Results 1 to 8 of 8
Thread: GS6-17BG 6 speed tansmission from 06 e90 325i
    Jun 2005
    Wilmington NC
    1990 332i
    will the GS6-17BG 6 speed transmission fit the m50/s52 engine
    Bmw e30 332i
    Bmw e36 m3 convertible
    Bmw e46 325i
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    Idk but this is an interesting subject. Subscribed...
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There have been some threads on this subject, maybe in this or the M3 or the FI subforums. I think you need a different clutch, different linkage, different mount and different driveshaft.
    Jun 2005
    Wilmington NC
    1990 332i
    Yeah thats what im trying to figure out i have the transmission and i have the clutch disk with the proper splines, the e90 flywheel bolt pattern at flywheel is different, so i could use a e36 325i dualmass flywheel for clutch and i noticed that the e90 flywheel has a larger ring gear for starter, was looking for more info, wanting to swap this into my e36 m3, i may pull the tranny from my s52 e30 as i already have a e36 325i clutch flywheel installed on it and see how it mounts up and check starter engagement
    Bmw e30 332i
    Bmw e46 325i
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Subscribed .. If the tranny can be put on a m5... That means the engine can to a e36.. And that puts a 3.0 n5 engine a newest cheap engine swap. (Given ecu hacks. )
    -Oakdizzle
    Jun 2005
    Wilmington NC
    1990 332i
    Yep the bellhousing is pretty close by looks and i know a few bolts are not going to line up, I may test fit in s52 e30 this weekend and see what i'm working with and if its possible
    https://instagram.com/p/-fAMAjnkdj/
    https://instagram.com/p/-fAU7Knkdy/
    https://instagram.com/p/-fASaIHkdt/
    Bmw e30 332i
    Bmw e46 325i
    Denmark
    87 E28 M5, 95 318ti
    Did you ever try this?
    Apr 2017
    United States
    95 540i,98 328i, 93 325i
    Quote Originally Posted by Loupoz View Post
    Go over to the forced induction subforum, they have a recent thread regarding this. https://www.bimmerforums.com/forum/s...n-(S6-53)-Swap
    1998 318i m52 swap 3.38 lsd, 1995 540i/6 speed (SOLD), 1993 325i, 1999 328is m-sport, 1996 328i GT35
  1. Toronto - Black '06 E90 325i M/Sport Pkg.. Manual.. charcoal delete+brospeed muff
    By 325tolife in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-17-2011, 07:59 PM
  2. E9x Silver 16" stock rims from 06 325i e90
    By troyer16 in forum Wheels and Tires
    Last Post: 09-29-2010, 08:56 PM
  3. Go from E90 325i to E36 M3?
    By voltron1011 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2007, 03:40 PM
  4. will wheels/tires from 06 325i 16" fit my 98 323?
    By maleih in forum 1991 - 1999 (E36)
    Last Post: 06-18-2007, 10:21 PM
  5. FS Getrag 260 5 speed Transmission from my 88 325is
    By jmarch in forum 1983 - 1991 (E30)
    Last Post: 10-01-2006, 01:13 PM
