Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #3026
    A house
    '86 325e, '14 VW EPA
    I used an ARP one over the winter, worked like butter. Well, it was my first time so I wasn't sure how easily it should slide in, my one piston felt like it caught a little bit compared to the others, so I pulled it out and re-did it, and got it on video:
  2. #3027
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by rajicase View Post
    So it's a good idea to lube up the rings and pistons and cylinder wall with some 5w30?
    Ya. Thats kind of an engine building 101 thing. Make sure and do plenty of research.
  3. #3028
    Apr 2006
    Minnesota eh?
    86 325es
    don't overdo the lube. just a light smear on the rings is enough. You don't want the ring grooves to be full of oil.
  4. #3029
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by jakermac View Post
    I'm doing my research in phases. Too much info all at once does me no good.
    I am still on the installing bearings/crankshaft and checking clearances so that's where my attention is at the moment.
    Once I get that done I'll do more research on gapping rings and installing pistons.
    I've never done this before so it's learn as I go.
  5. #3030
    Feb 2012
    1995 BMW M3
    Okay so JE says min. ring gap for top and bottom oil rings is 0.015" .. my oil rings gap is exactly 0.015". Should I open it up a bit or leave it?
  6. #3031
    Manchester, N.H.
    96 332IS 6466 turbo
    Leave it I guess. Mine were a little tighter, and I went to like 0.016-17 those are a little tougher to file. They are different. The previous engine had oil gaps at .023 and took a qt per thousand iirc the PO stated. I have zero consumption now .
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  7. #3032
    Apr 2006
    Minnesota eh?
    86 325es
    leave it. The oil rings don't get much heat so don't need as much gap.
  8. #3033
    Feb 2012
    1995 BMW M3
    Good to hear. Ima go ahead and gap my rings tomorrow hopefully since my bearings don't get here till friday.
  9. #3034
    Feb 2012
    1995 BMW M3
    Little problem.
    Went to gap the rings and out of the box the top ring is gapped to 0.024" and the 2nd ring has a gap of 0.031"
    Little confused here. I ordered the correct ring set for these pistons so not really sure what's up.
  10. #3035
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Check the part numbers on what you received against what you ordered.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  11. #3036
    Manchester, N.H.
    96 332IS 6466 turbo
    Little problem.
    Post a pic of where in the bore your checking the gaps
    1996 332IS
    Built 3.2
  12. #3037
    Feb 2012
    1995 BMW M3
    I am using an old piston with the 2nd ring on it as a stop to push the rings down. Ring is at least 1" in the cylinder.
  13. #3038
    Feb 2012
    1995 BMW M3
    Wow unfuckingbelievable.
    The 6th cylinder is just bored out significantly more than the other 5. Jesus fucking christ. My block is ruined and $300 down the drain.
  14. #3039
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    Who did the machine work?
    Sent from my SM-G920V using Tapatalk
    '93 325is: ZF swap, Borla Type X muffler, cat delete, X Pipe, Tune, Powerflex bushings (subframe, diff, RTAB, LCAB), Apex ARC8's, Raceland Ultimos, Corbeau seat, Renown steering wheel, M3 front and rear bumpers, BMW motorsports moulding, Euro tails, Depo headlights (soon to be retrofitted)
  15. #3040
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by tyr283 View Post
    GG///M3, .....it was free shipping.
    Did you give the pistons to the machine shop that punched it out ? They should be boring and honing to fit pistons. Not "XXmm"
    1996 332IS
    Built 3.2
  16. #3041
    Feb 2012
    1995 BMW M3
    Yes of course I brought them the pistons.
    The 6th cylinder is just significantly larger than the other 5.
  17. #3042
    Feb 2012
    1995 BMW M3
    PM me
  18. #3043
    Feb 2012
    1995 BMW M3
    So I brought the block to the machine shop and the owner immediately acknowledged that they messed up and the bore was too big.
    He said they will put a thin walled chromoly sleeve in it and should be good as new. My research indicates this is true as long as it's installed correctly.
    I'm optimistic they are doing the right thing, I have been bringing all my heads to these guys for years and the always do excellent work and are very quick. So hopefully this works out well.
  19. #3044
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Excellent update.
    sleeving a block is old tech. Should be just fine.
  20. #3045
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Concerning that they gave you the block knowing it was overpunched. Sh!t happens, but be up front about it. I'd get details on the sleeving and check tolerances before they press it in. Maybe have some more knowledgeable guys on here double check what they plan to do.
  21. #3046
    Apr 2015
    Tennessee
    1998 BMW 328i
    Was this the shop you recommended to me? They did great work on my cylinder head.
  22. #3047
    Toronto, Canada
    E36 Turbo
    I personally would get them to buy you a new/other block and properly size the holes this time.
    Sleeves can add another point of failure (they can sink).
  23. #3048
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by NOTORIOUS VR View Post
    That would be ideal but this is what they are willing to do so I'm gonna have to live with it.
    Theoretically sleeves should be perfectly fine as long as they are installed properly.
    Fingers crossed. ..
  24. #3049
    Manchester, N.H.
    96 332IS 6466 turbo
    A member here had a VERY expensive engine put together by "XxxxxxxxXxxxxxxxx", fully built to the hill. Top of the line everything. Arrow rods, CP pistons......the works.
    He installed it and all was good for 500-1000 miles of no boost. To break it in. Then once going into boost, he noticed his coolant was blowing out the cap. System was pressurizing.
    This was with a cut ring gasket, I couldn't believe the gasket failed, no way. So we installed a pressure gauge in the line from the bottom of the bottle to the engine. The one that runs along the drivers side. Well, he was hitting around 30psi pressure in the cooling system. So, off came the head and what we found was disturbing. The 5 digit engine that he purchased was sleeved on 1 cylinder, and the sleeve dropped. The kicker is, he bought the engine 8 years ago, and it sat all wrapped up in a crate till it was installed.
    Shit part is, he bought the engine under the impression it was a good block punched out. They never told him it was sleeved. He didn't provide a block. He bought it all. Then when this was caught years later with only a few hundred miles, that " xxxx " is no longer in business. Many will know who "xxxx" is.
    My "solution" would have been a baseball bat to his head, then suck him off while he is knocked out.
    That would teach him not to rape.
    1996 332IS
    Built 3.2
  25. #3050
    Feb 2012
    1995 BMW M3
    I mean sleeves have been run in engines for a long time from production cars to big power race cars. I don't like the fact that my block is going to have a sleeve but if it's installed correctly it shouldn't be a problem?
Page 122 of 186 FirstFirst ... 227297112113114115116117118119120121122123124125126127128129130131132147172 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
