Results 1 to 25 of 51
Thread: Front thrust arm differences
    Nov 2014
    Milledgeville, GA
    1994 Alpine White 840Ci
    Have replaced both front thrust arms on my '94 840 and notice that the front wheels seem to be closer to the rear of the wheel wells than before. These units were lemforter (sp?) that were pre-loaded with the infamous bushings. Was there some design change at some point where there could be two different length arms available? The shorter arms are causing a toe out condition and I'm now looking at a wheel alignment (if I can find someone that can do it).
    Any insight would be greatly appreciated.
    '94 840Ci "Broomhilda"
    Mission Creep |def|: "When repair X ultimately leads to repair Y and Z"
    jcs1966's Avatar
    jcs1966 is offline SoCal Eights - CA BMW CCA Member
    Nov 2012
    Bakersfield, CA, USA
    1994 BMW 840ci
    Not sure about the length of the thrust arms, but you will need to have an alignment done anytime you change any of the control arms or ball joints.
    Jeremy Smith
    94 840Ci
    98 Porsche 986
    02 Mini Cooper
    13 Ford F150 Platinum
    The OC, CA
    95 840Ci
    I think I read somewhere that the arms for cars with x-brace were slightly different length. I think that is most cars from from 4/92 on. RealOEM shows the same part, but I think the mount point on the two brace types were slightly different.
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
    Victoria, Canada
    850i, Z3 2.3, X5 4.8is
    Not true. I added an X-brace to my 91 car and used my original arms.
    Live, Love, Life, Amazing...
    Jun 2010
    FL, Sydney, Hong Kong
    '92 850i '94 850ci
    Same here. Upgraded to x-brace. No diff.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    My 91 does not have an X-Brace. Does it make much difference?
    Jun 2010
    '92 850i '94 850ci
    The arms are the same pre and post '92 x-brace.
    Edit:
    If you meant performance diff - do you think bmw would make a production change and spend $$ if they didn't think it was needed?
    IMO the actual diff is minor and will only be apparent in more 'spirited' driving. My guess is that they found out after a couple of years the early cars were losing their front wheel alignments due to chassis flex.
    There's a designed-in 'weak point' ( forgot the technical name) on the frame rails between the engine carrier that the lower arms mounts to and the rear crossmember that the thrust arms goes. The weak point is there so the frame rails will bent down in a head-on collision and will try to take the engine under the survival cell. Constant flexing from suspension load might be causing unwanted movement or stress there. I believe the x-brace helps distributes this load away except in a frontal collision situation.
    It is for the same reason that the full x-brace extends all the way to the torque boxes just under the footwells. If the frame was strong enough they wouldn't have needed to extend the brace all the way there.
    San Ramon, CA
    850Ci, M5, Model-S P85D
    There are 2 upper control arm lengths that look very similar.
    E31 & E32 is the longer arm with E34 being the shorter version and if installed will move the suspension back and reduce the wheels caster value.
    So you should not have the toe set/aligned with the wrong arms as the steering return to straight will be greatly affected.
    I suggest checking the part numbers cast into the arms to make sure the installed thrust are the ones for the E31 p/n 31121139999 & 31121140000, I suspect they are the E34 arms.
    Iceland
    BMW 850
    My wheel on the driver side is close to the door and when I have my wide wheels it rubs against the fender.
    Could it be the case I have the e34 upper control arm and that could be the case?
    This has been making my sleeping a problem as I had the car aligned and still nothing changed.
    You can see how it is rubbing and the other side is all good.
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    Odd. I finally got around to installing my Wokke UCA and habe noticed the exact same issue now!
    Why do they look like the wheels sit further rear in wheel wells?
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    Quote Originally Posted by BMSman View Post
    It makes a hell of a difference. One of the best suspension upgrades you can get for a pre '92 E31.
    Quote Originally Posted by blanz View Post
    that's how it should be.
    Iceland
    BMW 850
    So its possible o have the wrong arm?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by Fatandre View Post
    Well not quite, what do you have for a bushing up there?
    I had used poly bushings on my earlier 850 and the wheels were in fact too far back, for what ever reason.
    Installed M5 bushing,alignment, fixed everything. Not sure how any of this made a difference on an original arm..
    San Ramon, CA
    Quote Originally Posted by dragon850 View Post
    The arms are a fix length, so replacing the bushing shouldn't matter unless the bushing is totally gone.
    The E34 arm (image attached) is 17-5/8" overall length. The number on this new arm is 1133667.1 which is weird because the order part numbers are 1141097 & 1141098.
    If someone has an E31/E32 arm are laying around please measure it and post the overall length and the casting part numbers for the record.
    Iceland
    BMW 850
    So you M6 say its possible that if I have on one side an arm from the e34 and on the other side from a e31 the arm from the e34 will put my wheel back, right?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have a used old E32 thrust arm here, overall length as mesured by you is (roughly) 47cm = 18.5", no name product, that was a cheapo one I replaced on an E32 of wrenching buddy
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Measured new BMW control arm I had laying around , 18.5"
    Apr 2012
    Austin, tx
    1997 BMW 840, 1995 850
    This is interesting. I have the arms with the bushings that Wokke sells in my '97 840 and the wheels are too far back in the well. In fact, with the camber plates installed the alignment shop was not able to get the correct caster with a negative camber.
    The OC, CA
    95 840Ci
    So, from what it sounds, we have arms between 7 5/8 and 8 1/2. That sounds like it may cause the problem described by OP.
    Current
    Past
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    So are Wokke's arms the correct length?
    What "thumbs up" really means
    Nov 2014
    Milledgeville, GA
    Had a four wheel alignment done yesterday and as I suspected, the toe was way out from replacing the thrust arms. The shop did a fair job trying to get all the settings within spec, but caster is still out. I'm still convinced that there are differences in the lengths of the thrust arms. Caster s/b 3.5° to 4.5° according to their machine, my front end came in at 7.0° and 7.4°. Caster can only be a function of the length of the thrust arms, and from the attached image, the front wheels on my 840 favor the rear of the wheel wells. They dialed in toe just fine. Camber, being what it is, was just on the edge of being out, being a tad on the negative side.
    I checked the part numbers on the thrust arms that I installed some time ago, and they are the correct part numbers.
    And the mystery continues...
    Jan 2005
    Japan
    Found another upper arm made by Meyle, HD version, for E32, right side, also 18.5"
    I posted this a while ago, copied from the E34 forum: That is what happens when the parts from E32/E31 are used for the E34. Just got done at the alignment shop hoping to fix my problem but they said there was nothing wrong with my front end.
    https://images.tapatalk-cdn.com/15/05...10723e098c.jpg
    The PO said something about putting e39 control arms or maybe 7 series? Could this be the issue? The alignment shop said that the thrust rods may be to long causing it to push out?
    I'm going to go out on a limb and wager that some dope installed e32/e31 thrust arms on your E34 car, part #31121139999,31121140000 . Replace them with part #31121141097, 31121141098 with bushings #31121136605
    You can shop around and find them with bushings already installed, but this ought to give you a very good idea of why your wheels are mislocated.
    I got the wrong 7 series control arms once and they did the same thing.
    what was in there, but they where wrong https://images.tapatalk-cdn.com/15/05...5241b6f530.jpg Correct ones in then I was off to the alignment shop for the second time today. And we are all fixed
    San Ramon, CA
    It is very possible to install the incorrect parts on one side and end up with a goofy front end (turning and tracking performance is unbalanced).
    The difference in caster between the front wheels will make the suspension and steering wheel react differently as the wheels returns to straight.
    The front wheel caster makes the front suspension want to steer straight ahead. The caster needs to be very close on both wheels so the suspension will not tramline or pull excessively and when one front wheel has a substantially less caster then that wheel will not return to straight as forcefully when that wheel is on the outside of the turn, i.e. reduced camber on right front with car turning left.
    Quote Originally Posted by toomanyparts View Post
    I sure hope so. I run them in my E31s and have no issue (see above picture). Same on my black 850i.
    Quote Originally Posted by IJustDrive View Post
    7 5/8 is the E34 version which is shorter than the E31/E32 version.
    San Ramon, CA
    There is no magic about the front suspension geometry. Of you measure the arms installed the 1 inch difference between shouldn't be to hard to conform.
    I have uses a wire coat hanger bent to make the ends contact the desired measurement points (free form caliper); when a tape measure is not useful to measure the ends of an object.
    The shops 3.5 to 4.0 deg. caster spec. is wrong and the caster gets smaller if the wheels move back not larger to 7.0 & 7.4 deg.
    The caster for the E31 should be 8 deg. +/- 1/2deg., so 7 and 7.4 deg. is too little for an E31.
    However I would have anticipated a 1" shorter UCA would have reduced caster more than that 1 deg. but the arms are at an angle and the actual geometry will cause less than 1" wheel displacement. Most likely 1/2" displacement with 24" to top mount so 1 deg. reduction in caster is about what to expect.
    If a short upper control arms was installed the front wheel will move back in the wheel well (reduced caster) and it will have excessive toe-in then you take it in for alignment.
    Also, don't just rely in the parts order numbers as the BMW warehouse can mix-up the parts bins and the physical parts so you will want to confirm the part numbers cast in the parts and length measurement for extra measure if the solution seems allusive.
