I demand you turn up the wick and take video of the vehicle in action.
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
"So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
Interest on a Very Budget Supercharger Build??
Waiting on a new valve cover, should be here next tuesday.
I'm also re doing my scavenge pump hoses. And I ordered a walbro 255 so I should be safe to crank the boost way up when I'm ready. Before I put it back on the ground I am putting a 10psi spring in, which should get me about 8psi at the intake. I'll probably leave it there till I get a dyno tune. Hopefully that will be soon.
Yesterday I rewired my boost and wb gauges, re did my turbo intake pipe, and put a nice k&n cone filter on, and cleaned up my scavenge pump wiring.
i thought we agreed 12#?
1989 535i - sold
1999 M3 Tiag/Dove - sold
And VOLOSSO! lol... I'd be running 25 psi right now if it were up to you :p ... I will turn it up, but I'd like to get a dyno tune before I do. I can't afford to blow this engine up. Well I think it is attributed to the fact that my wg reference is right off the compressor housing where pressure is the greatest and my boost gauge is in my intake manifold where pressure is going to be the lowest. And my boost gauge only reads in whole numbers. So my boost drop from compressor housing is likely 1.5-2 psi which doesn't seem all that far fetched.
And I'm running a boost logic manifold which is known to be one of the best in terms of boost control. So I'm not surprised I'm not getting any creep even on a weak wg spring.
I still haven't boost leak tested, been busy between work and school. But I welded all my chrge piping so I only have 4 silicone couplers. I also epoxied the hell out of all fittings. And I'm running an authentic tial bov. So I'd be shocked if I had any major boost leaks. Maybe my compressor housing? But again, my numbers seem pretty reasonable.
Sounds good bro, let us know the results on the 10psi spring. Sound like if you do have a boost leak, there aren't many places you'd have to look. Can't wait for vids so I can live through you vicariously lol.
1989 535i - sold
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
You're welcome
1989 535i - sold
200psi sounds about right.
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
Not gonna lie, after a big project or new engine my first thing is WOT lol. I like to test it right away hahaha.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
Give me the car, I'll WOT the babybackbulllllisht out of it for you
Its not like I am babying it.
I broke it in following the mototune method, its seen plenty of hard acceleration up to 6500ish rpms. But I havent done any extended WOT pulls yet. Bottom line is that after a fresh engine install and installing a custom, pieced together turbo set up(my first FI build), I have driven it with no issues and haven't had to troubleshoot anything yet. No weird codes. No idle issues. No vac leaks, bad sensors, fuel issues, etc. So I am gonna keep doing what I am doing, seems to be working. I think there is a fine line between being too easy on a new engine and beating the shit out of it and toying with significantly more power than I have ever experienced and being reckless.
Vollosso makes it seem like I am granny shifting at 2000 rpm lol.
Good for you. Don't let them talk you into something you're not ready for. Lots of folks have the money, time, resources to fix things easily and quickly, but not everyone.
Lots of guys have had motor failures too. I'd rather have a fun 500 hp car than a broken 700 hp car.
My line of thought. My goal from the beginning is a reliable 400ish whp car with a bit of room for more later.
And I definitely dont have the time/resources to throw a ton at this car right now. I did the build in my mothers car port cause the place I am staying at now has a mud pit for parking area >.< School and work take up most of my time right now, so I just want a reliable toy.
Awe man, you guys just let me harrass him for fun!
More boost :p
1989 535i - sold
"Do what thou wilt"
― George Orwell
Slowly turn it up. Make sure your all good and safe.
Maybe pickup a dual stage MBC. I had one for a bit. Turbosmart makes a nice one. Then you can put a rocket switch in and flip a switch for more boost. Start dialing it up, one # at a time.
1996 332IS
Built 3.2
12# spring or bust!!
1989 535i - sold
Lol I did think you were babying it below 2 to 3k RPM. I should've known better than to think you'd stay completely off the throttle lol
