Thread: "What did you do to your E39 today V2.0."
  1. #9576
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    Just drained oil, replaced vanos solenoid gaskets on both banks. I also have oil filter hose o-rings that seal the oil hoses to the block, it is leaking pretty bad over there, I cannot see where is leaking but I am pretty sure it is where the oil hoses go into the block. according to JimLev, I need to remove engine mount and bracket to gain access. Since my car has coolant cooled alternator and alternator hosing is part of lower timing cover, I cannot remove the alternator to gain access. Anyone has successfully replace the oil hose o-rings? I looked there, I might have to remove the PS hose too to gain more room, not excited about doing this job.
  2. #9577
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Walkinator, the 2 lines go into the engine mount use o-rings for the seal at the mount. The other side of the engine mount has another set of o-rings to seal the oil path thru the engine mount and into the block.
    Sound like a dumb piece of engineering to have the oil flow thru the mount and into the block.
  3. #9578
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    Yes, I didn't realize that there are also 2 o-rings between the block and bracket until I went to realoem and looked at the bracket diagram. I also found a picture that shows the bracket on the engine, now I understand how the oil path flow through the bracket, it is a dumb design, anyway, I need to buy the 2 o-rings that go between the block and bracket, someone mentioned that GM LS oil pump o-ring fits, do you know what is the OD of the o-ring?
    http://garagistic.com/uploads/images...m60-swap-1.jpg
    http://garagistic.com/uploads/images...-m60-swap2.jpg
  4. #9579
    Sep 2014
    Bay Area, CA, US
    1998 BMW 540i/6
    I've had a couple of recurring codes for a while now. Finally did something about them.
    * P0100 MAF - Bought new Bosch unit from Amazon. Was identical to old one. Reset code.
    * P1475 LDP - Replaced charcoal canister / leak detection pump unit (16131183573). Reset code.
    So far so good!
  5. #9580
    Dec 2012
    Australia
    02 530i 05 156SW 05 166
    Swapped out the 3 lengths of cable for the bonnet release mechanism. Easy seeing as I already have most of the front of the car off. Huge difference over the old rusting dry ones. I'm back to zero resistance and smooth bonnet opening experience. : ]
  6. #9581
    Arklahoma
    '94 325i, '97 528i
    Went back into the dash. Last weekends journey ended when I was able to test the blower fan, and it seemed fine. 2 days later (& 100 degree heat) it ceased running, again. Changed FSU with no change. Voltmeter says all is well upto the blower, so new blower it is.
    Also showed me that if I ever get really bored, there's a tube frame that needs a little paint...
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  7. #9582
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Small blower motor replacement tip - don't lightly drop the new blower motor and non-visibly damage the cage so that it looks 100% fine and even then works for about a month or so after reassembly but then shatters at speed and throws a blade and you have to do it all over again. Sure wish somebody had warned me about that. :P
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  8. #9583
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Quote Originally Posted by AusE39er View Post
    Ah yes, the infamous hood release cable. Good idea swapping it out before it leaves your hood stuck when you desperately need to open it (like when there’s a massive coolant leak).
    1995 525i 5-speed - Thread
  9. #9584
    Sep 2013
    Tx.
    02 bmw 540
    Quote Originally Posted by dannyzabolotny View Post
    I can see that happening!! HaHaHa
  10. #9585
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Nav went on the fritz... was driving to the lake and the nav started opening and closing non-stop over and over until I found somewhere to pull over and turn everything off. Waited a few minutes after finally being able to get the cassette out (my form of aux) and it finally chilled out. Decided to not touch the aux and just listened to the radio.
    Seriously time for a new car.
    E39 WhatsApp Chat Gruppe
  11. #9586
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Quote Originally Posted by RuskiE39 View Post
    Sounds like it wasn't happy about the aux-in adapter cassette... You should look into either setting up the OEM aux-in with a BM53 radio or an aftermarket solution like GROM or Dynavin. I hated using cassette adapters in my 540it, the sound quality was pure trash. I got a Dynavin N6 and never looked back.
  12. #9587
    Dec 2012
    Australia
    Quote Originally Posted by jmc1590 View Post
    Looks like once you get the dash off it's pretty easy to access stuff like AC components. How'd you find pulling the dash off?
    Yeah that's what I figured. On my previous E39 the pull on the hood release handle was nice and smooth.
    When I got this 525i it was pretty obvious the cables were stuffed when the handle had a lot more resistance and an almost snap action half way through the pull as it popped the front latch.
    The handle that pops out the front of the grill was very stiff too. Used my favourite lubricant on that.
  13. #9588
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Pulling the dash board is easy as hell.
  14. #9589
    Arklahoma
    '94 325i, '97 528i
    Pulling the dash wasn't too bad, especially now that I've done it twice. I went to NewTIS and printed off the procedure, as well as all of the prerequisite items. Followed step-by-step, it's fairly simple.
    A couple of suggestions:
    Move steering wheel out and down prior to disconnecting the battery. (Saves the oh duh moment...)
    Pay attention to where your wiring passes thru for the instrument cluster trim. It can go several ways.
    I found that I prefer to remove the glove box completely after disconnecting the strap & piston. (Feels like it provides additional room when working with the trim pieces under the passenger side.) If you do, remember to disconnect / reconnect the flashlight wiring.
    All in all, took about 2 hours to take it apart, 15 minutes to change the fan, and 2 hours to re-assemble.
    -James
  15. #9590
    Jun 2018
    vancouver wa
    2002 bmw 525i m sport
    Successfully changed my water pump this weekend!! with a home made water pump holding tool.Complete cooling system overhaul in the near future
  16. #9591
    Jun 2010
    Bay Area, California
    325iT, 540iT
  17. #9592
    Mar 2010
    ill second that. First time was less bad than advertised, second time was really routine. ...
    Wut? Disconnect the battery? You bin readin too many of them tightass factory procedures.
    (I know that sounds sarcastic but srsly. Not really necessary. )
    Totally. Part of being an old-head is learning how “take MORE stuff off early rather than trying to screw around and work around it” is 8/10 times the way to go, FASTER, and easier.
    Nice. That’s good time, I think maybe I can make a round trip in 3hrs if my life depended on it... but then again that was after I did it 2x back to back, maybe I’m rusty now....
    2003 M3CicM6 TiAg
    Former:
  18. #9593
    Arklahoma
    '94 325i, '97 528i
    Disconnect the battery. .. Only when playing with electrically activated explosive devices. Lol
  19. #9594
    Oregon/Ukraine
    disconnect the battery. .. Only when playing with electrically activated explosive devices. Lol
    sent from my samsung-sm-g900a using tapatalk
    yolo
  20. #9595
    Feb 2015
    Seattle
    03 530i, 99 Silverado
    Went and bought some style 32's locally. Came with 5 wheels and new tires. Not too shabby. I don't like 19's on E39's; they just don’t ride well in my opinion. My area is rough though.
    They are not perfect condition but that's fine for now.
    1999 528i Touring - Alpine White
  21. #9596
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    Quote Originally Posted by RRH View Post
    Looks nice, I like the upgrade
  22. #9597
    Jun 2015
    Tennessee
    BMW
    Installed my slushbox back into the wagon for the third time in 3 months this past weekend. I rebuilt it, it leaked, I took it out and replaced the seal, it leaked again much worse...The third time I was informed by a seasoned transmission specialist that you are supposed to "coach" the torque converter bolts in when connecting it to the flex plate/flywheel. If you just torque the bolts down one at a time it gets in a bind and doesn't spin true. My wagon is finally back on the road and leak free!! Also slapped in a new steering rack because it blew the seals out on both sides at 108k miles.
    In the process of all of this I now have two broken downstream O2 senors, thanks to the air hammer used by the exhaust shop that removed my old broken studs. Thus I have SES lights on for that.
    Transmission light is on after this last install, but it drives okay, maybe a slight hard shift from 1st to 2nd. Thats when the light came on. Gonna try a scan and clear to see what happens.
    My steering wheel is a little off because I forgot to mark the steering column/steering rack splines before reinstall
  23. #9598
    Buena Park, Ca
    2002 BMW 540i/6, 2003 BM
    Sold the first half of my Black and Blue m5 interior last night. Owner has everything but the front seats until he gets the rest of the money. Guess now is a good time to swap my 540i's BAV Sound speakers into the new-to-me 530i
    Sent from my LG-H932 using Tapatalk
  24. #9599
    Jun 2014
    Astoria, NY
    2003 M5
    OMG that sounds like a nightmare. This was my least favorite job on the E39. My personal horror story after installing new blower: I tried plugging the climate control unit back in to test operation and plugged to the radio harness instead. They looked the same in the rats nest of loose cable with the dash out. Anyway, I spent a half hour cursing, another half hour trying to curse at Amazon for selling me a bogus part and then a half hour giggling when I had discovered my error. 😂
  25. #9600
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Rolled over 210k miles in the 540it today... have been doing burnouts to celebrate.
Page 384 of 671 FirstFirst ... 284334359374375376377378379380381382383384385386387388389390391392393394409434484 ... LastLast
