Results 1 to 25 of 55
Thread: S50/S52 M50/M52 valve spring compressor.. any interest?
    UT
    98 M3/4/5
    Back a year and a half ago i made my own Valve spring compressor to do my valve springs and valve seals on my car. I have made a few more tools for people that are going to do their own work.
    I am in no way a professional tool maker, but what i made works and is a much cheaper alternative to the $400 BMW tool. The tool compresses 2 valves at a time to release the valve locks.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    it works great and is very simple to use, as you can see it utilizes 2 of the stock stud head bolts, under the top plate is a welded nut that when the bolt is turned, presses the top plate against the nuts, and the bolt presses the bottom plate down evenly onto the valve springs to release the locks. the plates are 1/4" thick steel and grade 10 hardware
    $55 shipped, i have 2 currently but i can make more. PM me if interested
    98 Estoril ///M3 4/6
    S54 swap CSL
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The best is lever action, like using a big drill press as the lever so you do not have to twist down 24 valves.
    UT
    98 M3/4/5
    Can be, however this keeps the springs down without using one hand on the lever and the other trying to get the locks out, allows you more freedom. I ran into a few locks that were stubborn in releasing and needed both hands to get them loose using a magnet and a pick. This also lets you collapse the valves to your desire to aid in that where as the lever has a set depression squash area, this is adjustable.
    also since this is 2 springs at a time, you're only doing it 12 times not 24 with other tools
    S54 swap CSL
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    I bought the lever type spring compressor and while it'll do multiple types of heads this looks so much easier to use! And it's the same price as the one I got.
    UT
    98 M3/4/5
    Bump
    S54 swap CSL
    UT
    98 M3/4/5
    Bump
    S54 swap CSL
    Jun 2006
    Atlanta, GA
    '89 e30 mash up...
    That's a great idea. What other tools have you made?
    UT
    98 M3/4/5
    Just this is available now but soon to have a water pump holding tool, and one or two other things in the works
    S54 swap CSL
    UT
    98 M3/4/5
    Bump, few sold, few left
    S54 swap CSL
    Jan 2016
    Colorado Springs
    97 528i
    Anymore available?
    UT
    98 M3/4/5
    Yep pm sent
    S54 swap CSL
    UT
    98 M3/4/5
    Bump
    S54 swap CSL
    Fort Riley, KS
    96 M3 Turbo
    sent you a PM
    Jersey
    E36 325is
    Bought this off the op and works great!! Fast shipping. It's probably easier then the real tool (first time pulling valves).
    Here's a tip, if the valves don't release from the spring right away, put slight pressure on the valve with you fingers if still an pain, back out until it's uncompressed then tighten it up again eventually it's break free!
    Thanks again OP
    UT
    98 M3/4/5
    Great to hear it, glad you got your job done, thank you for the update
    S54 swap CSL
    NY/FL
    '08 G35S, '98 M3/4/5
    So you gonna make any more of these? I'd like one if you are
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
    UT
    98 M3/4/5
    Sure I usually can have them ready in a day, just send me a pm and I can send you PayPal info
    S54 swap CSL
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Does this work for installing valves as well? I would assume it does.
    Jan 2017
    Michigan
    1992 bmw 325is
    Are they still available?
    UT
    98 M3/4/5
    i have been knee deep in my S54 engine build lately but i could probably knock one or 2 out this week
    S54 swap CSL
    Jun 2012
    South fla
    97 332i, 90 535i
    Quote Originally Posted by TH3 Shifty View Post
    I'm interested in one also, pm me your paypal info when they're available again. Thanks!
    UT
    98 M3/4/5
    I'll start a few today,
    S54 swap CSL
    Jun 2012
    South fla
    97 332i, 90 535i
    Awesome! Pm me your paypal info when ready
    gilbert,Arizona
    95 M3 Coupe
    I don't just want one I need one. Sent private message. would help a fellow builder out to have one of these.
    Jun 2012
    South fla
    97 332i, 90 535i
    Quote Originally Posted by adam120 View Post
    X2 pm sent months ago still no reply 😕
    Sent from my SM-N920P using Tapatalk
