Thread: "What did you do to your E39 today V2.0."
  1. #11226
    May 2018
    Florida
    '99 E39 M5T
    Wasn't today, but over the weekend, I installed all new brakes and front coilovers. After removing the rear rotors, this is what they looked like....
    Hopefully, that gets rid of the terrible shimmy the car gets, when I apply the brakes at highway speeds.
  2. #11227
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Thumbs up Rotors with life left!
    Why change them? They have metal left on them! Well on one side at least?
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  3. #11228
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    I tested the components for my factory navigation retrofit, found something to be continuously blowing fuse 58 (10amp trunk fuse).. also found fuse 56 (30amp trunk fuse) blown too. Replaced both, F58 blew again.
    Pulled out ALL of the wiring in the left side of the trunk and went through the WDS to see what components were attached to the fuse. Pulled the K3 unloader relay out also, tested it and it was working fine. Traced it back to a thick red/green wire that was powering the DSP amp was chaffing against the body behind the amp and shorting out against the body. Cleaned up all the wiring and re-tested all my retrofit components, all work great.
    Looks like ill be going forward with a full MK4 nav retrofit with the latest version BM53. I have 2015 nav dvds.. its more of a novelty to even install this, i really just want to address the eye sore that is the E39 center console without a wide screen monitor.
    Stancing is for drivers trapped in an abusive relationship of their own lives.
  4. #11229
    Aug 2013
    Finland
    1999 540i M-sport
    Replaced transmission oil with ZF original parts, also added Dr.Tranny just to be sure.
    Also replaced faded rear tail light, to a brighter one.
    Lähetetty minun ONEPLUS A5010 laitteesta Tapatalkilla
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
  5. #11230
    Lawrenceville, GA
    4 BMWs.
    Quote Originally Posted by Manny G. View Post
    I need a set of 2015 dvds for my 4.8is. They still are $140.00.
  6. #11231
    Jun 2015
    Sydney, NSW, Australia
    1999 E39 M5
    Consider using an OBM radio from a late E83 X3 or E85 Z4 - it’s a better and more reliable radio.
    https://m.youtube.com/watch?v=536UoDGOIGk
  7. #11232
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    Quote Originally Posted by amancuso View Post
    Check ebay here, $20.
    https://www.ebay.com/itm/143245116558
    Quote Originally Posted by RosieE39 View Post
    Mine is out of a 2006 330Ci ZHP .. its the latest BM53 radio that is Sirius and MP3 compatible and I want to retain my Sirius
    *edit* Thanks for that video, i hadn't seen it yet even though I've been all up and down E39source lately with the navigation stuff... I may indeed do the switch to one of those radios over this BM53
  8. #11233
    Lawrenceville, GA
    4 BMWs.
    I already have those, sometimes they work and sometimes they don't. More often than not, they don't. They are knock-offs. I got so tired of it not working, I put the old disc back in, even though the road I live on isn't on it.
  9. #11234
    Madison
    99 528it black 99 528
    Replaced all four wheel sensors today to get rid of yellow abs warning lights on dash. Now to try and figure out why my self leveling suspension light is still on. Let the trouble shooting began.
  10. #11235
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Front and rear suspension refresh on my daily driver with fresh wheel alignment, new rear brakes (pads and Brembo rotors) and adjusted my parking brake (6 clicks on each side). Whole different car. It's the second time I've refreshed the front and rear suspension. It only had a little under 50,000 miles since the last time and I didn't think it needed it but, since I was doing the same thing to my project car, I though I'd refresh them both.
    I found one ball joint (right rear) a little worn. Probably because I nicked the rubber boot when I installed it years ago.
    Now, my daily should be good for several years until something breaks (I'm looking at you, timing chain and clutch).
    Still have much work to go on my project car (the other 540i). Figuring out new shocks and struts and still have the timing chain to do.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
  11. #11236
    May 2003
    Spring, TX
    ’02 M5, ‘03 540, ‘98 M3
    Test fit for sound deadening on the rear parcel shelf before I reinstall my BavSound Stage 1 speakers. I know it's overkill but it only took about 20 minutes to cut and fit the mat. I'll peel off the back and roll it tomorrow.
    Sent from my Pixel 3 using Tapatalk
    2002 M5 Sterling Gray (88k)
    Dinan mufflers and intake, ZHP shift knob, E60 shifter, Ground Control coilovers
    Restoration in progress!
    2021 M340i (25k)
    Sold!
    2003 540i MSport 6sp Tit Silver (193k)
    Dinan Exhaust, Autosolutions SSK, 88C Thermostat, Koni's, BlueBus, BavSound, DUDMD Stage 2, AFE CAI
    Sold!
    Aavi's 98 M3/4/5 Cosmos (137k)
    TMS Stage 3 with Shrick cams, Shorty headers and tune, M50, Stromung, 8.5 LTW's squared, PFC-Z, 3.38, Bosch H1's with city lights, CD43, BSW Stage 1, BMS SSK, TMS Underdrive Pulleys, Sunroof Eclipse, LeatherZ gauge pack
    BMW CCA# 308494
  12. #11237
    West of Boston, MA
    2001 BMW 540iT/6
    Old sunroof seal started dropping at the passenger side rear corner, had a new one on the shelf and finally made time....
    Taped down the deflector to work.
    Old sticky gunk... lots of plastic razor blade and finger nail work at first.
    Goo-Gone didn’t make a dent, so off to the Depot for some Acetone. Nice and clean now.
    New seal on and trimmed. Have a couple spots a c-hair high but quite pleased overall.
  13. #11238
    Missouri
    '02 540i/6
    OEM M5 Rear Bumper installed today. Had to cut off the muffler as it didn't line up. Looks great, sounds better.
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
  14. #11239
    May 2014
    Just ordered the Bavsound speaker upgrade for my dd 540i6 (princess). Almost got a second set for my project car (Pea, only spelled with two e's) but I need to get the suspension (shocks and struts) and timing chain repairs completed before I give her a "treat".
  15. #11240
    SoCal
    2001 BMW 540i 6spd
    Replaced the timing chain tensioner on my 2001 540i. I was getting a brief startup rattle and figured it would be good preventative maintenance to do. I started it up after a cold start (about 12 hours sitting) and I didn't hear the rattle! I'm hoping it was that simple but I'm going to give it a week or so before I call it.
    I've heard of others who have replaced it and the rattle came back after some time. At the very least, I know the part has been replaced. To be fair, the old part still felt like it had a decent amount of spring in it compared to videos I had seen where the piece was barely moving.
    If it turns out to still have the rattle, I understand it could then be the VANOS which is a repair job that's above my skillset, unfortunately.
  16. #11241
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Quote Originally Posted by a91syncro View Post
    Turns out the right front sensor wiring and the left rear wiring were crumbling away. Four new sensors and all is right in the world. Now I get to replace the front and rear suspension parts as the kit came in Friday!
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  17. #11242
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    Replaced all 8 spark plugs with Bosch Platinum+ plugs and finally changed the ignition coils with the red BavAuto performance ones.
    Tomorrow I plan to neatly re-do the fog light harnesses with the new plugs and terminal connectors I just got... they were hacked up from an very old xenon fog light kit which I've retired.
  18. #11243
    West of Boston, MA
    2001 BMW 540iT/6
    Curious to hear your thoughts on the red coils. They’re among the few things I didn’t replace yet.
  19. #11244
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by Iamthebull View Post
    Hey Daniel!
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  20. #11245
    Missouri
    '02 540i/6
    Quote Originally Posted by computiNATEor View Post
    Hey Daniel!
    Hey Nate! Thanks again to you and Ryan for getting the bumper on. Looks great!
  21. #11246
    Mar 2008
    Hollywood, CA
    2003 525i
    Changed the rear windshield gasket, today:
  22. #11247
    West of Boston, MA
    2001 BMW 540iT/6
    Total score today.
  23. #11248
    Feb 2012
    Mountain Home, Idaho
    1997 Z3
    Did this job over the past three days. Replaced the leaking coolant pipes under the intake manifold. While I was in there I replaced the oil filter housing gasket, all vacuum lines, and the entire CCV system.
  24. #11249
    West of Boston, MA
    2001 BMW 540iT/6
    Replaced my badly worn tailgate lights, swapped in fresh bulbs, cleaned rear plate light lens and replaced those too.
  25. #11250
    Jun 2013
    San Diego, CA
    2003 BMW E39 530i
    Did a complete cooling system refresh since the radiator went last week. Now to get my airbag replaced from the recall.
Page 450 of 671 FirstFirst ... 350400425440441442443444445446447448449450451452453454455456457458459460475500550 ... LastLast
