O2 sensors replaced today, not as bad as I thought it would be. I don't enjoy being under a car held up with jack stands. Also swapped out my timing chain tensioner, the one on the passenger's side (starboard) of the engine. No more ball bearings in a coffee can sound on startup.
Conclusion, 50 miles later and there's no codes showing so next step is the last dyno run @ Drift-Office before letting DUDMD have some fun tweaking the engine on his dyno.
Oh and that little secret surprise is coming together nicely. I can't wait to reveal it.
Just passed my emmissions check with the secondary air pump and the evaporative control pump coded out.
In another month I should be ready to delete the cats and have DUDMD code them out too. Then the fun begins.
Oh, and yes, I still need one more dyno @ Drift-Office...
I procrastinate just a tad now and then.
Let me guess .... NOS!
Alright. I'm going to guess it's VF s/c kit.
I wish but I think I'll hold out for one of toolman2's twin screw kits. I think he's really got something good there.
No. For the time being I'll stay naturally aspirated. It's killing me not to say anything more but I promised someone that I wouldn't say anything until the install.
I'm not done with this thread. I had all the work done during my slow part of the year and now I'm busy every day. I need another dyno to find out how TerraPhantm and DUDMD's flash performs with this engine.
So far, no codes and it runs great. I do have a tiny oil leak that I'll need to track down but it's below the v/c's and I need to remove the splash guard to really get a look. That means a lift/time. For now, I'm topping off in the morning and not pushing her too hard.
The thread ain't dead!
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
-Paul
-Paul
There's still going to be O2 sensors, AFR monitoring bungs too for a future addition of the wind machine.
Long time coming. It's been a work-heavy few months. My car is trashed inside. I haven't vacuumed the car since before the swap. I'm a bad owner.
-Paul
Them Jedders sure look purdy but $$$. Also, they look big like almost 3" to 3.5" tubing.
#sizematters
Need...? Want. Back pressure is not a friend of the m62 so if I had the $, I might go cut outs but honestly, just so I could scare people in tunnels, not for performance.
I might need to finally use a muffler of some kind. Hadn't thought about that, might not too. Cart before the horse.
4 -2 -1 (Tri-Y) modular design*
True equal length runners*
Full T304 Stainless Steel construction 100% Mandrel bent tubing*
TIG welding, fully back purged w/ Argon Solar Flux type B in cases where back purging is not applicable*
Laser cut exhaust port flanges*
Oversized exhaust ports to accommodate ported cylinder heads*
3” V-band flange exit pipe*
Profiled merge collectors*
Double-slip joints w/ stainless steel spring clamps*
Tuned stepping*
Removal of front subframe not required for installation*
100% of raw materials & supplies sourced from USA manufacturers.*
Mandrel bending, welding and fabrication services provided by USA vendors.
