Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #2726
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Mklock View Post
    So wait.. rods are fine and you tore the motor out for a exhaust + lifter tick?
    No, washer fluid tank was getting little low. I think this was "while I'm there filling the blue juice". Situation
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #2727
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Correct. You know how those little projects snow ball..
  3. #2728
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Quote Originally Posted by rajicase View Post
    Correct, compression was really low in 3 cylinders.
    Also, no it wasn't just a lifter tick or exhaust leak lol. Chikinhed is just being a troll :p
    While using his name like this it also sounds like you're insulting him so it really works out in this context hahaha.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  4. #2729
    Manchester, N.H.
    96 332IS 6466 turbo
    They rally round tha family ! with a pocket full of shells.
    1996 332IS
    Built 3.2
  5. #2730
    Feb 2012
    1995 BMW M3
    Guys help.
    I can't figure out why it was knocking.
  6. #2731
    Mar 2012
    Renton, Wa
    98 m3
    Yep definitely lifter tick.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  7. #2732
    Nov 2008
    Indiana
    In before he assembles a fully built engine, maxes out the new turbo and decides he needs a bigger one.
  8. #2733
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by somebody5788 View Post
    1989 535i - sold
  9. #2734
    Vancouver, B.C., Canada
    '97 M3
    Was it the piston hitting the crank or the rod hitting the bottom of the bore?
    Troll...... Jeesh... :
  10. #2735
    Feb 2012
    1995 BMW M3
    So 4 out of 6 rods are bent. 5 & 6 are bad, 1&2 are kinda of tweaked.
    Bad news is, 6 piston is ruined. Crank and bore look fine, bearings all look great, but this puts a huge dent in my project.
  11. #2736
    Feb 2012
    1995 BMW M3
    Skirt is screwed up , and the ledge on bottom (don't know the term for it) is totally eaten up..
    Here next to a piston that is OK. All the pistons aside from 6 are fine.
  12. #2737
    Toronto, Canada
    E36 Turbo
    Well that sucks that you damaged a piston.... Remind me again why you used stock rods with forged pistons? Just seems like an odd thing to do.
  13. #2738
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by NOTORIOUS VR View Post
    Because 350-400whp was going to be enough to satisfy me forever. Same reason I bought a 56mm turbo.
  14. #2739
    '97 M3
    What brand of pistons at they? You will need the build sheet for them if you want only one or two made. If they are CP then you are looking at a ten week lead time unless you want to pay a big buck 'I want it now' surcharge.
    Next time I buy pistons I'm almost tempted to buy 8, just in case.
  15. #2740
    '97 M3
    LOL! That's funny.
  16. #2741
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    They are Arias pistons. I haven't called them yet to see if they can make one. But I do not have the spec sheet. So I'm feeling kinda screwed here. I cannot afford a set of 6 pistons right now, nor the machine work for it. Kinda bummed..
  17. #2742
    Feb 2012
    1995 BMW M3
    Spoke to arias , cannot buy one piston.
    So I need another set of pistons.
    I'm thinking I could get a set of JE 86.5mm pistons and new rings and just do a light honing of the cylinders. Does this sound reasonable?
  18. #2743
    Mar 2012
    Renton, Wa
    98 m3
    Maybe can reuse rings
    1989 535i - sold
  19. #2744
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by vollosso View Post
    I mean if I buy new pistons I should probably use the rings that come with em?
  20. #2745
    Mar 2012
    Renton, Wa
    98 m3
    I agree but if the specs match you wouldnt have to rehone.
    A ballhone would be sufficient if you do rehone for new pistons.
    1989 535i - sold
  21. #2746
    Mar 2013
    Upstate NY
    M3
    http://www.cnc-motorsports.com
    I'm not sure if they have the best price but it's one of the cheapest I saw.
  22. #2747
    Apr 2006
    Minnesota eh?
    86 325es
    A set of wiseco's from Real Street performance will be about $740 after using there 10% off promo code. I got mine in 3 weeks when I ordered them last year. If I was in your shoes honestly I would just get wiseco to make me one piston in a similar compression ratio and ball hone that cylinder.
  23. #2748
    '97 M3
    He may have to take a bunch of weight off the other pistons to get them in balance or visa versa.
  24. #2749
    Apr 2013
    Alabama
    1995 M3 Coupe
    Bummer about the piston
    1995 M3...Screwed
  25. #2750
    Mar 2012
    Renton, Wa
    98 m3
    So blackpearlz said he did 750whp out of the 369 at 21psi creeping to 29psi..
    Im driving but i read the 69 flows 95 and the s366 flows 87lb/min..
    Be curious what you dyno at 21psi buddy..
    1989 535i - sold
Page 110 of 186 FirstFirst ... 106085100101102103104105106107108109110111112113114115116117118119120135160 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
