Results 1 to 2 of 2
Thread: BMW e34 525i engine swap to M5
    Jan 2014
    As Sulaymanyah,Ku,IQ
    1991 BMW E34
    I have e34 525i 1991 non-vanos manual transmission and I want a M5 (S38 - S50 - S52) engine that fit easily because I can't replace everything for the new engine
    and what should I replace in general for this swapping
    Apr 2014
    PA
    The S50 and S52 came in the E36 M3, not an M5. S50/2 would be the easiest to swap in. For an M50NV car, IIRC you would need the E36 M3 DME/ Proper chip a VANOS engine harness, Coolant pipe adapter/ harness, your M50 oilpan and engine sensors. Probable a few other things that I forgot, but that is a start.
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
