Like he said, $20 is $20.
Pistons in!
Rod bearing clearances according to plastigauge were between. 0.001-0.015"
a hand job is still a job.
Looks good man!!!!!
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Oh those decimal points, they can really get you sometimes.
Meh, just round to the nearest tenth
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
-oil pump installed
-oil deflector tray installed
-oil filter housing installed
Tonight I hope to get the rest of the bottom end along with the timing cover completely buttoned up and hopefully pick up my head from the machine shop today as well. The light is getting brighter...
Post a picture of your oil pump nut.
I don't use safety wire. I clean the threads and use a drop of red loctite. People way over think the oil pump nut.
If you have ever removed the nut after it had been red locitited, even after 50k+ hard miles, you would know that it would NEVER come off in a million years on its own. In fact, I think blue loctite would be more appropriate.
I use red loctite, safety wire and spike the threads on the shaft with a chisel. I may have tac welded on top of that.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
