I might have missed it, but whatcha doing for the tune? Got a new TRM map for the e85? Are you obd1 s52? Chip swap?
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
It's taken me a solid 6+ months to convert to positive pressure, and I'm still not quite done. Time and money always seem to be the limiting factors. I really
Don't know how the hell some of
You guys do a complete turbo conversion in weeks or days.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Today I installed the 450 and wired it up, got the back seat back together.
Literally all I need to do now is install injectors, swap chips and turn key...
1996 332IS
Built 3.2
That'd kinda suck.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Injectors enroute
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
You could have made 600 on 93 pump with your 60 lb tune and your big turbo.
600 on 93 is really pushing the limits of safe IMO. Especially in 100°F+ days. Even more so when racing; doing back to back to back pulls.
E85 should provide me that safety, keep temps cooler, allow for more timing, and help spool up this big turbo a bit quicker. It will also be a better fuel when I inevitably want 7 or 800whp.
1989 535i - sold
Did you ever get a real tune from TRM or was it the base tune this whole time? If it was base tune I'm sure they could have played with it some.
1989 535i - sold
Ah okay, well anyway in for results let's see this rod carnage already I'm excited.
I got a revision.
I have no complaints with TRM. It was a great tune that had my car running flawless from day 1. And honestly, probably kept my car together despite running more boost than I should have on 100° days; 20psi pulls back to back to back on 93 probably was asking for trouble, but she stayed together.
