Very helpful AND looks awesome!
Very helpful but looks alright.
Very helpful but doesn't look nice (or overkill).
Alright but looks nice.
Alright but doesn't look nice.
Ehh, not very helpful but looks nice/alright.
Not very helpful and ugly.
Thank you. It didn't make sense to me either, so I guess it was probably something else.
Also, I would like to submit a photograph of my bimmer lights to this thread, how would I go about doing that?
If you can't post it in your post, try using Bimmerboard.com and uploading it there then linking it.Originally Posted by p.a.r.t.y
bump for me
Are all hid bulbs the same, whether they are in a "correct" housing or somehow put into the standard housing? I have a bulb out and need to replace it. I didn't buy or install these lights so I'm clueless about them.
gr8 job !
i'd go for it as soon as i get some cash !
I believe so. And they're not actually "bulbs". No filaments. More like capsules.
You'd need to find out what headlights you have first before you can figure out the "bulb" you need to replace it. Search for it. I know it's out there but I always forget which is which. Good luck!
2005 Audi (Purchased 07/09) - 2005 Yamaha R6 (Raven) (Purchased 5/06)
07/97 BMW (Sold 08/09) - 03/01 Audi A4 1.8TMCX (Sold 06/03)
Please do NOT PM me! Email me: clumpymold@sbcglobal.net
They are ZKW's. I've been searching my butt off. I find tons of references to them, but so far no specific model number or types. If a local store had them, I could take the dead one out and ask them to give me one just like it that worked, but so far I can't find any HID bulbs anyplace local.
Do those PNP kits from umnitza draw power from the battery?
I'm guessing not.
Either way, how would someone go about doing it the correct way and like others said, not get expensive surprises later on. Great writeup, but I'd look into drawing the power from the source.
WTB: E36 ZKW Headlights, ACS Rear Diffuser,E36 M mudflaps front + rear
do you have problems of fogging up with the hole in the back
bringing this back from the dead..
I replaced both low beam with 15 amp fuses. i realized that there are TWO fuses for the fog lights, but the OP recommended only replacing ONE fuse. Is there any explanation on this?
i have a 95 M3. I remember reading the back cover and seeing there were 2 fuses, one where u circled, and one near the bottom right? Or maybe i'm reading the diagram wrong? It's number 15 then theres a comma, and another number. What does the second number refer to. I notice Low beams say 11,25 and 12,25
I've also have been reading that with newer HID kits, it wouldn't be neccessary to change the fuses because they only pull up to 6-7amps during initial startup, is that true? If that is true, is there a risk from running higher rated fuses when all that power isn't needed?
Well, I made THREE circles in that diagram. If you're setting up FOG lights, then there should only be ONE fuse but it MAY be different for your vehicle.
The BEST way to test this is to just leave the fuses as they are. Turn on your HIDs. If the fuse blows, up the amperage. If they don't, you're good to go. That's actually how I learned to up my fuses.
And yes, it's best to run the least amount of amps as possible without blowing the fuses. If you can run your HIDs without changing the fuses, more power to you (and the HID company).
seems like the stock fuses in my 95 m3 is holding up. if it blows, i guess i'll up it. thanks!
Very good write up good job.
This is old school!
nice!
That may be the problem I have with one of my lights. I ended up replacing the one that doesn't work with a standard H1 halogen bulb and when it didn't work either, I discovered the fuse was blown. So I plugged the HID back in with a new fuse. It tried to ignite for a moment, then popped the fuse. The standard fuse is 7.5 amps. So even though the passenger side HID may run fine on 7.5 amps, I may need a 10 amp or higher fuse for the drivers side HID?
