He does have the sxe. I googled 369sxe just now to see the flow rating. It could be wrong as i didnt verify it at the stop light
1989 535i - sold
1999 M3 Tiag/Dove - sold
According to full race it flows 94 lb/min
Sent from my SM-G920V using Tapatalk
I do have the s366sxe. I would love to dyno it with you zack, unfortunately looks like it's gonna be a while. I was hoping the pistons were okay.
Really bummed out about that , don't know what my best option is at this point.
Yeah i know buddy. You did confirm the limit of factory rods in style though.
The good news is you now are forced to buy proper pistons and get rid of the spacer.
1989 535i - sold
Am I the only one that would recommend taking that block to a machine shop? I keep hearing everyone say ball hone and I realize you're trying to do everything on the cheap, but all those bent rods and especially the damage to the one piston would leave me nervous that something also happened to the block. Just my thoughts. Sorry for your loss
Sent from my SM-G935V using Tapatalk
At 3:1 pressure ratio and 60% efficiency a 366sxe is about 85 lbs, a 369sxe is about 95. There is no regular 369, the biggest cast wheel s300 is an s366.
I'm still shocked that at that power the rods were only bent and not broken in half and through the side of the engine haha. An LS1 can barely handle 600 reliably and they keep dogging on me that their engine is so much better and that I'm wasting my time.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
The only reason an LS is good, once you replace all of the internals, is because it's aluminum and its displacement is huge in comparison.
Not quite true I've seen a bone stock LQ4 lay down almost 1100whp, drove it home normally. That is the "truck" motor but still LS based.
Not to get off topic here but there are definitely a ton more reasons the LS is good. As for the Ls1 only making XXX power reliably it isn't really as well tried on stock blocks as it seems to be with other cars, because it's way easier to sell the pricey aluminum block, buy a truck block for $300 and make 800+ whp on stock block
So I think my game plan is this;
Stone hone the number 6 cylinder until the bore looks new.
Bore gauge and mic the bore in several different places. Confirm it's in spec to run 86.5 JE pistons.
Assuming it is, I'll get some JE pistons and stone hone and ball hone all 6 cylinders and throw the new pistons and eagle rods in.
I want one of your rods for wall art, preferably the most f***** one, will pay shipping.
The aluminum engines make decent power to but not like the iron motors. I know someone locally that's been running 9.5's in a bracket race car for two years with a stock 5.7. If the goal is to make the most power with the least money with light weight that will fit in almost any chassis then a turbo LS is the greatest motor ever built ever ever ever ever by a very wide margin.
Would you be comfortable with posting your timing map?
...just to give an idea of where you were at for others running stock rods. (Like me!)
Sorry about the carnage, but it sounds like it was one heck of a ride until it let go.
Good work on the rods!!!
Sucks about the piston.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Well hey there , ready for 800 now.
Oh yeah, 350-400whp will satisfy me forever.
F****** b*******
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
