Page 1 of 8 12345678 LastLast
Results 1 to 25 of 184
Thread: Big block i6 e39
    Nov 2015
    Melbourne
    E39 528i
    Big block i6 e39
    Hi everyone,
    I'm new here and pretty new to BMW goodness as well, but after much thought, it seemed like a good idea to share my build with you.
    The basics are....
    Engine: Nissan TB48
    Transmission: Ford/ZF 6r80
    Diff: Nissan R230
    Turbo: Large
    Sump: Not wet
    I just moved into my new house and so I finally have a garage again after almost 2 years of having no space to work on anything fun. Before I moved any furniture the first thing I did was Park the e39 in the garage and start removing parts and spreading tools and mess everywhere. That was about 5 weeks ago and since then I've made pretty good progress. I'll go through everything up to where I'm at currently shortly and include a few pictures, however I just finished a 12hr night shift and need to go and pass out for a while..
    All stock and in desperate need of boost..
    Dave
    Nov 2015
    Melbourne
    E39 528i
    Out with the old
    Nov 2015
    Melbourne
    E39 528i
    Not super practical but still plenty of room for groceries
    Nov 2015
    Melbourne
    E39 528i
    Hello large piece of aluminum
    1x TB48 to 6r80 adapter complete
    Nov 2015
    Melbourne
    E39 528i
    Goodbye miniature diff and axles
    Nov 2015
    Melbourne
    E39 528i
    Hope there isn't too much comfort lost
    Nov 2015
    Melbourne
    E39 528i
    Time for some 930 cv adapters. Made from en26 steel
    Nissan R230 to 930cv
    Stock 528i outer CV housing / stub ale with adapter to 930cv
    Finished with 4340 axles. Cv joints have chromoly cages also. The outer CV sits further inboard which isn't ideal and I had to modify the lower rear arms to clear the cv boot
    Nov 2015
    Melbourne
    E39 528i
    Nov 2015
    Melbourne
    E39 528i
    Need to attach the turbo
    Nov 2015
    Melbourne
    E39 528i
    Need a flex plate to attach the torque converter to
    More 6061
    And got a tci 3100rpm bolt together torque converter with multiple disk lock up clutch that's rated for lockup under WOT
    Nov 2015
    Melbourne
    E39 528i
    All together
    Obviously painted the trans mount before final install
    She's in! This motor is LARGE, I'll measure the difference in size between the TB48 and the 2.8 that was in there
    Nov 2015
    Melbourne
    E39 528i
    80mm intercooler piping tacked together. Cooler core is 600mm x 300mm x 125mm thick
    Bonnet almost closes too...
    Nov 2015
    Melbourne
    E39 528i
    Plumbing these back in.. What a pita
    5 inches of awesome
    Nov 2015
    Melbourne
    E39 528i
    Billet adapter to get rid of the three bolt donut rubbish and convert to 1350 uni. Another 108mm chromoly cv which attaches to the R230
    Exedy frictions kit for the 6r80
    And back together... Hopefully correctly
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Wow, awesome build! What kind of machine shop hookup do you have?
    Aug 2008
    Houston, Tx.
    '10 X5, '98 M3 - 302
    That's impressive. By the looks of it, you have your own machine shop? I've never heard of those engines. Time for research
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    You sir have mad skills. Very enjoyable to view. Please keep the updates coming. I know it's a pain to stop and take a picture in the heat of a build, but I for one will enjoy.
    Look forward to future installments.
    Dan "PbFut" Rose
    Aug 2011
    Salt Lake City
    '95 M3, 97' E39 540i-LS3
    Wow. Love all the custom components.
    540i-LS3-TR6060 swap thread
    Nov 2015
    Melbourne
    E39 528i
    I wish I had a machine shop! We have a workshop at the place where I work that I use after hours sometimes. I do have some of my own machines but they are in storage until my big shed is built. I get by mostly with a tig and a 5" grinder.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Impressive skill set! And also impressive how much custom work you did in a very short amount of time.
    Jun 2008
    colton, ny, usa
    95 M3 turbo V8, GSXR 600
    looks like this is not your first build. look good man keep us updated!
    1995 E36 turbo v8
    Nov 2015
    Melbourne
    E39 528i
    Been a bit of a slow few days unfortunately. Mostly running around getting bits and pieces. Got some chromoly to make a front sway bar, a few intake bits and a flex fuel sensor. Also got some aluminum tube for the dry sump hard lines. Working 12hr shifts all weekend too which doesn't help. Hopefully I can be motivated to get a bit done after work :-)
    Going stealth
    The chief! This should keep my head clean
    Flex-a-liscious
    5.5" to 6" elbow
    Running out of room pretty quickly...
    Buffalo, NY
    2001 BMW 540i/6
    love this. you Aussies are nuts. i had to look up what a 6R80 even came in.
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
    Minneapolis,MN
    2003 M5, 2014 535i
    Fantastic work and machining skill!!!
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
    Raleigh, NC
    SR-71 Blackbird
    Holy crap!! The first thing I read in your first post was the engine TB48 and I was like, "BLOODY HELL YEAH!!!!!" This is going to be so good. Having grown up / born / raised in middle east, UAE, I know what these 'big block I6' engines are really capable of. I just wish I could see more of a toyota turbocharged 1FZ as well but most like to go for the TB48 engines from nissan. Well done.
