Hello fellow BMWers,
First post here.
I have a friend with that has an 2007 120i N46 engine (european version), and he has been having a lot of problems with it for some time.
The car runs rough when cold, at idle when hot, and has a slight hesitation on part throttle acceleration.
Here are the codes that have been pulled with my scan tool:
BMW specific:
2C24 present
DME: Oxygen sensors before catalytic converter mixed up
29CC present
DME: Misire, several cylinders
29D0 present
DME: Misfire, cylinder 4
29CE present
DME: Misfire, cylinder 2
OBDII:
P0040
O2 Sensor Signals Swapped Bank 1 Sensor 1/Bank 2 Sensor 1
I have already cleaned the injectors, changed spark plugs and coils, cleaned the MAF, and checked fuel pressure (55 psi).
And yes, I have already tried to swap the connectors on the upstream O2 sensors.
None of this has solved the problem. I am running out of ideas, input from you guys would be very much welcome.
Hello.i have the same problem and no result.all of a sudden my car shake at idle.i changed all i could and no result.do you find any solution?
Hey, the problem on my car was the eccentric shaft position sensor, and the connector for the injectors on cylinders n° 3 and 4 were switched.
The P0040 code indicted that the cables for pre-catalytic converter O2 sensors have been swapped. That causes the DME to chase its tail.
http://www.realoem.com/bmw/enUS/show...diagId=18_0641
Sorry but who swapped my connectors??? last service intervention was 6month ago and were changed filters and oil nobody works at the oxigen sensors before to appears that error
And connectors cannot be reversed a cable is longer than the other
Dirty or defective fuel injectors can also cause this problem. Since the N46 engine has two cylinders banks, 1&3 and 2&4, if you swap an injector connector the car will still run fine, but fine fuel metering will be off. The DME doesn't have a fault strategy for inverted fuel injector connectors, it will think there might be a problem with the lambda sensors instead.
Thanks i will swap the injector 4 with 3 to see the result thanks
The eccentric shaft position senzor didn’t show any error on the diagnose?No codes? How can i know if my eccentric is good or i need to replace him ?
I swaped the connectors 3 with 4 and my car runs perfect.thank you so much
