XRIMS
Results 1 to 5 of 5
Thread: Modular 3mm Spacers, Stackable, Use with Existing Spacers, Etc - $15 - SOLD
    Mar 2001
    Iowa
    '03 X5 4.4i Sport, E320
    I'm selling these modular 3mm (1/8") spacers. If you have a set of 12, 15, 18mm spacers and would like to have the ability to cheaply make them modular to a slightly different width, these are for you. They can also be run without any other spacer to give you an additional 3mm of clearance or stacked up to 3 thick (use of hub extender required over 6mm width).
    These are CNC laser cut from 5052 aluminum and typically have a tolerance of +/- 0.002" to ensure a precision fit.
    To remain hubcentric when stacking or when used with an existing spacer, you only need to measure how far the hub sticks out and confirm that it is more than the chamfer depth on your wheels. Typically most wheel have chamfers under 4mm in depth, so I recommend making sure you have at least 5mm of hub sticking out before mounting your wheels.
    Longer bolts are not included and you'll need to verify that yours have the appropriate length. Stock bolts will typically be fine if only adding 3mm spacers but obviously I recommend using the correct length bolts.
    The price is $15/pair and shipping is a flat rate $5 via USPS. I have plenty of these available at this time. If you'd like to order, my paypal address is maurer.todd @ gmail . com (no spaces) - please include "3mm BMW Spacer Pair" and your shipping address in the payment details. If your payment method has a paypal fee associated, please add 3%.
    Let me know if you have any questions! Thanks guys. :)
    List Date: 10/30/2015
    For more info, click here to view the original listing: Modular 3mm Spacers, Stackable, Use with Existing Spacers, Etc - $15
    SOLD
    May 2005
    Diamond Bar, CA
    97 M3/2/5
    Will these work with my ECS 5MM (extended lugs from ECS)?
    Current cars:
    87' Zinnorot 325is
    91' Alpine white 318is
    92' E30 Alpine white Mtechnic
    97' E36 Alpine white M3/2/5
    Mar 2001
    Iowa
    Quote Originally Posted by hakstern View Post
    Yes if the lugs are long enough. You may need hub extenders if used up front to avoid vibration as mentioned above.
    Todd Maurer
    Past - 5 E36s, 1 E39, 1 MB W210 E320, 1 GMC 6.5 ECLB, B6 A4 3.0 6 Spd Quattro
    Present - '05 E320 CDI, '06 VW TDI Jetta 5 Spd, '02 Ford F250 CCSB PSD, '02 Ducati Monster S4
    Mods: 92* Thermostat, MB to BMW Wheel Adapters, 18" BMW Style 72 Wheels, Custom Mercedes-Benz Diesel Plate Frame
    Mar 2001
    Iowa
    Have some updated pictures on HR 12mm Spacers.
    Todd Maurer
    Mar 2001
    Iowa
    TTT, still have a bunch of these. PM me.
    Todd Maurer
