I once heard a really well known engineer in the industry say "Everyone has a fuel problem, most of the time they just don't know it".
Had a nice BMW meet today. A lot of n54s. I was the odd man out XD
instant grams: doktor_b
Sooo spoke with zack about adding some more fuel. I bumped my base pressure up and he added some more fuel up top and I turned it up to 21ish psi and lawwwddd have merttthhy... she wild.
Loving the progress. I'm going to look back and copy a lot of your setup when I up my fuel system for the e85. Running Zacks 93 tune for now and it goes like hell. What's the size on your Rsrrs? That's probably my next upgrade
That's exactly what I'll be doing then. But my current wheel setup is on 18s. 8.5 front and 9.5 out back but I think I'll get the same 255/40s Rsrr out back. Right now It'll spin all the way through 2nd and hook fine 3rd+ on 13psi. My current alignment is about -3.2 out back so I'll definitely have to raise the car and dial that out a bit.
Yeah that camber is screwing you right now.
Keep in mind rsrrs run really wide. 255 will require some pretty serious rolling out back I think. I just cut my fenders and got flares lol..
1989 535i - sold
1999 M3 Tiag/Dove - sold
Looks like I'm breaking out the grinder again
Would 255s fit under stock fenders? When I got mine it looked like it would be a ton of work to get them to fit the rear ad they might not ever fit, so I just cut and flared.
1989 535i - sold
1989 535i - sold
Yes
1989 535i - sold
1989 535i - sold
255/40-17 rs-3 fit under my fenders with a little roll..but I don't hook 2nd on 22psi and e85. That would be nice..might look into these tires when I replace these.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
Are you guys running into any issues with the tire contacting the fender lip right where the fender meets the rear bumper? I had to grind the lip there and trim some of the bumper inside.
