Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #2851
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    What's going to be the next failure?! Your making quick work of building that engine. Nice work!
  2. #2852
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by Mklock View Post
    8000whp???
    Fixt
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  3. #2853
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Haha well all I have are parts so far.
    Gotten lucky with some deals so far.
    Going to pick up a 210mm diff for $300 sunday.
    Ima max my injectors out ! We will see where I land
  4. #2854
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by rajicase View Post
    On a rollback is my guess.
    race
    break
    fix
    repeat
  5. #2855
    Mar 2013
    Upstate NY
    M3
    Raji did my source for that differential come through??
  6. #2856
    Feb 2012
    1995 BMW M3
    Supposedly getting it sunday. We will see. I always assume CL folks gonna flake unless proven otherwise lol..
  7. #2857
    Mar 2013
    Upstate NY
    M3
    Let it be known fellow bfc member helped another to find a 210mm diff for under 1300$ hehe.
  8. #2858
    Joliet, IL
    Out of Service
    Help me next. I need a core to rebuild with 40% lockup
    Sent from my SM-G935V using Tapatalk
  9. #2859
    Feb 2012
    1995 BMW M3
    Def will give you a major shout out when I go get it!!
  10. #2860
    Aug 2012
    CT
    Twin turbo LS E36 M3
    amen
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  11. #2861
    Feb 2012
    1995 BMW M3
    What's up yall. No progress lately, just been too busy finishing up my semester, working, and slaying some easy college hoes before they all gone for the summer.
    On a side note, going to pick up the 210mm diff today!
  12. #2862
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    do work to those hos and that car.
    you're young. sleep when you're old.
  13. #2863
    Feb 2012
    1995 BMW M3
    Got the diff!! Thing looks and feels great. Solid as a rock. 3.15lsd out of a 750il. $300 picked up!
    Mklock came through big time!!! Huge shout out to him for the lead. I will be dedicating my number 4 piston to you buddy! Dude with the diff was cool. Was building a couple of tube chassis drag cars, one with a 700ci 16:1 running methanol and another monte Carlo he said was making 3000whp. Thing was crazy, wheelie bars, chutes, freaking monster.
    Got three more pistons to dedicate; secure your spot in history TODAY!
  14. #2864
    Manchester, N.H.
    96 332IS 6466 turbo
    Toss up pics of the 210 ! Welcome to the club of being indestructible.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  15. #2865
    Feb 2012
    1995 BMW M3
    Will do when I get home!
    It'll probably sit a while, I literally just re did the entire rear end so I kinda hate myself for that cause I really don't want to drop the subframe again...
    Do you guys through these 210s in stock or what? What's the best way to ensure this 210 lasts forever?
  16. #2866
    Vancouver, B.C., Canada
    '97 M3
    Take the cover off, clean, inspect, replace the clutch discs, put cover on, fill with Redline 75W140 and enjoy.
  17. #2867
    Mar 2013
    Upstate NY
    M3
    If you can slip the clutches by hand with the tires then I'd say replace clutches but if you can't just run it. The one that I found only had 60K miles so I just swapped it in and ran it.
    Run a good fluid it takes two quarts.
  18. #2868
    Mar 2012
    Renton, Wa
    98 m3
    Raj, i can source you clutches and dogs... if you so desire. They come out of germany so there is a lead time..
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  19. #2869
    Feb 2012
    1995 BMW M3
    I haven't decided yet. It is supposedly a low(ish) mileage diff....
  20. #2870
    Joliet, IL
    Out of Service
    The diff is a pain to install and remove. Pony up the cash now and just call it a day. You're going to be punishing it so why not prep it while it's ouy
  21. #2871
    Mar 2013
    Upstate NY
    M3
    I'll be honest here I don't think that's needed, yes maybe for you guys drag racing every week. It's not hard to install it took me couple hours to prep it for the 210 (bracket) cut front bushing out. Then another 3 hours to put it in the car.
  22. #2872
    Louisville, KY
    turbo m3
    I repainted the strut towers today. It looks so nice I'm gonna repaint the rest of the bay while the engine is out.
    How did you about that? Looks good.
    This is my signature....
  23. #2873
    Louisville, KY
    turbo m3
    Quote Originally Posted by jakermac View Post
    Ya, me too. I'm not ready just yet to give up on this yummy orange goodness:
    Details on the CCV setup?
    Drawing from the exhaust or intake?
  24. #2874
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by BadBoostedBmwM3 View Post
    I just cleaned it with dish soap, prepped it with some alcohol, and sanded it with 220 and 400.
    Shot it with some Boston green base coat and followed with a 2k clear.
  25. #2875
    Louisville, KY
    turbo m3
    I just cleaned it with dish soap, prepped it with some alcohol, and sanded it with 220 and 400. Shot it with some Boston green base coat and followed with a 2k clear.
    Custom Rattle can or some type of sprayer?
Page 115 of 186 FirstFirst ... 156590105106107108109110111112113114115116117118119120121122123124125140165 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
