-20 percent chance of me moving it.
Today I installed a barb in the intake and hooked up the vac/boost reference for the fpr.
Build your car how i want it or ban.. mmkay?
1989 535i - sold
1999 M3 Tiag/Dove - sold
This is all your fault lol!
In 3 years we will all have TS steeds and 9180's . youll see. Once these guys starting hitting the dyno. Most of us already have our FPR's on the strut tower tho. That's just a given.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Dibs on old setup if he goes V8. I just want 500whp lol
Sent from my SM-G920V using Tapatalk
1996 332IS
Built 3.2
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
If you think metric, 22.05psi is only 1.5Bar.
Now it's only a little boost.
Oh that makes a bunch of sense. I'll just run 3 bar then. That should be really safe for test purposes.
Just weld the wastegate skip all this nonsense.
ugh, all this talk is making me want to convert over from 93+meth but my car will sit too much once it's done. I don't know if it's worth it based on that with some of the issues I've read about idle time in the tank/system. Definitely looking forward to the results though.
You've done a lot in what seems like a short amount of time, that's awesome. I'm jelly since my free time is very minimal and it's taking forever to get mine close to 100% where I want it. It's been a garage ornament for a few years now
Turbo E36 M3 with all the things..
I'm excited. Funny, I feel like it's taken forever. I started this project on 2/13. Gonna be at least a week from now by time it is running again, so over a month in this project.
Really feel like I could have knocked it out in a few days had I had the money to buy all the parts at once and the time. But school/work takes up the vast majority of my time.
hakentt would have had this done 2/14
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Man hakky would have been done on 2/12
