Results 1 to 13 of 13
Thread: Is anyone running an external GPS with Harry's Lap Timer?
    Sep 2012
    Charleston, SC
    10 335i - 97 328is x2
    I've been using Harry's for the past year and love it. It's pretty accurate but since it's my primary lap timer, I'd like to improve the accuracy. I'm thinking about using the Dual Skypro XGPS160 which is recommended by Harry's. Is anyone using this specific one or any other external GPS and what is your opinion of it? How much improved is the Harry's experience with the external GPS?
    Thanks!
    1997 E36 Track Car - Started life as 328is
    1997 E36 S54 Track Car
    2010 E90 335i - Daily driver
    2011 F-250 - Tow rig
    Oct 2007
    sterling hts, michigan
    02 M3
    I use the Dual XGPS150 5hz external, it works great. Definitely a worthy upgrade.
    Jun 2006
    Atlanta, GA
    '89 e30 mash up...
    I have the dual as well. It works fine.
    Sep 2012
    Charleston, SC
    So once the dual is paired with the phone, it doesn't have to be re-paired before each session, correct?
    Oct 2007
    02 M3
    Yes it has to be paired every session. The dual takes up the bluetooth signal so I bought a Wi-Fi based OBD2 scanner, both work great.
    Sep 2012
    Charleston, SC
    Quote Originally Posted by Inflame View Post
    Well I ordered both the dual gps and a wifi based OBD II reader! Hopefully they work well
    Sep 2012
    Charleston, SC
    So I ordered an Automatic brand OBD II wifi adapter as it was recommended by Harry's. I downloaded automatic's app, however, and the adapter seems to only log info related to driving so as to maximize your fuel efficiency. It doesn't provide access to all the sensors I expected it to allow me to access (water temp, oil temp, tach, intake temp, etc when plugged into my E90 335). Does anyone else have experience with this adapter or any others that work with Harry's and provide access to all the sensors?
    I'm going to return the Automatic and order a new one.
    Oct 2007
    02 M3
    I have this $15 one, http://www.amazon.com/Elm327-Wirless.../dp/B00871CJFI
    Works for me.
    Sep 2012
    Charleston, SC
    Dang that's a lot less expensive! And it works with Harry's and provides access to all the sensor info?
    Oct 2007
    02 M3
    Quote Originally Posted by SalahHH83 View Post
    It provides info for whatever your PCM is willing to spit out, atleast I think that's how it works.
    For me, it provides RPM, Throttle percent, Coolant temp, etc. Though I have an LS1 PCM. Friends S2000 provides same info except throttle percent.
    Nov 2005
    MA
    bmw 330
    digging up old thread and hoping someone can answer 2 questions:
    1) I would like to use the Dual via bluetooth and the OBD2 reader, also via bluetooth. Can I use 2 bluetooth devices at once, with Harry's? I am assuming since an iPhone can support both a keyboard and headphones w/ bluetooth, at the same time, it will work. Thoughts?
    2) Where do I mount the Dual in my E46 ? Any suggestions?
    BryDog
    Mar 2006
    New York, NY
    Z4 M, X3 35i, 550i
    Quote Originally Posted by BryDog View Post
    BryDog
    1. Yes not a problem. I use the GoPoint BT1 OBD and Dual XGPS simultaneously which are both Bluetooth devices.
    2. Mount on rear parcel shelf so it has a clear view to sky. You can zip tie it to one of the rear child seat anchors.
    Nov 2005
    MA
    bmw 330
    Thank you so much !
    Quote Originally Posted by Dubbedown View Post
    1. Yes not a problem. I use the GoPoint BT1 OBD and Dual XGPS simultaneously ...
    Got any video I can check out ??
