today I decided to look into just how badly my headlight adjusters were broken. All 4 were indeed broken , and my bonus surprise, the entire reflector housing inside the passenger side headlight is cracked in half... making the high beam and low beam 2 individual parts.
.... oh and the headlights are '03 production so baking them open wont happen. I'll be practicing playing Operation before taking the JB Weld to the inside of the headlight being that they're Euro Hella housings.
going to order these and be done with it.
Stancing is for drivers trapped in an abusive relationship of their own lives.
I'll try.. Im not all that great at taking pictures while I work on my cars, having my phone too handy becomes very distracting.
Here is a picture of the crack I'll be trying to do surgery on.
How the heck did it crack in half like that? Manny, I’ll look through my spare headlight bits, I have a whole pile of halogen bits too, let me know if you want one, specify which side that is.
Oh, just noticed that you won’t be opening it up. I’ve done so on the housing that are unbakeable, it’s more work, plus you need to buy new lenses.
let me know where you sourced those metal adjusters, I should have just gone that route on my last headlight operation.
ALL metal adjusters are here:
https://www.ebay.com/itm/BMW-E39-5-S...MAAOSwFnxac2ac
The lenses on my headlights are MINT, I really dont want to rip them off.. I'm going to try and go at it the hard way keeping in mind that its the hard way, sometimes that makes it easier lol.
As for how it happened,... thinking back, I think it happened one cold night in NJ about 5 years ago when one of my high beams went out driving through a dark area, i tried to pull over and change the bulb while it was maybe 15-20 degrees out, and while fighting the cold and the frustrating amount of space left to slip the bulb back in, I probably pushed too hard. I remember hearing a crack, then forgetting all about it until I recently had the lenses refinished and clear coated, and had such a hard time adjusting that side.
Use the tips seen in this video:
https://www.youtube.com/watch?v=Uz-zW-cLdUs
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
Update - After looking closer at the area that my exhaust shop guy told me the was leaking (driver side cylinder closet to firewall) had clear signs of black soot. I was able to get an 11 mm wrench onto the bolt and surprisingly enough both bolts were loose! I was able tighten them down nice and tight, nothing else was loose and I was able to reach all the header bolts without lifting the engine any.
Tomorrow morning I will get the valve cover on (yes the valve cover needs to be off to reach the bolts from the engine bay) and hopefully all will be good! Then it's off to get my new tires installed. Super stoked for the results...
E39 WhatsApp Chat Gruppe
Bought Styling 81's and sold my 66's.
Still haven't decided what 19" wheels I should get for the summer though...
Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS, E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
Went to replace the CCV, and ended up removing the intake manifold in a fit of rage. What other things should I plan on replacing while I've got the manifold off? I've got new vacuum caps on already, and plan on getting a new manifold gasket. Anything else? I'm considering replacing the heater core hoses, but the look/feel in pretty good shape, and since the E39 will soon be retired from daily-driver status, I'm not sure its worth it, especially since the coolant is all new.
Check out my car blog here: exhaustfumes.blog
Gone: 1995 525i5, 1995 740iA, 2006 S60R 6MT, 2000 540iT, 1999 ML320, 2007 335i6
Went to the beach then went to the lake lol.
had hood repainted, replaced nostrils with shiny new ones, new headlight covers w smoked corners.
OFHG and VCG, OFHG was kaput, found the VCG had been replaced by PO, but nary a drop of sealant had been used in the repair. dry as a bone now.
Anyone happen to know off the top of their heads what the correct rechargeable key fob battery is? Mine finally died.
Backstory - my S62 had a rod knock.
Update - I tore down the engine with the help of a friend. Discovered that the crankshaft is worn out of spec, and I will need to replace it. Yay... $3000+ here we come.
Nate J.
OE or what? That sucks but if it makes you feel better cranks for my wee little Honda 400cc V4 are rendered useless at the slightest scuff (can’t weld and repair em, they all break). Used cranks are pushing a grand, billet are $4k or so. that’s all for ~83 HP so I’d say $3k for a crank that’ll take 500++ ain’t so bad actually
Nate J.
That sucks Nate. I was wondering where you were with the M5 engine. I know you drove it cross country to get it home and all was good and solid, so I doubt the previous owner was hiding anything in regard to the bearings. I guess it was just bad luck they went south on you so soon. Were you beating the hell out of it when they went bad? Anything odd?
You going to post up a S62 rebuild thread on here? Be a good change of pace from EWS sync threads (barf).
Yeah - all sympathies Nate. At least you'll know you have a motor thats all refreshed and 110% great when its over and the car will be worth investing in for the long haul.
LOL. YES x1000. I'm taking a BimFo holiday for a few reasons these days but banging my head against the wall in EWS Sync threads until I start to behave in an ungentlemanly manner is one of them...
<--- Actual live-action GIF of GG after trying to walk somebody else through EWS facts of life...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I'd be stoked to rebuild an S62 if the opportunity came up, haha. Cracking engines open is a ton of fun, especially if you've got a whole shop at your disposal.
1995 525i 5-speed - Thread
Hey John, screw the snoobs, ignore them, not worth getting your blood pressure up for. If they don’t want to listen, let them be. They can brick their sh!t, and then maybe next time , they pay attention.
Dannyboy, you’re just realizing that now, about having a shop to play in? Lol... But good for you man, have at it, after a while, it becomes normal, then you start taking it for granted.
