I need one that holds the readings and has a valve to release PSI. Accuracy is also very important.
Thanks.
///Major Havoc
BMWCCA
'98 M3/4 Cosmos Black/Black 5sp manual
Shark Injector
X-Brace, UUC TME, Eibach Anti-Swaybars, Hawk HP + Pads, Stainless Steel Brake lines
Ground Control ( Track / School coil-over kit ) 375F/450R
GC Camber Caster kit, 3.46 40% LSD, Strong Strut brace
Chk out - http://amazingfacts.org/
'06 530xiT Auto - Olivin Metallic/Beige
Premium Sound Package/Logic 7 - Cold Weather Package - Premium Package - Comfort Seats
Park Distance Control - Navigation - SIRIUS Satellite Radio - 3-Stage Heated Rear Seats - Rear Side-Window Sunshades
Try BMP Design
www.bmpd.com
I bought an Intercomp liquid filled 0-60 psi gauge from Pegasus (www.pegasusautoracing.com) and love it. It is very accurate and has about 18" of hose and a pressure relief which makes it easy to use. It is about 3" in diameter and has a protective covering around it that will prolong its life. I was about $55-$60 so it was not cheap, but it will last and can be read to the 1/2 pound if needed. Hope this helps!
Brian
...speed is not about going fast, but living to tell about it....
I decided to go with the Digital Accutire Gauge. Seems like I made a perfect choice according to European Car(July).
I didn't get the exact model that they tested but it seems like they us the same internal components.
http://forums.roadfly.com/m3/message...ges/18914.html
///Major Havoc
BMWCCA
Shark Injector
