Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #3051
    Mar 2012
    Renton, Wa
    98 m3
    Eeehhh if done right id rock sleeves.
    The block will be "rebuildable" lol.
    But you do hear a bit too often dropping sleeves.. usually ""due to heat"" or "overheat"... also cracking sleeves...
    I don't know. Its quite the Sophie's choice you have here.
    Side note, anyone going to bimmerfest west?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #3052
    Virginia
    97' m52 turbo
    They ruined the block,
    They buy me another block.
    If I were you I would be looking around on craigslist locally for motor or block for around the price you paid to have them do the work (or cheapest you can find) or for the price you purchased yours. I'd print the ad and hand it to them. You shouldn't be worrying about whether or not your motor is going to "hold up" due it having a sleeve in it and it not being properly machined by someone else.
    Not cool in my opinion. I've been told by X amount of people I'm asshole though, so I don't know... That's what I would do. Would then take the new block to another shop.
  3. #3053
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by 328iFun View Post
    I have learned that there are certain times to be confrontational and certain times not to. In this instance, a locally owned business at any point can tell me to fuck right off and Ill have no course of action to take. In this instance, the owner acknowledged the problem they caused and promised to fix it and it would be good as new. This shop has been around for decades and has done great work for me and everyone I know, so I am willing to give them the benefit of the doubt. I told the owner what type of power and stress this block would see and I ensured he knew how important it was that it would be reliable, he promised it would be. So the ball is in their court, I am going to let them sleeve it, pick it up, inspect it and continue my research. Worst case I pick up another block and bring it to another shop; whats another month or two and a few hundred dollars more at this point, right?
    Everything I have read leads me to believe that a sleeved block is every bit as reliable assuming proper install. Other commonalities between failed sleeves seem to be related to overheating and installing sleeves in cracked/damaged bores. I'm going to hope that a massive machine shop that has been around longer than I have been alive knows how to properly sleeve a iron block and hope that this screw up was just an isolated and carless mistake....
  4. #3054
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    Yes, I would get another block and take it another shop. That way you don't have to worry about. Especially considering how much time and money has been put into it.
    I think a few hundred bucks extra soul be worth the piece of mind.
    Until you can source a new block we cab always post more dog pics, I have tons
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  5. #3055
    Feb 2012
    1995 BMW M3
    I am going to play it by ear. I am at the least going to pick up my sleeved block and get you guys some pics. And maybe some more people here will chime in once they see the finished product.
    https://ls1tech.com/forums/generatio...ron-block.html
    This was an interesting thread to read.
    Cool pics of a freshly sleeved iron block.
  6. #3056
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    If they have a good track record and the shop knows what the block will be put through and is confident it will last I see no reason not to just let them sleeve it. I don't know, maybe I'm missing something
    VAC sleeves tons of blocks and I remember a while back reading that they said a single sleeve in a cast iron M5X block had no drawbacks provided it was done right (there was a guy who called them about having it done after he damaged one cylinder)
    Sent from my SM-G920V using Tapatalk
    '93 325is: ZF swap, Borla Type X muffler, cat delete, X Pipe, Tune, Powerflex bushings (subframe, diff, RTAB, LCAB), Apex ARC8's, Raceland Ultimos, Corbeau seat, Renown steering wheel, M3 front and rear bumpers, BMW motorsports moulding, Euro tails, Depo headlights (soon to be retrofitted)
  7. #3057
    Virginia
    97' m52 turbo
    Quote Originally Posted by tyr283 View Post
    I'm sure a sleeve will work for Raj fine.
    If I were him it would itch my bump to have all 5 cylinders perfectly fine and then a sleeve in the 6th because someone else goofed.
    But building a good rapport with a local shop is good thing... He may need them again later
  8. #3058
    Vancouver, B.C., Canada
    '97 M3
    After all the crap I've been through, I wouldn't take any chances, I'd get another block and have them machine it. Don't let Murphy into your engine.
  9. #3059
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by chikinhed View Post
    Grab a m52 for $300. Even shipping is no big deal. I shipped one from NH to Mike R and cost on shipping was only $79 iirc. That was a stripped block. But I'm sure the sleeve will be fine.
    Will they be doing a flanged or tapered sleeve ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  10. #3060
    Feb 2012
    1995 BMW M3
    I'll decide what course I'm going to go once I get the block back. I'm really inclined to trust the machine shop on this one but I'll keep thinking about it.
    I'm not sure what type of sleeve they are going to use. I assume tapered but I'm not sure.
  11. #3061
    Manchester, N.H.
    96 332IS 6466 turbo
    Well, I only worry as this is F-up #1. If a sleeve drops, shame on you.
    Personally, I'd probably just have them sleeve it, if I was in your sneakers.
    1996 332IS
    Built 3.2
  12. #3062
    Feb 2012
    1995 BMW M3
    I'm getting very mixed signals from you regarding sleeving lol.
    Shame on me what ?
  13. #3063
    Manchester, N.H.
    96 332IS 6466 turbo
    Shame on me what ?
    I'm torn with it.
    They already screwed up a job for you once. You asked them to punch out the block and they didn't do it right. So, you can call it an honest mistake. Maybe things got hectic or whatever and they made a very rare mistake. Or, this is common practice for them, and they aren't really all that good.
    If its #1 then your fine, but if its #2, and you go ahead and have it done, reassemble the whole car. Drive it a few hundred miles, then a sleeve drops. Well, that will suck for you much more then for them. That would be a whole lotta work for you, and you will ponder parting it out.
    So, the old saying.
    Fool me once, shame on you.
    Fool me twice shame on me.
    If that sleeve drops, they have fooled you twice.
    The shit part ?
    When modding a car, making that type of power, it will be easy for them to blame something on you. You will have no recourse what so ever. 100% screwed you will be.
    1996 332IS
    Built 3.2
  14. #3064
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Supposedly if sleeving is done right, a lip or step is left at the bottom so the sleeve cannot drop. There was a fancy built motor that pushed down a sleeve due to the pressure from the ring of a cutring gasket, and perhaps this motor was not sleeved right or perhaps when it was sleeved no one contemplated a cutring gasket since they did not exist for S52 at the time the motor was built.
  15. #3065
    Feb 2012
    1995 BMW M3
    Hmm so the idea of the cut ring pushing the sleeve down concerns me. I guess what I can do is torque the head down with the oil pan off and visually see whether or not the sleeve moved. I'm sure I can make some mark or measurement before and after I torque the head down to be sure the sleeve has not moved.
  16. #3066
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Heat cycles likely make it move after install. Can the shop tell you what type of sleeve they plan to use?
  17. #3067
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by philly98540 View Post
    I'm sure they can , but they are closed over the weekend.
  18. #3068
    Mar 2013
    Upstate NY
    M3
    Cheapest block I find in most yards are 150$ I'd say take your chances with the sleeve.
  19. #3069
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by Mklock View Post
    I probably will.
    As long as they put a step in the bottom of the bore to retain the sleeve I don't see how it could drop.
    Hopefully they get done with it early next week and I can get back to work.
  20. #3070
    NY
    skateboard
    Long, or short sleeves that is the question
    ― George Orwell
  21. #3071
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by GG///M3 View Post
    SLeeveLESS
    Full muskel shoit
  22. #3072
    NY
    skateboard
    Quote Originally Posted by milKt View Post
    SLeeveLESS
    Full muskel shoit
    Korrekt in which it will work best indeed
    ― George Orwell
  23. #3073
    Vancouver, BC Ca
    1993 325is
    I once had a VERY reputable engine shop here in Vancouver bore a 4cyl block for forged pistons for me. I asked them to hit a specific piston to wall clearance. I gave them the pistons. When I went to pick it up, the pistons were NOT marked for which bore they were to be matched up with. I questioned the counter guy Dave (Brad, you'll know who I'm talking about) about why the pistons were not marked. His response was "it doesn't matter". I asked why it didn't matter, if the piston to wall clearance that I asked them to target/hit was achieved. His response was that they bored all the holes to the same diameter.
    As they did not perform the work as I had asked them, I asked to be compensated. They "bought" the block from me for the cost of a replacement block and refunded all the charges for the work they performed incorrectly. I have never returned to them for any further work. They did stand behind their fuck-up, and I think this shop that you are dealing with should do the same.
  24. #3074
    Feb 2012
    1995 BMW M3
    Well I've already told them to go ahead and sleeve the cylinder so I can't really ask for a refund any more.
    I'm gonna pick up the block and see how it looks and post some pics here for you guys to examine and go from there. Worst case I'll cut my losses and get another block and take it to another shop. Surely I can sell this one and recoup some costs down the road.
    I really want to give the machine shop the benefit of the doubt because I have used them for years, recommended them to friends, and have never had anything but excellent experiences and same with everyone I know. And like I said, this place has been around for decades and every BMW shop around sends their heads and shit to them so I'd really hope that this was an isolated incident and that the sleeve they install will (as they promised) be good as new and have zero effect on longevity and reliability.
  25. #3075
    Apr 2006
    Minnesota eh?
    86 325es
    Ask them if they are machining a step to retain the sleeve. If not tell them to cancel the order for the sleeve and source an m52 block.
Page 123 of 186 FirstFirst ... 237398113114115116117118119120121122123124125126127128129130131132133148173 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
