Real cute. I'm hoping the engine will be back in the car next week.
What should I do with the full tank of 15 gallons of E85 that's been sitting in my gas tank for 2.5 months? Just run it?
1989 535i - sold
1999 M3 Tiag/Dove - sold
E85 that's been sitting for a few months in the tank should be okay?
1989 535i - sold
Yeah I mean the evap line is open to atmosphere.
Left off here for the day. So close to going back in the car,
Whoa I've missed a lot. Sorry for the bad luck but looking good!! should be making that 700+ soon without any bendies.
1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
What's that block in the background? Bad one?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Yes that's the block that suffered from the bent rod. It is trash.
Valve cover coated and added two 10an breathers.
Converting back to obd1 vc.
Engine scheduled to go in this weekend.
Looks good.
Is that spray painted?
Yeah I sprayed it, too big to fit in my powder coat oven
Okay plan for tomorrow is to get the motor and trans in and put as much shit back together as possible.
I'm nervous as hell about this motor, not really very confidence inspiring asking my first built motor ever to handle 6-800whp...
Mmhm built motor life
1989 535i - sold
1989 535i - sold
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Yes I plastigauged all the bearings.
Motor and trans in!
PS pump and rack all attached.
Wiring harness in and attached!
Funny.
i removed an engine and trans from an e36 today while you were installing one.
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
So called it quits for today. Got a ton ton.
The only thing left to do before first start is installing intake manifold and connecting oil lines to scavenge pump.
First start should happen by the end of the week.
Super nervous about the motor but we'll see...
