That's okay.
I have personally loctited three oil pumps on three different engines, all of which were beyond a pain in the ass to remove 10s of thousands of miles down the road.
I have also had two local buddies loctite their oil pumps and one of them was torn down a few months back after 50k miles of track/drifting/street, and it too was a bitch to remove.
Like I said, if you ever tried loosening an OPN that had red loctite applied to the threads, you would know that nut would never come off on its own.
#red/loctite/is/no/joke
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I kmow what red loctite does, i have it everywhere, oil pump nut, valve cover studs, flywheel bolts, crankshaft bolt, harmonic balancer bolts.
Ive done it, id rather the safety wire and spot weld to keep in check.
Then again 7700 rpm is a little more.
1996 332IS
Built 3.2
I like lockwire but then again I'm always doing it.
I spun my last s52 to 7500 and my buddy did as well for 50k miles; nut was damn tight.
Id never weld the sprocket on for several reasons; 1) for removal later on, wtf 2) I have seen several people with welded OPNs have their shaft shear off. No definitive proof that it was the weld that weakened the shaft, but the correlation is strong enough to make me suspicious. SO great, your OPN didn't back off, but the shaft sheared off.
If it helps you sleep at night knowing you welded/loctited/wired/staked the nut on, great. But I have NEVER seem a loctited OPN come loose so I am going to go with what I know works and what has worked for me on three separate engines.
Wire is great if done right; key word there though <<<---
But I don't think it has any advantage to Loctite, simply cause I have never seen either one fail. Seeing them as equals, I prefer the easier method.
Is it that much harder to wire and run the other pre-requisites while your in there though? Just a thought. I'm all about future proofing, regardless
Sent from my SAMSUNG-SM-G935A using Tapatalk
Wire is a bit more work; I would never ever stake the threads or weld the nut. Either Loctite it, Loctite and wire it, or wire it; at some point you are beating a dead horse and doing work for the sake of doing work. And that doesn't make your engine more reliable. A loctited OPN is more than adequate. If wire makes you happy, do that as well. Your call.
It's seems we are doing work for the sake of doing work to begin with. When I build my motor I will do the exact things that people making 700+ tell me to do
Better safe than sorry
No, I am doing work for the sake of building a reliable motor.
If you want to do work for the sake of doing work, go for it. If it helps you sleep at night, then its worth it to you. Doing useless shit just because some people on the internet said so doesn't help me sleep. What helps me sleep is knowing that my method for securing my OPN has never failed to my knowledge.
Jesus Christ,
Failures happen to those that have nothing or shit luck. Even that's not even the case, I have stock 350k E36's coning to my shop with original bottom ends.
/ oil pump nut discussion.
1996 332IS
Built 3.2
I tack mine with the tig. 0.01% heat added.. takes 12 seconds..
Whatever works and is easiest.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Well a stock E36 325i doesn't twist up the front of the crank like an 89.6mm stroke with 900 hp at 7200 rpms does. Its the torsional vibration of the crank that backs the nut off and breaks oil pump shafts so its dependent on RPM, stroke, and power. Anyway carry on.
Oil pan and drivers motor mount arm painted black and finished with a 2k clear.
Probably should have asked this before I installed everything but the middle oil expander/spacer ring ; it doesn't matter which side faces up or down right? It didn't mention it on the JE ring sheet so I just put them on the piston and clocked them according to the sheet.
The expander ring swings both ways.
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
1989 535i - sold
Lmao!
