Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #2801
    Manchester, N.H.
    96 332IS 6466 turbo
    While I agree with the 700 marker, sure. But under 600, i wouldn't bat an eye. I'd run stock pistons all day at those levels. I think the smart move in this is to stay under 600, or at 600. While I have forged pistons, I went above and beyond the 600 marker.
    There are boat loads of guys running stock pistons , under 600 and their fear is the rods. Tons. The real problem becomes greed. Wanting more then 600. At the 500 marker on a hard hitting turbo, like a 35r, your rods are at risk.
    I totally agree on the 6xx and above tho. 300-600 I wouldn't bother if money is an issue. Pistons+rings+machine work+filing rings+lot more time. Rods can be changed in an hour with motor plucked and head off.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #2802
    Mar 2012
    Renton, Wa
    98 m3
    Yeah 100% agreed. I would also file the oem piston rings. Some evidence showing oem piston rings can butt and break the lands.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  3. #2803
    Toronto, Canada
    E36 Turbo
    I think its a great move. Rods fail quick. But if tuning is good, screw it, keep the stock pistons. Rods are drop in and go.
    Where forged pistons require machine work, lots more money to install those.
    I personally think doing machine work and what not is the right way to do it. But certainly you can just get drop in pistons, ball hone the cylinder walls and you're off to the races without any machine work what so ever.
    I just don't see the point in going anywhere near 600 with stock anything.
  4. #2804
    Apr 2006
    Minnesota eh?
    86 325es
    moneys, there are only so many of them
  5. #2805
    Manchester, N.H.
    96 332IS 6466 turbo
    Yeah, people have been making 500-600 on stock internals for many many years. There are loads of guys running around with trm/TT/Technica kits and diy kits with just a mls or cutring/spacer. The bulk of F/I e36's out there the owners don't want to be cracking the engines open. Maybe the handful of guys here myself included go for the glory and invest stupid money into 20year old pos. But we are the minority.
    1996 332IS
    Built 3.2
  6. #2806
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by rajicase View Post
    Problem is now that I will have a fully built motor I'm going to want to make 800+ .... I should have started doing heroin. Would have been cheaper. Not too late though. Might part out the m3 and buy a bunch of heroin....
    It's also the only thing you could possibly sell on Panjo if you decide to quit
  7. #2807
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    So it keeps getting better.
    The main cap on the bearing that got messed up is totally screwed up. It got distorted and now the bearing tang doesn't fit and the main stud won't screw back into the hole in the block.
    So I tore down my spare 2.8 today and will be taking it and my pistons to the machine shop and have them bore out the 2.8 to 86.5.
    Basically the only thing I'll get to re use is my s52 crank.
    This keeps getting better and better...
  8. #2808
    Manchester, N.H.
    96 332IS 6466 turbo
    Life was simple with 500hp huh ?
    1996 332IS
    Built 3.2
  9. #2809
    Vancouver, B.C., Canada
    '97 M3
    He didn't have 500 whp.....
  10. #2810
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    465 with the old 256. No clue what i was making with the 366sxe at 21 psi and e85.
  11. #2811
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    S366 and 21psi on e85 should be well over 620-650whp on a 3.2.
  12. #2812
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    you were making licorice out of your rods.
    too soon?
    remember i read this thread next time you want me to strap snails on my hog. lol.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  13. #2813
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by doktor b View Post
    too soon?
    I'll remember that in a few months when I'm making 700 and continue to poke you until you come to the dark side.
  14. #2814
    '97 M3
    A few months..... Are you making a carter out of it?
  15. #2815
    Feb 2012
    1995 BMW M3
    You know how much money I have right now?
    Barely enough to put gas in my jeep lol.
    If I had money I'd already be reinstalling a new engine...
  16. #2816
    '97 M3
    I was just buggin'. You will often find you will have no money and all the time or all the money and no time. I have all the parts I need and no time due to too much work and family needs..... same same really...... with the end result of no boost
  17. #2817
    Feb 2012
    1995 BMW M3
    I know you were just Givin me shit.
    I need to get through school and hopefully with my lack of family and responsibilities when I graduate in December I can have a shiny parts build like all of you high rollers.
  18. #2818
    Mar 2013
    Upstate NY
    M3
    Damn am I the only one In the boat with no money and no time? At least I have boost for now.
  19. #2819
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by Mklock View Post
    no money
    no time
    no boost
    but i have freedom under the hood of my e36...
  20. #2820
    Feb 2012
    1995 BMW M3
    I repainted the strut towers today. It looks so nice I'm gonna repaint the rest of the bay while the engine is out.
  21. #2821
    Jul 2005
    PEI, Canada
    2001 330i
    It's a life balance that I haven't figure out.
    I've had money and time...and still couldn't get it right.
  22. #2822
    NY
    skateboard
    Ahhh being spared of the sadnesses, but you all are sad from lack of sadnesses .
    ― George Orwell
  23. #2823
    Feb 2012
    1995 BMW M3
    I have several things for sale if anyone wants or could share with someone interested it'd speed up my build exponentially!
    TRM tune with two revisions and 60# injectors for OBD1 s52 : $400
    ARP rod bolts $70
    X brace for e36 $100
    Super tech dual valve springs with steel retainers 84#: $450
    S52 crank: $250
    M52 crank: $50
    OBD2 valve cover: $40
    OBD2 ignition coils : $75
    Like new OE OBD2 knock sensors : $20
    S52 cam trays with lifters: $100
  24. #2824
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    Pm me about the tune and injectors!
  25. #2825
    NY
    skateboard
    ARP rod bolts $70
    S52 crank: $250
    M52 crank: $50
    Very fancy list
    ― George Orwell
Page 113 of 186 FirstFirst ... 136388103104105106107108109110111112113114115116117118119120121122123138163 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
