This is what I have for a boost controller/AFR meter. Very happy with it.
http://www.amazon.com/Innovate-Motor.../dp/B00LBJAZLI
1989 535i - sold
1999 M3 Tiag/Dove - sold
Sounds like I need to run you before you turn up the boost
1995 M3...Screwed
all this money and time spent for 12 PSI?
#15 PSI or bust
"So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
Interest on a Very Budget Supercharger Build??
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Yesh. 12#.
1989 535i - sold
I saw a diy where a guy cut the case off an oem pump and clamped it to the 255. Not the cleanest install but it's free.
I would splurge on a filter that fits the pump.
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
I wrapped mine in a sheet of neoprene gasket material. My middle name is Hack
Aaaaahhhh. Sorry for the confusion. Didn't your walbro come with a sock? The only difference I saw was where the filter attaches to the pump my walbro has a different type fitting.
So how much boost are you putting through Raji, 24 PSI as these guys suggest?
24 is the new 12. Its amazing the progress the youngsters have made.
Lol you guys kill me..
I put in a 12 psi spring today.
Anyooonneeeeee know what pump filter I need??
There is a 255 with a hole offset that fits best. Might also be some filters that fit better. If you search around you may find the details.
