Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 80
Thread: M62: Gauging Interest, Big Bore Throttle Body 85mm
  1. #26
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    How do you plan on opening up the 82mm hole in the flange that the 85mm TB will be mounting to?
    Part #12......
    http://www.realoem.com/bmw/enUS/show...diagId=11_2281
  2. #27
    Dec 2010
    Simpsonville, SC
    2001 BMW 740i Sport
    Good question - but are they really perfectly matched? The TB gasket is several mm larger in diameter than the TB itself - it would be an easy answer once it's all appart.
    I ordered a used TB from a 745. It arrived and it is the "627" part, not the "308". I measured with a ruler and the inside diameter is not more than 83mm. Not the greatest tool for measuring but I would say that replacing ours with a 627 is not worth it. has anyone measured the 308?
  3. #28
    JimLev's Avatar
    Sundance Mesa, NM
    [QUOTE=mjbrokster;29139816]Good question - but are they really perfectly matched? The TB gasket is several mm larger in diameter than the TB itself - it would be an easy answer once it's all apart.
    QUOTE]
    The OE parts do match.
  4. #29
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    Quote Originally Posted by mjbrokster View Post
    So what exactly was the measurement? OP state's the 308 is ~84mm. Was the 627 not 3.25" ID or was it close to 3"?
  5. #30
    Dec 2010
    Simpsonville, SC
    2001 BMW 740i Sport
    The 627 is 82mm ID which is 3.23" ID. Same as the m62tu TB. I didn't read close enough. I thought all N62 TBs were 84mm. I'll have to exchange for a 308.
  6. #31
    Aug 2012
    Austin TX USA
    2006 M3 ZCP/2001 540iT
    Bump, anyone had more success making an n62 tb, and 4" stuff all the way out work?
    2001 540it Black/Black --- 2006 M3 Competition Pkg Black/Black
    **FOR SALE - E39 DINAN 540I 4" intake and filter - gently used PM ME for details.
  7. #32
    Philadelphia, PA
    2005 M3 & 2004 330i
    308:
    627:
    Gasket is the same. That wall definitely looks thinner on the 308 part, so it's probably at least a couple mm wider.
  8. #33
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    Thanks so much for sharing, I'm interested but since I'm in Argentina, I was starting the off the shelf parts investigation to see what I could find here. Your generosity is greatly appreciated!
    I'm confused with one thing: The connector is the same but the pins are in different places, right? I may try my luck in removing the pins and move them around.
    Thank you!
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
  9. #34
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    The X5 has at least one TB that seems identical to E39 M62TU by eye but has a slightly different connector shell shape, Juan. So... I dunno about this one but if it has a different housing I won't be surprised and if so perhaps the X5 connector will be a donor candidate.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  10. #35
    Jan 2014
    I see, thanks JC! Maybe I can use the connector out of a crapped up M62TU TB and make a pigtail loom so I don't have to cut the original harness... Opening up the N62 TB to replace female connectors seems too much work especially since they only come in the press fitted cover flavor... or maybe I'll just splice and I'm giving it too much of a thought. =)
    Diehard E39 driver.
  11. #36
    Mar 2010
    What might be possible is the pins may be the same so you can just unclip the pins and swap into the other "carrier shell"? IIRC the style of connector is very much similar just with the asymmetrical "key" part of the shape on a different side. I'm not home now or I would get a pic. This is all suppositional or course - lets see somebody post up what the actual TB socket is...
    2003 M3CicM6 TiAg
    Former:
  12. #37
    Jan 2014
    Oh I get it now, mirrored keyway... yes, most likely the pins are going to be the same, so I can just buy a pigtail from eBay and swap the actual crimped connectors in the new male shell.
    Diehard E39 driver.
  13. #38
    Philadelphia, PA
    2005 M3 & 2004 330i
    I don't think the pins are the same. The N62 throttle body connector looks more like the M54 connector. Pins are a bit wider
    M62
    N62
    The M62 looks like it has MQS contacts; N62 looks like MCP1.5k contacts.
    This looks like to be the male variant of the M62 connector. Not sure which key is the correct one: http://www.te.com/commerce/DocumentD...f%7F1-967587-3
  14. #39
    Mar 2010
    Hmmm seems you're right M. Shouldn't be hard to get a connector but not a simple repin. Again I'd dig my parts out but not home.
    2003 M3CicM6 TiAg
    Former:
  15. #40
    Philadelphia, PA
    2005 M3 & 2004 330i
  16. #41
    Aug 2012
    Austin TX USA
    I'd love to see if the 84-5mm TB is really a worthwhile upgrade. DUDMD said he has not come across one in the wild so I guess its pretty untested. OP, update please?
  17. #42
    Jan 2014
    Quote Originally Posted by TerraPhantm View Post
    I'd probably just make an adapter.
    For the Throttle body connector:
    Housing: https://www.ecstuning.com/Search/1J0973713/ES311340 (TE equivalent is 1823467-1, but I can't find it for sale in small quantities)
    Pins: http://www.digikey.com/product-detai.../A107016CT-ND/
    Seals: http://www.digikey.com/product-searc...words=964971-1 or http://www.digikey.com/product-searc...words=963530-1 (depending on wire thickness.. I think either would be okay with 20AWG TXL wire)
    For the harness connector:
    Housing: http://www.digikey.com/product-detai...-3/A122075-ND/
    Pins: https://www.ecstuning.com/Search/Sit...3703/ES164879/ (minimum quantity elsewhere is 100)
    Seals: https://www.ecstuning.com/BMW-E46-33....0L/ES2537968/ or http://www.mouser.com/search/Product...ualkey967067-1
    Priceless information! thanks!
    Diehard E39 driver.
  18. #43
    Philadelphia, PA
    2005 M3 & 2004 330i
    Just updated my post. It was a little ambiguous as to whether or not the pins I selected would work with the VW connector. So I just linked to a kit that contains everything
  19. #44
    Jan 2014
    Thanks!
    Diehard E39 driver.
  20. #45
    Aug 2012
    Austin TX USA
    Quote Originally Posted by europorsche914 View Post
    I have been doing a lot of research to attempt to create a stage 5 kit using as many off the shelf parts as possible. I believe I have located a suitable replacement throttle body. I am wondering what kind of interest the 540 owners may have for a kit which includes larger maf, maf-throttle body tubing, throttle body and tune. I may or may not also create a custom cold air intake as well, depending on interest. Let me know!
    Any update OP?
  21. #46
    Jan 2013
    FORT WORTH, TX
    2002 540I
    Bringing this thread up again as I am interested in using the N62 TB.
    I wonder if this TB spacer from ECS would work in place of the M62 TB spacer since the opening is too small as stated earlier in this thread. Its expensive might might add some gain too (or probably just marketing hype).
    https://www.ecstuning.com/BMW-E64-650i-N62_4.8L/Engine/Intake/Throttle_Body/Spacer/ES2207823/
    After looking at this again, it appears the spacer is much different since the OEM is wider and goes from 6 to 4 bolts.
    Guessing no one has found a solution to the smaller spacer opening.
    OP - do you have any updates to share?
  22. #47
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by jpjack72 View Post
    When I installed the Dinan TB I opened up the ID of the spacer plate.
  23. #48
    Jan 2013
    FORT WORTH, TX
    2002 540I
    Ah cool. Do you mind sharing how you opened it up? (what tools or process) I have a good friend that has a machine shop and could probable make me a customer spacer but if the plastic OEM piece can be opened up thats seems easier.
  24. #49
    JimLev's Avatar
    Sundance Mesa, NM
    I used a curved file, then a round sanding drum on a drill press, and finished it up by hand.
  25. #50
    Jan 2013
    FORT WORTH, TX
    2002 540I
    Perfect, really appreciate your response. You always bring a treasure drove of knowledge to this forum!
  1. H7 Super Fogs(nearly new)....Big bore throttle body
    By Nimble in forum BMW Parts For Sale
    Last Post: 01-14-2003, 01:29 AM
  2. Does a big bore throttle body help 325's?
    By VT325 in forum 1991 - 1999 (E36)
    Last Post: 10-18-2002, 09:15 PM
  3. Big bore throttle body
    By Scott528iM in forum 1991 - 1999 (E36)
    Last Post: 06-28-2002, 01:40 PM
  4. Big Bore throttle body helpful for FI?
    By KilljoyM3 in forum Forced Induction
    Last Post: 04-25-2002, 12:36 PM
  5. anyone modded w/big bore throttle bodies??
    By 232is PoWeR in forum 1991 - 1999 (E36)
    Last Post: 06-22-2001, 02:52 AM
