Due to the semi success of my SC14 Supercharger Build.
I am proud to announce that finally due to much demand, I might soon try to start work on EATON M90/M112/M122 Supercharger Bracket Designs for the M5X and S5X Family of Motors.
I call it...
The HMW Anarchy Plate
Now the word Anarchy is not itself a bad word that its put out to be, its more so people of various backgrounds working together for commonality without having big brother governance so to speak, and it may be the perfect word for it since not only the bracket will look like the English Letter "A", However the fact that although I may have been inspired with this idea, the work of the final designs and its development may not be done at my hands at all.
Anyhow, I would like to request those who have any experience, to as of the type of Eaton most commonly found or rather most readily available to you (Consider Part Sellers, Junkyard Finds, Ebay Etc), and also tell me the cars they are off, and finally the design (snout size, small or long etc), and as always any pics and ideas would be appreciated.
"So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
Interest on a Very Budget Supercharger Build??
That's sweet. A Whipple or kenne bell SC would be even more bada**!
If I could have gotten a Whipple onto my s52 I might have done that over turbo.
https://whipplesuperchargers.com/ind...product_id=218
^ Would had fitted this 2.7L twin screw beast if I had the funding to buy & R&D.
Can be done, the eaton bracket system may be modified to fit these now that i think of it..
Yeah they are expensive.
This is relevant to my interests, but not quite necessary just yet. Soon!
Hey doing God's work there OP! I live in Malaysia and I have to say that we get more SC14/13/12s than Eaton/Whipple/ESSs superchargers here. The SC14 costs like $100 at the breakers here whereas the Eaton's go for $500. However I have a few concerns:
1. The SC14 isn't serviceable - but you could probably buy a lot and swap them out as they break for the next 10 years!!!
2. OP can you provide us some dyno data etc?
As a side note I'm supporting you on the Eaton bracket design!
Thank you.
Yea, they cost around $200 here, its not serviceable however so there's a downside, however as long as you keep it within spec, you would be fine. I am currently running 2.3 Ratio (16000RPM at max engine RPM). I will do dyno one day, but makes a tad bit more power then a Euro M3. Let me know if you guys in malaysia need any help with these, I see some builds with them, but yea. Feel free to post locally if there is any interest.
People are still building around these small blowers really,
Here's something using the SC14 Blower - http://pcmhacking.net/forums/viewtop...3543&start=290
Oh forgot to mention a few things as well:
1. How much does the 10mm V2 bracket weigh if you make it out of mild steel? Just doing some weight increase estimations here before - might buy a CF hood to compensate
2. Any plans to do a bracket design for AC compressor? My thoughts are RHD cars don't have much turbo options because the compressor and steering rack clearances. If we relocate the AC compressor to the intake side it would help a lot. Mounting a turbo is easier and the AC gets cooler air!
Thanks.
I would say a solid 10KG after its all done, the blower adds another 12KG. The V1's are half that weight.
But overall if you look at the from a technical perspective, on our RHD Cars we get something called Torque Steering, As in we sit on the right side, the direction the motor/crankshaft spins, these cars are meant to be driven LHD to balance that out. I am doing fine with it.
I left the AC Compressor bracket for a twin supercharger setup, never perfected it tho.
I can actually hook you up with a Turbo manifold setup for RHD Cars, but that would cost around $500 or more. Then there is the Turbo and other bits to sort out, Problem with Turbos for those of us in this RHD Region is really that most people are happy with another 100 - 200hp on top of what they got, and with a turbo you spend money for equipment that you cant max out the potential of because well..most people wont want to replace the Head Gasket and all that stuff inside the motor to run a nice turbo setup to lets say 15 - 20PSI. So they end up running them around low boost, by which logic they might as well had gone for a cheaper bolt on sc setup. I will go with a Turbo setup when I am in Europe, but these are just my humble offering to the larger majority of DIY builders.
Do you want a setup by chance? I could use a rep in Malaysia actually.
Hey misterm52
I'm doing a swap on my e46 in the very near future and would love to slap the charger on
Have you guys had anyone running one of these on an e46 m52tu motor?
Sent from my SM-G920I using Tapatalk
Hi, Been kept very busy last 2 weeks.
We had it running on a M54B25 on a E46 about a month ago using the V2's, But then the guy crashed it shortly after and sold the car.
So I'd say yes, it works on M52TUB28/25 just fine.
Yep, slight modification but retains it.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Hey fellas, so with my 20PSI rated pulley (and a whole lot of hot air), I had this pulley adjusted for the blower but the inside sproket piece was not welded well enough or so which lead to the thing coming off, the pulley free wheeling and ultimately breaking of my main pulley shaft stud that came out of the keyed sproket. Now these are only worth a few hundread dollars these blowers but instead of replacing it out I mearly did this fix, where I had a older friend here locally drill a 7mm hole in the keyed gear piece, then thread it to i think M7 bolts, ofcourse it wasn't completely straight but the only job it serves is to keep the pulley in there, the real job of keeping it in line is done by the key piece and bearing. So anyhow, after a bit of work here is the repair, not pretty but looks alright Imho..
I have a small announcement to make, sorry I have been quite busy with a few things.
I think I may now consider shipping out entire bolt on setups for $1K - 1.2K USD Shipped Anywhere in the world. This will include:
Laser Cut Bolt on Brackets + SC14 Supercharger + Pulley + Belt + Shipping to your door for around $1.2K.
You will be left to do the piping on your own (CAI/Maf side only really)
Sweet!
I may be very interested in the mid-term future
I'd like to see one of these tuned and run on a Dynojet. Seems affordable and promising. Results will help sell the product.
Quick Update 19th October 2016
V-2.1 REVISION - Code Name "German Girl"
V-2.1 / German Girl Revisions Added Full Support for the Newer Power Steering Pumps on M54/S54 (And some on S52/S50)
Available Now.
Also I now Ship out the Supercharger on Request as well as providing a full laser cut bracket set for a base kit which can be further customized, with optional custom manifolds if required.
Warm Regards,
- Hyde
From Whanagrei,
Northland, New Zealand
Trump trump trump!!!
What kind of tune would you recommend for a m52 motor with m50 manifold, and a catback with the supercharger setup?
Depends on the boost, I have run low boost without a tune last year for a bit, show cased it in videos for non believers
I would say unless you can shell out for a dyno tune, a base tune would do fine, I have had people use just a variable rate FPR, I have some tuning contacts who I can recommend, you could use a tried and tested one flashed to your ECU, I am running a flash of MS41.2 now I think same as the USM3, its a custom tune from Dave at Markert Motor Works, Atlanta, USA, Top people to work with but hard to get a hold of, and it was further perfected by a good friend from Texas; Abel, who initially decided to help me, hes a Hobbyist but knows more then many 'tuners' out there today. I am running around 10 - 12 PSI now with pretty much most problems solved. I also have other tuner and chip tune contacts in Europe mainly Scandinavia and UK. But overall, I should be able to help with it or direct you to the right place.
