This is a weird problem I've had for a while now even before my engine swap. Sometimes my lights inside like the speedo, temp, etc. will go out for no reason at all. Usualy if they come on when I turn my car on, they'll go out when I punch the gas...weird. I checked the fuses, they're fine, I moves some wires around behind the instrument cluster and that did nothing. What could be the problem? Thanks if anyone can help.
-Joe
It may sound like your dimmer switch is loose. The potentiometer in not making a good contact. Try to disconnect the pot and measure the resistance. By turning the pot from min to max setting. You should get a reading of o ohm to k-omhs. If the reading is high open on all settings then you need to replace your dimmer swtich. Ask an Electrician to help you with the problem.
