Got the motor on the stand.
Wiring harness and turbo removed.
Tomorrow I will tear it down and find out what went wrong...
Is that a boost logic manifold?
― George Orwell
Probably the best picture of a bl mani ever lol
1989 535i - sold
1999 M3 Tiag/Dove - sold
Triggered some fatty war monger who always talking about starting wars with other countries but when asked why he doesn't enlist he uses his fattyness as an excuse. I've been productive today..
― George Orwell
Those are the same guys that spend thousands of dollars on tactical gear and clothing so they can waddle out to the shooting range and pretend they are the worlds fattest special forces member and practice tactical shooting 2 feet from the target.
Soooo got the head off. I'll try and get the pistons out later but some preliminary pics. Essentially, every piston and every cylinder looks roughly the same :
Any input?
"ingenious"
i lol'd.
also, if it sticks rotating it one way, try reversing the direction you're cranking the motor over.
or flip it over on the stand and pull the pan. you'll be able to see your...
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
It's kinda lookin' like you had a lifter tick
Woah, relax. Haven't even gotten the pistons out yet!
See if they all come up to the deck at the same height as Someguy said. Any low ones have a bent rod.
Don't even waste time, rip them rods out and change them. You can fix the lifter on round 2.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
So wait, the rods were fine??
Lol you guys. I haven't even pulled the pistons.
Will be doing that today. But I got new rods so that's happening regardless.
So wait.. rods are fine and you tore the motor out for a exhaust + lifter tick?
