I'm back baby!!!!
Gave the Taz a good wash yesterday, it was full of salt. Even though I don't drive it much in the winter, except cross Europe if needed, I took it out on a sunny Sunday to go and see Babylon,
When we came out.... bam... snowing.... and of course, Danish being prompt, they have already salted the road. I had only 5 km to home..... the horror!!!!!
Sent from my SM-G986B using Tapatalk
I am going to order new rear wheel bearings and rear hubs .
1. FCP has Febi-Bilstein rear hubs for $82 each , and FAG rear bearings for $66 each - which totals to around $300 shipped .
2. Rock Auto has Timken rear bearings for $51 each , and " Durago " rear hubs for $30 each - which totals around $200 shipped ...
I am assuming the " Durago " hubs are Chinese ?
https://www.rockauto.com/en/moreinfo...t=7632&jsn=897
What to do ... ? lol ...
sprayed a mew front M bumper skin... as mine was attacked by a random wildlife animal
and well.. 2001 Mtech bumpers... that are still orginal... yeah.. they shatter
ditching the intensive care,
Specializing In Breaking Things Professionally
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
Removed each of the wheels one at a time to check over stuff like brakes and suspension. All was well except for this damn rear upper control arm bolt. Was slighty loose. Second time I've discovered this same nut loose in the past several months. Last time I replaced the nut and torqued to spec. However this time I'm just going to replace the nut and the bolt and lather the sucker in Loctite! Will hit the dealer tomorrow for replacements. Right now it's torqued as tight as I feel comfortable tightening it to without snapping the bolt.
Meanwhile while the wheels were off. Ewww...
Ahhh, much better.
Back on the car and look as good as new!
Save yourself the pain of getting the bearings out and get them with the hubs. Make life a lot easier when changing them. It's not that bad to change them. Remember to clean the ends of the threads of the bolts holding bearing on the spindle. They get rusty and oxidation forms around also and might give you a headache. I cleaned them thoroughly and gave them some rust looser spray, and they came right out. The new bearings came with new bolts with red loctite on them. While in there, do yourself a favor and paint or replace the brake disk cover plates if needed
Well shoot, the fronts are easy as hell, the rears are the pain in the butt.
JimLev,
Being you asked...
New front bushings all around. Poly's.
New tie rod ends.
Rebuilt the sunroof...MF'er!!!
2 weeks, start to finish. (weekender, of course)
Hell, that's enough for a while...
Replace the 528i trunk struts and the wagon hood struts no more ‘French’ body chopper.
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
Took the wagon for inspection over the weekend, now completely legal, see y'all at Katies on Saturday morning
Current:
2000 RHD Euro Sport Slicktop 540it Glacier Green/Black
2009 LHD e92 335i Sport Black/Black
Former:
1997 5sp locker 4Runner Green/Beige
1991 Buick Park Avenue Gold/Beige
Finally got the new rear bearings and rear hubs in from FCP .
I just need to figure out what the best way is to putting the new bearings onto the new hubs ...
1. Hammer the new bearings onto the new hubs using a piece of 2x block of wood / and / or a large socket , or
2. Have the new bearing pressed on to the new hub ?
Has anyone done this DIY , so I can verify ?
You'll want to press them in. Don't do any hammering on the bearings. I DIY'd mine but can't remember exactly how I pressed the bearings onto the hub, but it's very doable. If there's a thru-hole in the center (which I think there is for the axel), you can take a strut compressor threaded shaft, place it thru the center hole, and tighten it down using a large socket (maybe the 36mm for the axel) and the back of the spring grasp. Just make sure it's all aligned before pressing. And make sure that the socket and spring grasp are pressing on the inner bearing race (the one being pressed over the hub), otherwise the bearing will split apart.
Ed CT
1998 528i
5-Speed
Aspen Silver
Aubergine Leather
Sent from my SM-S918U using Tapatalk
I had almost exactly the same thing happen with the new set of Conti's we put on the car early last summer. They were still new enough to smell the rubber and need the inventory markings on the sidewalls cleaned. I hadn't even made it home yet, I'd stopped at the local Do It Best hardware store and when I came out there was a screw right where yours is! Enough to make you am unhappy camper for sure. This is when I started asking tire manufacturers the time honored question. Which is better . "plugs or patches?" Which I still don't have a good answer for. I know some states outlaw one and some the other.
A great ending is all you'll see..
__________________________________________________ _____________
Yeah, these were installed last Aug as well. Still looking almost new thanks to the thorough front/rear suspension overhaul last year and alignment.
Luckily I have a warranty which covered tire replacement. Sucks 3 tires now are evenly worn while one is brand new. Oh well, could've been a lot worse.
Rule is, no shops will repair if the screw, nail, or whatever went in that close to the edge, I don’t know, I would get a patch and patch it myself. Use the tire anyway. And as for that plug vs patch argument, a plug s great when you are out in the middle of no where, but a plug is only considered a temporary fix, as it will start leaking within six months to a year. A patch vulcanized inside of the tire is a permanent fix. The only reason a patch may not take, is because the section to be patched was not prepped properly, and all oils wiped clean before applying the vulcanizing glue.
A plug / patch combo is best. Installed from the inside of the tire out.
Back in the day we'd light the glue on fire, snuff it out, and then immediately apply and roll the patch. Never had one fail. A plug like you say will leak but not suddenly fail.. and a proper application of a patch takes experience and guys with experience don't wan tto work on tires.. so that leaves us with states with different rules.. Mine was plugged and patched. Still fine.
Ok , thanks !
How about unbolting the bearing from the main hub ?
The bolts are E14's ... but the space is extremely limited ... I have seen Cnn's write-up using 1/4" e14 socket - is that what you did ?
Or , do you remove the half-shaft / drive axles in order the access the bolt heads ?
