Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #2951
    Vancouver, B.C., Canada
    '97 M3
    Back to truckers......
    [youtube]egcXvqiho4w[/youtube]
  2. #2952
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    <a href="http://www.youtube.com/watch?v=egcXvqiho4w">YouTube Link</a>
    I'm too drunk for that shit lol wtf did I just watch.......
    But good guy, getting this thread back on track.
  3. #2953
    Virginia
    97' m52 turbo
    Did I really just watch that twice
  4. #2954
    Mar 2012
    Renton, Wa
    98 m3
    What the sh..?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  5. #2955
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by rajicase View Post
    I have several things for sale if anyone wants or could share with someone interested it'd speed up my build exponentially!
    TRM tune with two revisions and 60# injectors for OBD1 s52 : $sold
    ARP rod bolts $70
    X brace for e36 $100
    Super tech dual valve springs with steel retainers 84#: $450
    S52 crank: $250
    M52 crank: $50
    OBD2 valve cover: $40
    OBD2 ignition coils : $75
    Like new OE OBD2 knock sensors : sold
    S52 cam trays with lifters: $100
    Buy some stuff pleeeaasssshhh.
    I also have random stuff like cam gears, chains, sprockets, etc... make offers!
  6. #2956
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    Do you have the intake cam gear spring washer?
  7. #2957
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by jakeE36325 View Post
    I do! Make offer shipped via pm!
  8. #2958
    Feb 2012
    1995 BMW M3
  9. #2959
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    less internet, more reassembling your car.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  10. #2960
    Mar 2013
    Upstate NY
    M3
    Hope you got the timing cover decked too.
  11. #2961
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by Mklock View Post
    I'm not a doofus lol...
    Quote Originally Posted by doktor b View Post
    UGHHH I have to do work now?
  12. #2962
    Virginia
    97' m52 turbo
    looks great
  13. #2963
    Feb 2012
    1995 BMW M3
    I still need to buy rings, bearings, and a ton of misc. Gaskets, nuts, bolts, etc.. I think $300 more will get me everything else I need to get this bitch back together. Slow going but I can see the light!
  14. #2964
    Manchester, N.H.
    96 332IS 6466 turbo
    Do a go fund me. I'm in for $5-10 bucks.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  15. #2965
    Feb 2012
    1995 BMW M3
    Inb4 I go viral and raise $100k and have the baddest e36 around XD
  16. #2966
    '97 M3
    $300 until you check your piston squirters. You will also want the springless rear main seal ($100) as the cheap Felpro spring type leak.
  17. #2967
    Feb 2012
    1995 BMW M3
    Oil squirters and rear main were all replaced brand new on my old short block with genuine BMW parts. I was just gonna swap them over to the new block.
  18. #2968
    Mar 2013
    Upstate NY
    M3
    Don't forget the welds you blew on your intake manifold.
  19. #2969
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Id throw some money into a go fund me
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  20. #2970
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    I will not. I can't even afford welding consumables at this point. Completely and totally broke.
  21. #2971
    Feb 2012
    1995 BMW M3
    As much as I'd love to do a gofundme I enjoy knowing that I put together this beast with my hard earned money. I'm living off tuna sammiches, driving around my daily with no a/c in AL summer because a new compressor could be turbo parts for the m3, and my pull out game is strong because condoms / birth control also could be turbo parts. But it will all be worth it in the end!
  22. #2972
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    I just lol'd at the pullout game joke
    Sent from my SM-G920V using Tapatalk
    '93 325is: ZF swap, Borla Type X muffler, cat delete, X Pipe, Tune, Powerflex bushings (subframe, diff, RTAB, LCAB), Apex ARC8's, Raceland Ultimos, Corbeau seat, Renown steering wheel, M3 front and rear bumpers, BMW motorsports moulding, Euro tails, Depo headlights (soon to be retrofitted)
  23. #2973
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    *double post, cant delete from app*
  24. #2974
    Mar 2013
    So~Cal
    Go fund me's are for YouTubers. Also am i too late for the dog post?
    Here my little shit
    PS: your cams are STILL sitting in that same box, wrapped in those same towels... if your really hurting i can send the towels back? lol
  25. #2975
    '97 M3
    No response means the engine is going back together?
Page 119 of 186 FirstFirst ... 196994109110111112113114115116117118119120121122123124125126127128129144169 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
