Let's hear what tools the E34 section needs the most. Im willing to build at my own cost any tools the E34 group needs and the tools can be shared free of charge for shipping. Have at it.
"You may all go to Hell, and I will go to Texas."
Davy Crockett
www.Angry-Ass.com
My Build Thread Part 1, Part 2
DIY E31 X-Brace Mod and Install
DIY Rear Seat Backrest Modification for E32 Armrest
Ok done.
Davy Crockett
www.Angry-Ass.com
I think these are just tools to be made to be circulated among the group. If that is the case here are some of the tools I can think of that would benefit the members here.
M50 Timing Blocks
M50 Gear Sprocket Wrench
ZF Transmission Detent Tools
95 E34 553i6 LS TR6060 Project
93 E34 525iA Beater with no heaterVANOS kicked in yo!
Current
2005 E55 AMG
1998 Silverado K1500
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
2001 Stratus 740i Msport
1990 750iL
1995 540i/6
1996 MGM
rear subframe tool would be nice
There's a gun building group that does this. I recommend doing what they do and requiring a deposit. We all mean well, but things happen and stuff will get lost.
Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
88 Alpineweiss / black E30 M3 -Project.
Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
98.5 Tiag Silber /black e36 m3 - Modded.
99.5 Estoril Blau /dove e36 m3 - Modded.
07 Crimsonrot /black E83 X3 6spd - Stock..
S38/M30 crank and flywheel locking tools. Ready to send deposits for those.
A special wrench for the M60 engine mount top bolts would make that job super easy - and what M60 doesn't need engine mounts?
Current Fleet:
E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
Past:
E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
E39 1998 528i 5-Speed Black on Black - Sold locally.
E34 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
as said already, m50 cam timing tools and rear end bushing tools are a must for a project like this. i know ill be needing them hopefully soon
Davy Crockett
www.Angry-Ass.com
Davy Crockett
www.Angry-Ass.com
Davy Crockett
www.Angry-Ass.com
Davy Crockett
www.Angry-Ass.com
It would be something like a socket that sits on the nut, with a neck on it that drops down below the engine mount bracket and then does a 90 degree bend with a handle on the end. Make sense? Probably not haha.
The crank tool that holds the pulley so you can get the jesus bolt off? That is what I will end up needing if the front timing chain covers are leaking on the S38, which I think they are.
Current Fleet:
Past:
Davy Crockett
www.Angry-Ass.com
Rear subframe bush tool
Rear Diff bushes tool
Crank holder tool
Door handle outer trim release tool (changing outer rubber seals)
Manual flywheel holding tool (clutch changes)
More HP to my M30 tool!
I used the Baum RTAB tool. It worked on 3 of the 4 with ease—then the bolt broke. Now my car pulls to the left!!! I can send it to you if you need a template to "improve" upon.
1991 535i 5-Speed, BLK/BLK, RD sways & headers, Vogtland, Konis, GC camber plates, ported, yada yada yada....—108K miles and waiting for a turbo!
M60 jesus bolt tool. And definitely a tool for the top motor mount nuts.
