Was that the steering wheel that came with the car?
New driveshaft and flex disc. Coming down off the lift now. Fingers crossed.
Had mine done. No issues.
Also, new driveshaft a definite improvement. I suspect I have a axle going though. Everything else being so smooth now helps highlight it.
Aftermarket or OE reman....
Exactly, that’s what I was saying to some friends over here. I mean, it is an airbag that falls in the recall zone, and whats it matter if it’s not in the original car, they made it, it was released, they recalled it, I would think that they would be obligated to cover it, in the name of safety.
Hm, maybe I should bother BMW about the facelift M5 steering wheel in my otherwise non-recall range car (late 99 build). A fresh airbag for free would look reaaaaal nice
1995 525i 5-speed - Thread
Sallvage yard for the bmw and expedition found a m sport steering wheel almost had it removed when I realized it was a dual stage air bag very disappointing. Though I feel a bit better because I ran into a dynavin n6 with all wiring GPs antenna and mic. So hopefully it works it needs volume knobs and a harness for my order e39
Update: #1 it's so annoying that every time I try and edit my post anywhere I click activates the delete post button on my phone 😡
Update: #2 rigged up a tester for the dynavin to a battery it booted, played music in the one speaker I had hooked up, connected bluetooth, made a call, turned radio. So I'm optimistically hoping it's truly working and will integrate easily.
Diff swap I did while back and now ECU software tuned. It has made a huge improvement on 528iA. It doesn't feel so slow after my 730d anymore.
Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS, E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
That's a lovely m sport. Is that one of the individual colour interiors?
Finally pulling off the front of mine tonight to work on issues arising from the kangaroo incident up near Cairns. Will also be doing besian vanos overhaul, bonnet cable replacement throughout, valve cover gasket, vanos oil line replacement and cam shaft sensor o ring replacement while I'm in there.
If anyone is looking for a good work light I can recommend the Hella Nova 5k (sold as scangrip outside Australia). No more boiling hot work light, 5000 lumes of brightness, and can run off rechargable battery or mains power.
Copper collar nuts arrived yesterday so I spent 20 minutes under the car to back out zinc flange nuts I put on and screwed the copper collar nuts on, tightened them up by hand, fire it up, she is quite now, a proper fix finally!
Still need to change oil and replace oil pan gasket, hope I don't see anything bad when I drop the oil pan.
Not exactly E39 related, but as of today, I have officially enlisted forum celebrity Danny Zabolotny, to help me with the chain guides on my X5. The car is too clean too sell for dirt cheap to start over and buy another high priced X5 that needs a bunch of work.
We booked his airfare today and agreed on a price for the labor. Time and time again Danny has been able to help answer technical questions not only here, but in our BMW WhatsApp group chat. I'm confident in his ability and experience.
I plan on bringing him out again when it's time for the 540 guides
E39 WhatsApp Chat Gruppe
Replaced the expansion tank (last cooling system refresh part), valve cover gasket, adjusted parking brake, replaced reverse light bulb and repaired the SAP exhaust engine pipe. Clutch is next on the list as the bimmer has 225k and I don't think the clutch has ever been replaced.
V/R Zachary Pullins Sr.
Florida Suncoast Chapter BMWCCA
2016 Cadillac SRX & 1999 E39 540i/Sport
" Vision without resources is just hallucination"
Valley Pan. Took about 9 hours over last 3 days. No leaks, no drips, no errors. Just hot and humid so worked 7 am to 10 am each day before too hot.
Had the water pump to radiator hose blow out 45+ miles away from home. Had to had to go to two different auto store (including walking to one a mile away and back). Spent about 4 hours total bringing it back to life...
So, installed a metal T fitting in it's place, replaced the AC fan, and replaced the cowl......oh, and a burnt out fog light on saturday.
Got to play "change the AC/Heater Blower Fan" over the weekend. Actually not as big a deal as I feared. My the interior looks dredful when you're about 1/2 way done!
Replaced the center link. Suspension refresh finally done!
Also moved the wagon to a staggered set up with some Michelin Pilot Sport AS 3+ on style 66 rims. Looks badass and drives great.
