    1995 BMW M3
    Lol.
    So today I got the oil lines connected, intake manifold on, drive shaft attached. Re-wired my scavenge pump to be a little cleaner. Hooked up my fuel systen.
    Everything is done now, it is ready to start. Just waiting on my obd1 coils to get here, hopefully in a couple days. I'm nervous as hell, if this motor doesn't work I'm probably done for quite a while, maybe for good on this platform. Fingers crossed.
  6. #3206
    Manchester, N.H.
    96 332IS 6466 turbo
    There are always bugs to work out. Don't get discouraged.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  7. #3207
    Feb 2012
    1995 BMW M3
    Bugs I can work out.
    I mean if I fucked up the motor build and the motor is shit, then I'm probably gonna have to take a good long break from this car.
    Ive never built a engine before, let alone one that I am asking to handle 600+ whp.. And I am not super confident in my end product, even though I did my research.
  8. #3208
    Manchester, N.H.
    96 332IS 6466 turbo
    It will be fine. If not take the WG line off and make a final pull.
    1996 332IS
    Built 3.2
  9. #3209
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    if you grenade your new motor, i have a $350 m52b28 waiting for you in Indiana.
    but i'm sure you'll be fine.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  10. #3210
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    If you did your research like I did you'll be fine. I know the feeling though. That first start and drive is a little nerve wracking. When you start racking up miles the feeling of accomplishment will make all the stress and destroyed bank account worth it.
    Can't wait to read your post after the first drive.
  11. #3211
    Feb 2012
    1995 BMW M3
    So I decided to fill her up with oil and turn the engine over with the starter till the oil pressure light went out. It isn't going out. I've cranked it 3 times fr 5-7 seconds each time and the light isn't going out.
    Spark plugs are out and she has 7 qts of oil in her...
    Hmmm
  12. #3212
    '97 M3
    Oil pump nut fell off already?
  13. #3213
    Nov 2014
    Bellingham, Wa
    It took my engine a bit more time then that to prime.
  14. #3214
    Feb 2012
    1995 BMW M3
    Nvm I was just being a bitch.
    10 seconds and the light went off.
    Phew. First disaster averted... fml I'm a nervous wreck
  15. #3215
    Feb 2012
    1995 BMW M3
    I don't think I was even this nervous the first time I got laid XD
  16. #3216
    Nov 2014
    Bellingham, Wa
    Its only because you didn't pay the girl 4K. Hopefully your engine lasts longer then you did .
  17. #3217
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    I'm a nervous wreck
    ha ha
    You're gonna need a new battery before this is over.
  18. #3218
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by jakeE36325 View Post
    It better last longer lol.
  19. #3219
    Feb 2012
    1995 BMW M3
    This sucks ass.
    Got my car completely done but cant start it cause I'm waiting on some damn coils
    I think my blood pressure has increased by 50mmhg in the past week waiting to start this mfer..
  20. #3220
    Nov 2013
    VA
    E36
    This sucks ass.
    Good time to back track and check everything over one last time. Haven't built a bottom end either so my fingers are crossed for you lol.
  21. #3221
    Apr 2006
    Minnesota eh?
    86 325es
    This sucks ass.
    How long is it going to take to get them? I have a good set I can borrow you.
  22. #3222
    Feb 2012
    1995 BMW M3
    They have been shipped it just sucks waiting for something so insignificant when my car is ready to go!
  23. #3223
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    I have learned that it is the last few things to get a car running that take the longest to arrive.
  24. #3224
    Feb 2012
    1995 BMW M3
    Coils get here tomorrow.
    Not gonna get any sleep tonight.
    On a side note. I really need to upgrade my intercooler. I'm still running an eBay special... maybe if all works out tomorrow an IC will be on my short list of things to upgrade..
  25. #3225
    Nov 2013
    VA
    E36
    CX racing? Is it worth going to a treadstone if not in a track env't? Just curious.
Page 129 of 186 FirstFirst ... 2979104119120121122123124125126127128129130131132133134135136137138139154179 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
