Results 1 to 18 of 18
Thread: Tires for 2011 328I
    Aug 2015
    Tempe, Arizona
    Bicycle
    Tires for 2011 328I
    Hello,
    I need to replace my tires. My car currently has the stock optional 17" wheels with four P225/45R17 tires. My question is, can I put the wider 255/40-17 on the rear tires? Or do i need to get all four replaced with the P225/45R17 tires? I'm not sure if the wheels in the back need to be bigger to use the wide ones..
    Jun 2015
    Las Colinas, TX
    2007 328i e92, 2007 RS4
    Go big. Not sure why you would stop there unless your rim won't support more. I am running 275 on my E92, and 245 front.
    Michigan
    2005 325Xi
    Quote Originally Posted by lmariach View Post
    Hello,
    You'll be getting wider tires just for the sake of getting wider (and more expensive) tires. You'll never notice the incremental increase in rear tire traction, and without wider rear wheels, the appearance of the tires' width won't be affected much.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Nov 2015
    San marcos california
    2007 BMW 328i
    Wider tires look way cooler. I also have 275 in back and 245 in front. They run great and are fun as heck! I decided to get a cheap brand and try it out for the first time. Nankang ns-ii. Mostly for drifting than anything else, but surprisingly good for daily also!
    Aug 2015
    Tempe, Arizona
    Bicycle
    Quote Originally Posted by seattlesquash View Post
    How do I find out how wide my rim can support?
    Carol Stream, IL
    2015 BMW 435i xDrive 6MT
    Hello,
    Assuming your wheels are 17"x8", then you probably can't run 255's. I think the minimum wheel width for most 255's I've seen is 8.5".
    Michigan
    2005 325Xi
    Quote Originally Posted by mokoboy1998 View Post
    Wider tires only look "way cooler" if they're mounted on correspondingly wider wheels. Otherwise they look ghetto.
    Aug 2015
    Tempe, Arizona
    Bicycle
    okay I'm just going to get new wheels. Staggered 8.5 front , 9.5 rear. Or should I just get 8.5 all the way around? The benefit being that I could rotate them equally... If the only benefit for staggered is looks I'm thinking it may not be worth the long term costs.
    Also, how do I know what size aspect ratio to choose for an 18" wheel? It seems the 245F/275R is standard for a stagger but I cannot seem to figure out what the aspect ratio (middle number) should be?
    Michigan
    2005 325Xi
    TIRERACK.COM will tell you the proper sizes for your car.
    Aug 2015
    Tempe, Arizona
    Bicycle
    Thanks, I actually called them today but they weren't much help because they do not source the wheels I want.... I ended up getting some good advice from a local Discount Tire here. I decided to go with staggered beyern spartan wheels- 8.5 front tires 245/40/18 , 9.5 rear tires 265/40/18. They said this tire size would fit well. I was starting to learn toward 19's but just can't commit because of practicality and additional costs of replacing the tires. I do not plan on lowering my car fyi. Now that I have the size down I just need to pick a good tire. I welcome any recommendations.
    Fort Collins, Colorado
    2008 328xi Sportwagon
    Just make SURE that the diameter of tires front and rear is the same! Don't tear up your X drive.
    You can check tire diameters and revs per mile on the Tirerack.com site by looking up the tire model you plan to use.
    Aug 2015
    Tempe, Arizona
    Bicycle
    I don't have X-drive, does that make a difference? Over all diameter for Continental Extreme Contact DWS Tires show 25.7 front/ 26.3 rear for the tire sizes I listed above, is that close enough?
    Carol Stream, IL
    Why don't you just get the matched set? 235/40/18 (25.4") & 265/35/18 (25.3")
    For comparison, your stock 17" tires are right around 25", so going to 26.3" will probably cause rubbing issues.
    Aug 2015
    Tempe, Arizona
    Bicycle
    Quote Originally Posted by trohde78 View Post
    That is what the employee from discount tire told me would fit w/ the wheels I want and "look good" with a higher backend staggered look. Honestly I'm lost when it comes to tires so I was just looking for the widest tires I could fit without any rubbing issues, while still having a comfortable ride. So your saying it may rub in the rear while those sizes?
    Carol Stream, IL
    There's a chance it could rub. Generally the tire width is the issue (a 265 is fine), but going a full 1" taller may cause problems. However, if Tirerack said it will work, then I would think you can trust them.
    Aug 2015
    Tempe, Arizona
    Bicycle
    Sorry to bring up an old thread but I wanted to ask everyone who runs F245/R275 a question. Does this mess with the accuracy of your speedometer?
    Running a 245/275 with the tire I'm going to get would put me at overall diameter 25.7/25.6, 808/811 revolutions per mile, which is pretty close.
    But when I used the wheel offset calculator on bimmerpost I got 2.893% difference for the 245 front tire from my oem setup. And putting a 275 on the rear only put me at 1.689% difference. Is the 2.893% too much?
    Maybe I'm just nitpicking but I guess I'm wondering if I should just go with a 235/265 to be safe and not stray too far outside the 1-3% recommendation. BTW this is a RWD car not AWD.
    Thanks,
    Lucas
    Any time you change to diameter of the tire, you change the accuracy of your speedometer.
    My speedo had the normal error of reading 3-4 MPH higher than actual speed; when I run my snow wheels/tires, their diameter is just enough larger that the speedometer becomes accurate!
    You can bet that the next time I need street tires, I'll work the same trick with them...and very much on purpose. BMW is very consistent about having their speedometers indicate a higher speed than the vehicle is moving.
    Incidentally, you can download apps for your smart phone that will use your GPS system to show your *actual* speed - which you can compare to the speedo reading. I use one called DigiHUD on my Android phone.
    May 2017
    Ontario, Canada
    335i E93 N54
    Old thread, but reading it for research and replying in case other read as well.
    BMW speedo will show 4 kmph over actual, intentionally.
    This can be coded out so it reflects accurately as well, though I prefer the 4 kmph over.
    Clearly tire circumference affects the actual speed as well. Oodles of calculators online.
    That said, I'm currently migrating to f245/40/18, r275/35/18. I have X1 322 wheels (9" rear) and really hoping (also expecting) them to clear!
  1. Wheels and tires for 1996 328is
    By radialaced in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-12-2007, 03:13 AM
  2. Tires for 97 328i Conv
    By tedbmw in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-29-2006, 06:00 PM
  3. Best tire for my 328i
    By luvinmy328 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-24-2005, 11:46 PM
  4. WTB: Spare tire for 98 328is
    By iwannadinanm3 in forum Wheels and Tires
    Last Post: 07-14-2004, 02:06 AM
  5. WTB: Spare tire for 98 328is
    By iwannadinanm3 in forum California sponsored by Avus Autosport
    Last Post: 07-10-2004, 07:15 PM
