Results 1 to 11 of 11
Thread: Photos and locations of E32 fusible link
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Special thanks to E32Fan, it is now on my website, see Photos and locations of E32 fusible links under Reference data>>> Data - Electrical
    http://twrite.org/shogunnew/topmenu.html
    X6400 is the power post inside the E box. It feeds only DME loads. Page 1361-01 for M30 and 1367-00 for M70. Fusible Link A is 50 Amps
    Page 0670-10 Fusible B is 80 Amps. It feeds all the Rear Power Box loads
    Brantford ON Canada
    735iL - 1989
    Thanks for posting this shogun. Just an observation, and a question - my M30 engines have had no troubles with intermittent Fusible Link A. I wonder whether this is only a problem for M70 engines?
    M30 has just one DME, with half the current draw of M70.
    Jan 2005
    Japan
    And another no start problem solved with no start due to the fusible links, he also found first only one on his E31, https://www.bimmerforums.com/forum/s...-fusible-links
    Apr 2017
    San Diego, CA
    90' 735iL, 90' 535i, 93'
    I was able to find a 100amp(too high?) inline fuse holder to replace fusible link A. Got everything hooked up, car started, sputtered then died and currently will not start back up. I had also made sure to double check my fuel pressure regulator. The vacuum hose (no clamps, just pulls off?) was dry and did not smell of fuel. I did not however remove the whole regulator to check for seepage. I will most likely pick up a new one today but I'm not extremely confident it will solve my issue.
    As always any assistance has been and is still greatly appreciated!
    Side note: while replacing the fuel pump I was unable to locate any solid info on what the "pre filter" looks like of how to replace/service although my blinders may not have allowed me to find any such info.
    Jan 2005
    Japan
    Here some pics, first 2 is the fusible link which goes from battery to the engine bay to supply power to the e-box. Originally wrapped in shrink tube, difficult to find.
    The one on the black plastic box supplies power to the rear fuse box under driver side rear seat for GM, RM, relays, fuses located there
    BMW 61131382065 Fuse Battery Cable Positive 80A
    http://www.bimmerboard.com/forums/posts/377728/
    http://www.bimmerboard.com/forums/posts/377948
    Jan 2005
    Japan
    and the next one where the fusible link was the problem, took him almost a year to find out: 530i die after 1km start back after cooling down -- solved, fusible link https://www.bimmerforums.com/forum/s...-link-replaced
    Jan 2005
    Japan
    did someone already replace the original fusible links with these reversible ones? called: Car Audio Inline Circuit Breaker Fuse 12V System Protection 50A, also available for 80 A.
    Any disadvantage/advatage?
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    Just completed this job. Went from the originals..
    .. to two 80A audio fuses as recommended. I’ll also be able to carry a couple of spares in the trunk. I used ferrules on the wires for an easier install.
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Video showing the location and replacement of the fusible links:
    90,700 miles 1992 BMW 735iL Azure Blue Metallic with Silver Grey leather interior ‣My car ‣My YouTube channel
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Hi shogun need help was gonna change fusible links but I finally got someone to come look and he said there still good backstory no power after wrong terminal hookup
    Jan 2005
    Japan
    please explain no power? Does the starter move but engine does not start? Or no starter movement at all? Checked all fuses in engine bay and under rear seats? Are you sure that both fusible links are o.k.?
