Thread: "What did you do to your E39 today V2.0."
  1. #16126
    Jun 2020
    Quincy, Ill
    540i, 986, 997, CTT
    Drove down to Jefferson City for a meeting at the Capitol. It was, as always a great ride, smooth, with effortless power to pass on the two-lanes.
    Um, sometimes a little too effortless. I got tired of idling behind a line stuck behind a pickup towing a boat. I may have been up to 100 as I passed the truck---and noticed "State Trooper" on the door. "Oops" is not quite capturing the sentiment.
    But no flashing lights, no roadblocks, so all is good!
  2. #16127
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by scubajim20 View Post
    BMW representing at the races in New Hampshire this week end. Unfortunately, the weather was a bust on Saturday and made for a bad day for the cars.Attachment 716364
    Was this at Epping, NH?
  3. #16128
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Quote Originally Posted by Monark John View Post
    ha ha good pucker event.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  4. #16129
    May 2018
    Cullowhee North Carolina
    1999 323i/5 2002 540i/6
    You know the drill, evox-r 2.0 retrofit and testing some 3d printed adjusters to see how they take the heat.
    Believe it or not this isn't for my car, it's for my dad's 530i, sort of an early father's day present.
    His lenses were cloudy, adjusters broken, and projectors worn out. Light output was abysmal.
    Sent from my SM-S901U using Tapatalk
  5. #16130
    Missouri
    '02 540i/6
    Upper radiator hose on the 528i blew up yesterday. Got it replaced, limped it home, properly bled the air, back up and running. $25 bucks all in all.
  6. #16131
    Aug 2013
    Champaign, Illinois
    2003 540i/6 Msport Sedan
    Just experienced a problem, haven't had time to get into it other than running the codes but figured someone here has seen it and can lead me in the right direction:
    I started the car and it ran fine, shut it down 20-25s later after moving it in the garage. I went to start it again because I still needed to reposition the car a bit and the car started surging from 1100-1400rpm and the throttle pedal had no effect. It just surged. I let it sit all day hoping it would clear whatever ailed it but it did the same thing. So I ran the codes and got these codes with the C310+ (not sure if this is a good one or if I need something else, it came with the car and so far it's done what's needed done) .
    E3 Function Throttle Actuator Jammed
    E4 Activation Throttle Actuator
    73 Signal Hot-film Airmass FLO w/sensor
    E5 Spring Check Throttle Actuator..
    Do I need to clean/check/replace the air mass sensor or is it something else. I was in a hurry but I saw something in the C310+ asking if I wanted to reset an activation? Maybe my memory is wrong on that. I'll get into it more in the morning. Any help would be appreciated.
    A great ending is all you'll see..
    __________________________________________________ _____________
  7. #16132
    May 2018
    Sounds like the TB died or possibly a issue with the connector, done any work in there recently? Was the EML light on?
  8. #16133
    Dec 2019
    København
    1999 e39 520iA
    Quote Originally Posted by SW530 View Post
    Clear the codes and see if any of them come back.
    Give the TB a good clean, it seems jammed.
    Sent from my SM-G986B using Tapatalk
  9. #16134
    Oct 2016
    Atlanta
    2001 540iT
    Quote Originally Posted by seagreen323i View Post
    Yep the connector and pins was just suggested in another thread for similar issues. But cleaning the TB can't hurt.
    Sent from my SM-G970U using Tapatalk
  10. #16135
    Aug 2013
    Champaign, Illinois
    No recent work. I'll clean the connectors are part of my ramp up to diagnosing the issue. Thanks.
    Quote Originally Posted by taz. View Post
    Will do. Thanks.
  11. #16136
    Aug 2013
    Champaign, Illinois
    Pretty sure I have it figured out. I noticed that the TB connector was a bit far out.. so I pushed and it would spring back into the connector but not catch. I used a screwdriver as a bar to really push it back in.. it clicks.. runs fine. I was able to clear the codes and run it without throwing a code. I noticed some clown has wrapped e-tape around the connector. Disconnected the connector like it was, throws codes. Snap it in with a lot of force, runs fine. I ordered a new connector and pigtail wires which I'll cut back and solder in when they arrive. Thanks for the help.
  12. #16137
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    Yes, It was my first time, I went with my daughter's boyfriend and some of his family and friends. Weather was raining on and off. They kept trying to dry the track and to get some races in. So we did alot of drinking under the tents to make up for it.
  13. #16138
    JimLev's Avatar
    Sundance Mesa, NM
    LOL, IPA’s I hope.
    When I lived in MA I use to go there, even raced there a few times.
    There’s a drag strip about 30 miles south of me here in NM that I plan on taking the hotrod to.
  14. #16139
    JimLev's Avatar
    Sundance Mesa, NM
    Hey Liketheredbaron, welcome to the forum.
    Why did you delete your post? It was good. I read it before you deleted it.
  15. #16140
    May 2018
    Yeah I've had many friends with TB issues that was simply the connector.
  16. #16141
    Oct 2016
    Atlanta
    2001 540iT
    What he said. Connector
  17. #16142
    Aug 2013
    Champaign, Illinois
    Agreed. And in this case the evidence suggests some hack "fixed" the problem in what most of us would call a non-permanent way.. and this is a classic case of why you fix things right the first time. Of course whoever did it sold the car so I suppose that was long enough for him..
    After I replace the connector and wires I'll probably put a heat resistant tie wrap around both sides of the connector just in case. Apparently either the material of one or both sides of the connector isn't compatible long term with the heat that builds up in that area, right under the beauty cover. I'd hate to have it go bad again why driving on the interstate..
  18. #16143
    Oct 2016
    Atlanta
    2001 540iT
    To be fair these connector problems are showing up 15 + years after assembly so the OEM design was not terrible.
  19. #16144
    Aug 2013
    Champaign, Illinois
    Quote Originally Posted by rlordjr View Post
    I suppose, but they're not good either. I don't think it's the design exactly, more its the tech they're using for their polymer components. BMW is known to have issues with everything made of that stuff from cooling system expansion tanks and fan blades to connectors to even CIA pipes.. I don't know much about more current BMW's, but I sure hope they've fixed their issues.
  20. #16145
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    They haven't
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  21. #16146
    Feb 2020
    San Francisco, California
    2003 540i M-Sport
    Got an oil change in.
    I was surprised how much more quiet my car became.
    Changed from 5w30 to 5w40 for the hot summer.
    Looking at Project Farm's tests on oil, I am considering moving away from Liquimoly to another company. Liquimoly doesn't seem to be rated very highly from their tests.
    Play Your Game. Meaning to say, do what you want to do, in the way you want to do it.
  22. #16147
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by E0339 View Post
    What you say? Oil not from the fatherland? Blasphemer!
  23. #16148
    May 2021
    USA
    2000 BMW 540i
    Removed the pesky CDV. World of difference!!
  24. #16149
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Drove across half of the US in the daughter’s 335xi …. lol
    However , the upper charge pipe blew off , and I had to RoadKill it with Zipties . lol
    I am looking for replacement now obviously .
    I probably will not get the OEM plastic pipe , since it is around $400 ... lol .
    https://www.ecstuning.com/b-genuine-...e/13717615026/
    These are the aftermarket aluminum options :
    https://www.ecstuning.com/b-ecs-part...esrep=agrigsby
    https://www.ecstuning.com/b-vrsf-par...10901020a~vrf/
  25. #16150
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Changed out the front fender inner liners for new OEM ones at $460. Ouch. They actually fit like they should.
    I was refunded for the cheap aftermarket ones from carparts. They didn't even want them back.
    Car goes in Monday to get detailed. Looking forward to getting it done. He did a great job a few years ago.
Page 646 of 672 FirstFirst ... 146546596621636637638639640641642643644645646647648649650651652653654655656671 ... LastLast
