Page 22 of 22 FirstFirst ... 1213141516171819202122
Results 526 to 548 of 548
Thread: 4.6is M62B46 into '03 540it. From day one.
  1. #526
    Chicago, IL
    98 740IL & 00 740i sport
    So if a 6 speed is going in, to run the 4.6is software would require a custom DME tune for the manual?
  2. #527
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Do we know that the 4.6 converter is larger?
    All I know is that it has a 400 rpm higher stall speed.
    And the 4.4 converter might stall higher behind a 4.6 than the rating for a 4.4.
    Normally a higher stalling converter is smaller, but we know it's not smaller, just different. 4.4 convertor is nominal 11".
    I know someone who could check.
  3. #528
    Nov 2011
    Stupid los angeles
    99 540i6, 02 X5, Tundra
    The 4.6 is bigger,
    Plattus what supercharger setup are you planning?
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
  4. #529
    Apr 2016
    Well there you have it.
    I searched the internet for info and couldn't find that.
  5. #530
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    Quote Originally Posted by 1999 540i m View Post
    The 4.6 is bigger,
    You'll have to ask Wagons_Ho, he's building what I want.
    It'll be the last on a longer and longer list as time goes by.
    In the beginning of this thread, where I'm talking about building a strong 4.6 to handle some forced air without strain, aboit that time, WH started thinking about how to make a blower that wouldn't destroy the engine.
    As for the DME tune, possibly not but because BMW, yes most likely. The Alpina B10 or B8 could be mapped out and partitioned. I think DUDMD has these files.
    Team that up with info we have from ess and other centrifugal chargers on say an m5's DME?
  6. #531
    Nov 2011
    Stupid los angeles
    Quote Originally Posted by Plattus1000 View Post
    Still patiently waiting on Wagons ho's supercharger project, in the meantime i'm installing ms3x on mine, starting with fuel only
  7. #532
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    My guess, his life gets complicated as do all of us. I'll hold out patiently too. I have seen some of his work. He doesn't enjoy short-cuts from what I've witnessed.
    What pump/filter?
  8. #533
    Chicago, IL
    I still think the 4.6 TC will fit the 4.4. A friend of mine confirmed he had done this on a 4.4 x5...
  9. #534
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    Quote Originally Posted by purplecty View Post
    I think the 4.4 X5 had the same bell as the 4.6, just a smaller t/c. I don't think a 4.6 transmission will fit.
    Should be easy to confirm.
  10. #535
    Nov 2011
    Stupid los angeles
    What pump/filter?
    For E85 I'm using a Quantum 340lph and a m62 filter to an adjustable pressure regulator,
  11. #536
    Chicago, IL
    I do not think the trans will fit just the torque converter...
  12. #537
    Nov 2011
    Stupid los angeles
    It can be made to fit with a grinder
  13. #538
    Chicago, IL
    Hmmm... I was under the impression it was plug and play. Maybe not...
  14. #539
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    Quick note: this thread, if nothing else (like many before it) speak volumes to the notion that just because it'll be tough or hasn't been done before, if you have the will... : )
  15. #540
    Nov 2017
    Crestline ca
    M6 e63, 740i e38
    I can confirm that the trans do have some swapability,
    4.6 trans will fit into a 740i and the trans from the 740i will swap into the x5 , pulling the trans from my 4.6is right now and going to put it in the 7 , just swap the rear output shaft , as far as computers go , those are completely plug-and-play however, the 4.6IS , EGS is programmed to lock up the torque converter a lot more, I have 4.6IS EGS units in my e38 ,e39 and X5, witch will be getting a regular non sport trans, and I guarantee it will work fine but still lock up the converter a lot more. Not going to do a manual swap because I love my paddle shifters.
  16. #541
    Nov 2017
    Crestline ca
    M6 e63, 740i e38
    IMG_20190311_011821.jpgthis is a sport trans going into the 4.6is
    IMG_20190311_011829.jpgScreenshot_20190311-012451.jpgaccording to ZF the 4.4 X5 has its own bell different from the 4.6is and sporte38/e39. Use this link to find out what you can swap it's how I did it. https://www.google.com/url?sa=t&sour...=1552292947921
  17. #542
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    That's all awesome! See? Now we know. Cool.
  18. #543
    Nov 2017
    Crestline ca
    M6 e63, 740i e38
    Has anyone noticed that the 4.6 uses a under-driven crank pully vs the stock 4.4 , this is more for making power than reducing rotating mass right?15529568350332589379092569982489.jpg
    4.4 PN 11231741773
    4.6 PN 11237513336
  19. #544
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by Jaspr6 View Post
    4.4 PN 11231741773
    4.6 PN 11237513336
    Huh! Interesting! Am I right in eyeballing that both belts are slightly under driven but the AC is just more under driven?
    If you had one for free / cheap great but $600 for the .732 hp it represents is prob not really worth getting too excited about.
    Cool data fact though.
    2003 M3CicM6 TiAg
    2014 BMW X1 xDrive28i (hers)
    2008 Audi A3 2.0T DSG (soon to go on the block)
    1999 Cherokee Sport 4L (trailer-hitched in-law-loaner bomber)
    Former:
    1985 Euro 300SL
  20. #545
    Mar 2017
    Finland
    e39 546i
    Attachment 646485
    Attachment 646486
    Was able to source a tub44 cylinder head, this head has a 5 cc smaller combustion chamber than the head on the TUb46, virtually the same except for combustion chamber size, the b46 also has higher quality valves and springs installed in it to handle its 10.5mm lift cam. After I transferred the valves, springs and cam over. I had it decked half a mil (.5mm). Did some calculations and it came out to a 12 to 1. Also check clearance for valves when in 20* advanve. And they cleared by (.4 mm) I would post some pics but I don't see any option maybe because I'm new, there are plenty in my profile however of its build
    Have you calculated what is your dynamic compression ratio when vanos is advanced?
    I also have a b46 block with b44tu heads. But the deck is lowered by just 0.1mm or less.
    I had to do timing cams in the old school style. I used two dials. I couldn't use cams lock pieces because cams were more aggressive than b46 standard.
  21. #546
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    Sorry to shift gears but I've been silent a while, waiting for new things to add.
    Yesterday DMI in Ballard WA (Dimitry) Let me have my car back after a few weeks without her. He'd spent the last few days (not weeks, sorry. I just parked the car) trying to ferret out a power loss I've had since the 4.6/4.4 tune.
    While in there, he also took care of some other needed things:
    Fuel filter, air filter, oil lines, brake lines, trans drain/fill-filter, new o2 sensors, air bags in the sls rear, plugs and a coil.
    This next week, I'll visit the other Dimitry in Auburn WA at DUDMD.
    With luck, he can pull my DME and re-write it or toss in another. For one reason or another, mine is sick. He can fix or replace it.
    The last piece I need to secure for diagnostics would be the Mark IV nav computer to make my BUS system read ALL the codes it has... Germans.
    If this all goes well, I'll try to put down some real numbers and post them.
    I still am waiting on a part for Ghostbutts and some read-outs for m5Jed.
    I am trying. Not on the Dead Pool thread yet GG!
    Once everyone else is happy, I will be doing this;
    https://forums.bimmerforums.com/foru...-DIY-with-Pics
    Since I've had the wavetrac since I had my sedan (bad kid, I know.)
  22. #547
    Mar 2017
    Finland
    e39 546i
    Hi,
    Why not a real LSD diff?
    I just made a diff swap.
    Previously i have a 2.81 ratio 25% LSD and now there is a 3.38 40% LSD. It's fun now…
    e39 540i/530d custom ratio Lsd Diff starting price was just over $1,500.
    I think the LSD with stock 2.81 ratio would be cheaper.
    My diff has new Timke bearings and 40%/15% locking and 4 friction shims and special assimetrical 30º Accel/60º Decel ramps. Also a custom 3.38 ratio. The total price and shipping costs were $1,980.
    I don't know how much Wawetrack is. But this custom diff was plug and play. No machining, etc.
    3.38 Diff in test and action:
    https://www.youtube.com/watch?v=Va2ujuW4laE
  23. #548
    West of Boston, MA
    2001 BMW 540iT/6
    A WaveTrac is $1299 through DiffsOnline and has a stellar reputation for performance and durability. Could not be happier with mine. No clunking or whining, just insane grip.
  1. From Day One
    By The Night Rider in forum 1988 - 1996 (E34)
    Last Post: 03-14-2015, 05:14 AM
  2. Replies: 2
    Last Post: 01-03-2012, 09:48 AM
  3. Feeler: Like new (stonguard from day one) ZKW's
    By Androulakis in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 01-28-2004, 04:55 PM
  4. Back from day 1(Barber BMWCCA Race)
    By Randy in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-28-2003, 03:17 PM
  5. Spun into a curb from flat tire... what to look for
    By Josh///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-06-2001, 09:52 AM
