Stock sensor connector and pins help
Hi all,
I'm building a custom wiring harness for my engine management on an S52. I'm trying to source the stock connectors and pins from BMW so I don't have to splice any wires.
I'm having a really hard time matching the pins up to the connectors.
For example, the connector for the coolant temp sensor is: 12521703571
It references 61130007657 but that comes with a wire attached. I think I found a pin I can use 61131376191 but it is .5mm longer.
For the next example, the 3 pin connector that the CPS' use is 12521706096 and they reference 12520007253 as the pin. However, once again, that has a wire attached. I think I found 61138364583 that will work but I really have no clue if it will fit perfectly.
I am also trying to find the two pin connector that the VANOS solenoid uses, but it says it is no longer produced...
Anyone have advice for me?
Thanks!
Thanks,
Matt
'91 Granit Sedan Turbo S52 | '13 Carbon Black F10 550iX MSport | '89 Zinno Sedan iX
