Page 7 of 8 FirstFirst 12345678 LastLast
Results 151 to 175 of 184
Thread: Big block i6 e39
  1. #151
    Royalest of Oaks
    Mazda 3
    I don't know much about pistons but those are a beaut.
  2. #152
    Mar 2012
    Renton, Wa
    98 m3
    Lol those are meaty.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  3. #153
    Jun 2010
    Reykjavik Iceland
    ALPINA B10 BITURBO
    wow,,, lots of effort
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    ULTIMA Evolution
    Contacts
    http://alpina.123.is/pictures/
  4. #154
    Feb 2013
    South Dakota
    01 530i, 83 Chevy p/u
    This is the most crazy bmw engine swap ive ever seen!! Absolutely brilliant!!
  5. #155
    Nov 2015
    Melbourne
    E39 528i
    Fixed the dump today, when I made it I forgot to add a turbo oil drain (idiot) and it was all ready to run except for that in the old car so I tried to weld one in under the car and had to use some spicy because I couldn't get the whole way around with the welder. It was dodgy and I hated it. Then I forgot to fix it again when I put the engine in this car... Plus it was also not in a good spot for the current setup so I made a bung thing to weld in and moved the fitting to a better spot (I hope, hard to know 100% with out the block or anything here to check against).
    Came up alright.
  6. #156
    Nov 2015
    Melbourne
    E39 528i
    Engine machine shop have started on the engine so shouldn't be too long. I decided to get the pistons HPC coated so that might add a few days but will be worth it.
  7. #157
    Mar 2012
    Renton, Wa
    98 m3
    Thanks for the weaksauce update! Back to work
    1989 535i - sold
  8. #158
    Nov 2015
    Melbourne
    E39 528i
    Picked this up today
    New lounge room ornament
    New wrist pins aren't great. The big ones are my old ones, I'll reuse them
    Old vs new
    Will start assembly tomorrow.
  9. #159
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Withe the heavier pins and old pistons the weight is almost the same as the new pistons and the old pins.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  10. #160
    Nov 2015
    Melbourne
    E39 528i
    I didn't achieve too much yesterday. Well not as much as I would have liked because I had to drive around for 4 hours to get bearings from the only place that had them in stock because the machine shop forgot to order them and being a Friday I couldn't wait until next week to get them posted here. Today I have to enlarge the holes in the head gasket which is a job I've always hated doing. Hopefully the new cometic gasket will be a bit easier because the layers are only held with a couple of rivets, where the old gaskets were very well held together and I was always concerned with Swarf getting between the layers and compromising the gasket.
    Gapping Rings sucks
    As does fitting piston clips
  11. #161
    Raleigh, NC
    SR-71 Blackbird
    You know what? Should've coloured the pistons differently like rainbow colours. One yellow, one green, one indigo, etc ... Just saying.
  12. #162
    Mar 2012
    Renton, Wa
    98 m3
    Finally an acceptable update good progress dude!!
    1989 535i - sold
  13. #163
    Nov 2015
    Melbourne
    E39 528i
    Well I opened up the head gasket holes pulled the it apart into layers for deburring. Spent almost the whole day driving around again because the machine shop didn't machine out my dowel holes to suit the bigger studs and dowels which I was very pleased about. Managed to find a 17mm have reamer to do it myself. After hours of driving and $105 later I had a reamer and headed home to assemble the engine. Just the head gasket mods takes hours with a total of 48 holes to debur on both sides. Anyway, the head is on, cams are in and timing chain on. Now I've got to head out to an engagement party and tomorrow I'm dirt bike training for most of the day. Hopefully I'll get a bit done in the arvo though and the rest of the assembly goes more to plan.
    Not wrapped to need this after spending a small fortune having the machining done..
    The stopper layer that apparently makes all the difference with these mlx gaskets
  14. #164
    Nov 2015
    Melbourne
    E39 528i
    This is annoying..
    As is this..
    Prime time
    Forgot to put this thing on. Off it all comes again..
    There is a very strict method that may be followed if you want any chance of installing the turbo stuff
  15. #165
    Australia
    Looking for a BMW
    You have a massive clean up job there before you can get it out for a drive by the looks of it. haha
  16. #166
    Raleigh, NC
    SR-71 Blackbird
    At least it's back in the car. Time for some big powah!
  17. #167
    Australia
    Looking for a BMW
    And then....????????????????
  18. #168
    Nov 2015
    Melbourne
    E39 528i
    All going well I should be on the dyno tomorrow
  19. #169
    Australia
    Looking for a BMW
    So did things go well?
  20. #170
    Australia
    Looking for a BMW
    Any updates?
  21. #171
    Nov 2015
    Melbourne
    E39 528i
    Well a lot has happened since the last update. Moving houses, separating from partners, changing jobs etc. The good news is that I still have the car and for the most part it's in one piece.
    I did dyno it but had a few transmission issues with the lock up convertor slipping and possibly something in the trans slipping as well. With the boost turned down all the way (8-9psi) it still managed to make it 660rwhp @ 5000rpm. Didn't get to go much higher than that due to the trans issues.
    A few days later I managed to destroy the intermediate shaft in the trans doing power skids 😞 since then I've moved the car around a bit (only has gears 1-3) but that's about the extent of the work done on it until recently.
    I've bought a cnc machining centre and rented myself a factory and managed to get the bug again to start building stuff for the car. A mate from work does a bit of drifting so I'm thinking I might have a go at that as well. Seeing as the car isn't really fit for purpose on the road I'm seriously considering stripping it out. I've got some seamless rollcage tube already and find a set of coilovers which I installed the other day. Also picked up a tr6060 gearbox, a tilton triple plate clutch and have numerous other parts laying around that will likely find their way into the car.
    Will start designing a flywheel and gearbox adaptor soon and machine them up on the machining centre. Also considering machining a billet sump because I'm not happy with the cut and shut job I did on the current one.
    What does everybody think about going manual and roll cage?
  22. #172
    NW suburban Chicago
    hiss by my window
    Every time I think of myself as handy with a wrench I stumble upon a build like yours and feel like a caveman.
    Your engine choice is interesting, your skills impressive.
    Well done so far, sir. Please, carry on.
  23. #173
    Elizabethtown, PA
    99 540i6
    Geezus...
    '99 BMW 540i6 L33 5.3, PRC Heads, E-force supercharged
    http://forums.bimmerforums.com/forum....php?t=1674320
  24. #174
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Thorpatrol View Post
    Sounds like you aren't breaking enough things with the slushbox.
  25. #175
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    100% yes.
