Page 3 of 186 FirstFirst 123456789101112132853103 ... LastLast
Results 51 to 75 of 4646
Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #51
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I would say run without the WG, but that will be loud with the placement of yours. If you could just make some stub pipes and connect with cheap flex tubing that would be great.
    A few hundred miles break in are fine. I was at the dragstrip at 200 miles.
    I like this idea, I think itll be the easiest to simply remove the wastegate. I can deal with loud. I would rather not have to remove/install the turbo once I drop the engine in if possible. No issues with just removing the wastegate?
    Thanks for all the advice guys
  2. #52
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Noise and risk of exhaust into cabin. Getting it under car would be better. Will sound like dump truck with no exhaust.
  3. #53
    Feb 2012
    1995 BMW M3
    I think im going to make my wastegate lines out of 1/4" hard brake line w/ compression fittings at wastegate and charge pipe. Sound good to all?
  4. #54
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    Quote Originally Posted by rajicase View Post
    Seems to be working for Zack. Nobody likes a melted wg line..
  5. #55
    Feb 2012
    1995 BMW M3
    Yeah he had hard lines and some coupler thingy that the hard lines fit into I didnt quite follow. I think a 1/8 npt -> 1/4" compression fitting at the WG and tapped into the charge pipe will work well.
  6. #56
    Jun 2005
    New England
    Route them properly and no issues. Put them in DEI sleeves or tubes if concerned. Turbo since 2010, rubber WG and boost controller lines, no protective covering. No issues.
  7. #57
    Jun 2015
    Long Island, NY
    E36M3TURBO,E82135i,F15X5
    Thumbs down
    Quote Originally Posted by m3mods View Post
    Nope, not me, cost me some ringlands.
    Sleeves are working really well for me now.
  8. #58
    Mar 2012
    Renton, Wa
    98 m3
    Dawwe thanks
    Nah just silicone hose to hose-barb fittings and hardlines
    Quote Originally Posted by RAWe36boost View Post
    Nope, not me, cost me some ringlands. - - - Updated - - - Sleeves are working really well for me now.
    What went wrong? A tube is a tube it shouldnt matter if its metal or rubber?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  9. #59
    Jun 2015
    Long Island, NY
    Quote Originally Posted by vollosso View Post
    Dawwe thanks
    Overboost, no compressor reference to wastegate. Right in the beginning of the game too.
  10. #60
    Sep 2008
    Toronto, ON
    6465 328ti
    Welcome.
  11. #61
    Mar 2012
    Renton, Wa
    98 m3
    Doesnt sound like a hardline issue :p
    1989 535i - sold
  12. #62
    Feb 2012
    1995 BMW M3
    Just got a new Borg Warner S256...
  13. #63
    m3mods's Avatar
    Sep 2011
    AC Schnitzer S3 CLS
    Sx or sx-e?
  14. #64
    Feb 2012
    1995 BMW M3
    Sx. Why?
  15. #65
    Bellingham, WA
    e30
    SXE is the billet compressor wheel latest badassness. The S256SX is still a great turbo at an insanely good price.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  16. #66
    Manchester, N.H.
    96 332IS 6466 turbo
    Isn't that a small turbo ?
    Like smaller than gt3071 ? Or am I looking wrong ? For a 3.2L
    In precision terms 5661
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  17. #67
    Mar 2012
    Renton, Wa
    98 m3
    Its a 500whp turbo that should spool fast as hell.
    1989 535i - sold
  18. #68
    Manchester, N.H.
    96 332IS 6466 turbo
    How much boost will be needed ? To make 500
    1996 332IS
    Built 3.2
  19. #69
    Jun 2005
    New England
    What is a turbo with great spool (500 lbs rwtq by 4000 rpm) and that will make 650 rwhp at 25 psi on 93 pump plus meth on a 9.0:1 S52?
  20. #70
    Mar 2012
    Renton, Wa
    98 m3
    35r
    Sx256 has a 35r sized turbine wheel. It should flow well.
    Two other members are running them we should ask them.
    1989 535i - sold
  21. #71
    Feb 2012
    1995 BMW M3
    Someone check out this compressor map of a s256 over a 35r compressor map. Pretty impressive IMO. https://www.google.com/search?q=borg...UMpUWLUmz8U%3D
    My goal is a quick spooling and reliable 400-450whp set up. I was never going to feel right about having that "mystery" turbo , and this BW should give me peace of mind, hella quick spool, and enough power to meet my goals. Hope I made the right choice
  22. #72
    Jun 2015
    Long Island, NY
    Quote Originally Posted by e30kid89 View Post
    Welcome.
    Thank you.
  23. #73
    South Carolina
    2004 330 vert 2004 X5
    Someone check out this compressor map of a s256 over a 35r compressor map. Pretty impressive IMO. https://www.google.com/search?q=borg...UMpUWLUmz8U%3D My goal is a quick spooling and reliable 400-450whp set up. I was never going to feel right about having that "mystery" turbo , and this BW should give me peace of mind, hella quick spool, and enough power to meet my goals. Hope I made the right choice
    Wish I knew how to read those. Might as well be Plutonian
  24. #74
    Jun 2005
    New England
    Does the BW256 fit the TCD manifold better or worse?
  25. #75
    Manchester, N.H.
    96 332IS 6466 turbo
    I think the 256 is more of a comparison to the 3076
    http://honda-tech.com/forced-inducti...3076r-2220363/
    1996 332IS
    Built 3.2
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
