Thread: "What did you do to your E39 today V2.0."
  1. #9201
    Oulu, Finland
    See my sig
    Passed inspection. Now I can drive a year without worrying about it.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
  2. #9202
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by joekitch View Post
    this is when the car's dead-cold
    and that video perfectly describes what i'm hearing
    so meyle sent me a DOA clutch? from fcp euro? figures
    unless there's some specific thing i need to do with a new fan clutch when i get it to set it up, or something
    Nope, no setup required. Very possible the clutch is DOA. I've had good experiences with Mahle-Behr.
    Anyone have any brilliant ideas for pilot bearing removal? I've tried a small slide hammer (2lb) and smashing in wet shop towels, but no dice. The bearing is IN there tight.
    Going to rent a 5lb slide hammer tomorrow.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  3. #9203
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by computiNATEor View Post
    Did you use some sort of rust converter? You need to neutralize the rust that's already in the metal, not just take away the visible rust.
    When you leave a really harsh line like that, it will be hard to blend. You can use some paper taped into a curve to feather out the edges. See this video at 14:40 (I don't recommend following the other steps in this video, though): https://youtu.be/n4vusY2-rkQ?t=14m40s
    Thanks a lot for the paper advice. Turned out very good! Now some clear coat then buff when dry.
    The light line is just shadow
    Lähetetty minun ONEPLUS A5010 laitteesta Tapatalkilla
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
  4. #9204
    Aug 2013
    Finland
    1999 540i M-sport
    Well it is done now, quite obvious line, but I think it is because of the spray being a bit different color than the car itself.
  5. #9205
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Took my 540 to the .25 cent car wash this morning then onto the pretty much deserted highway for a high speed run to air dry it. Then to the Labor Day car show in ABQ, 400+ car, not one BMW. Everything else was there.
    The featured car this year was pre 1989 English cars.
  6. #9206
    Raleigh, NC
    SR-71 Blackbird
    I was at the VIR this whole weekend for Hyperfest.
    https://photos.app.*******/x0V5pttZu9tchYe83
    Let me know if you can see the pics/vids or not.
    Probably not ...
  7. #9207
    OKC, OK - Derby, KS
    740i, 330i, A6
    Changing out the driver door lock actuator of my e39. The plastic sleeve of the Bowden cable crumbled when I took the lock mechanism out of the door. I placed an order for a new cable. It will be out of commission for a few days. I am taking the e38 in for a new headliner tomorrow. Looks like me and the truck for a few days. Always good to have a few spare vehicles just in case.
    2001 BMW 740i - Anthracite Gray - Style 32 Wheels --------- 2004 BMW 330i - Silver Grey Metallic
    Convenience Pkg - Cold Weather Pkg - PDC ------------------- Sport Package - Auto - Mroof - Hseats
  8. #9208
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Quote Originally Posted by auaq View Post
    Probably not ...
    negative
  9. #9209
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Quote Originally Posted by ryunk View Post
    How did you know the issue was the door lock actuator? Dealing with the same issue in my X5.
    E39 WhatsApp Chat Gruppe
  10. #9210
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    finally, finally, after owning the car for like 3 years, i FINALLY replaced the rear hatch and glass gas struts
    but man it was a pain. the struts weren't too bad but those little plastic coverings that keep the wires in check, such a pain to remove and put back together
    by the way, a cheat code for that job is to unbolt the actual ball joints the struts sit on, you can get to them under the rear headliner, not difficult or time consuming to reach, although be careful not to crack your D pillar plastic
    i legit forgot that the hatch will essentially self-open if you pop it with the keyfob, since the hatch struts have those huge springs on them
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
  11. #9211
    OKC, OK - Derby, KS
    740i, 330i, A6
    Quote Originally Posted by RuskiE39 View Post
    Failing door lock actuators are a common issue with these cars. The door lock will be slow to move when locking or unlocking, sometimes not moving at all. Don't think lubrication will fix it, it doesn't.
    I have changed out 8 door lock actuators now on my 5 and 7 series and it fixed the issue in every case. Oh, and I replaced 6 out of 8 window regulators.....
  12. #9212
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    The next week could be interesting. I’m going to push as hard as I can to have the car ready for Bimmerfest. Gonna be tough, as I still need to do a lot of stuff. Hopefully just reassembly, though, which is easier.
    Probably not ...
    Nope, sorry.
    Nate J.
  13. #9213
    Jul 2012
    mitten
    Been out a town for a week. Came home to three boxes of parts. Plan to finish the interior in the next day or two.
  14. #9214
    Buena Park, Ca
    2002 BMW 540i/6, 2003 BM
    Dropped roll bar of for powdercoat. Pick up and final install tomorrow
    Sent from my LG-H932 using Tapatalk
  15. #9215
    Jul 2013
    Worcester, MA
    ALMOST bought a colgan cover front end bra for my 540i for the road trip
    at $208, it's a little spendy but really good protection
    but as i was checking out i saw the message
    on there, which is waaaay too long for my purposes, i leave on the road trip on june 4th!
    any place i can get a e39 car bra that'll ship much sooner?
    GN92489
  16. #9216
    JimLev's Avatar
    Sundance Mesa, NM
    I've got a Colgan I haven't used in many years, but it was for the older bumper style so it might not fit your '03 car.
    Got the covers for the mirrors too.
  17. #9217
    Jul 2013
    Worcester, MA
    mirror covers i'm not worried about, since the square mirrors i have are getting replaced with m5 reps soon anyway, probably right after this trip
    another complication is that i have an M bumper :/
    if i had known it'd take this long i would have ordered them a month ago
    GN92489
  18. #9218
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Clear bra > anything else. It’s not hideous and old fashioned, nor will it scratch the ever loving hell out of the clear coat... unlike a certain vinyl product.
    Nate J.
  19. #9219
    Jul 2013
    Worcester, MA
    i called a local place that does clear bra installs, supposedly very good, $995, which is...quite a lot...
    i'm beginning to think it might not be worth doing protection since i'm respraying the bumper anyway (from sun damage) and the hood has a decent dent in it so it'll need dent repair and probably a respray
    GN92489
  20. #9220
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Don't follow big rigs or buses in left lane. They kick up a ton of grit and crap.
  21. #9221
    Apr 2015
    United States
    1999 BMW 528i E39
    Replaced cracked front bumper with an m5 bumper. And replaced the tail light lenses to get rid of th Amber. Also finished the front sway bar links, thrust arms, and control arms. Gona do the tie rods soon as well since i have them. Wanted to do those while i was in there but couldn’t find my torch. Until after put everything back together!! Smh
  22. #9222
    Raleigh, NC
    SR-71 Blackbird
    Quote Originally Posted by jp5Touring View Post
    negative
    Made a thread here:
    https://www.bimmerforums.com/forum/s...rfest-VIR-2018
  23. #9223
    Mar 2008
    Hollywood, CA
    2003 525i
    Continued work on the removal of the orange peel from the recently-painted trunk lid:
  24. #9224
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Just drive the car and let it get chips. Rock chips give a car character. My 540it is absolutely covered in rock chips and has them on almost every panel, but it doesn’t bother me because it wears its 208k miles with pride.
    1995 525i 5-speed - Thread
  25. #9225
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Hey Danno, I tell myself the same thing about my wagon, it’s about to hit 210,000.
Page 369 of 671 FirstFirst ... 269319344359360361362363364365366367368369370371372373374375376377378379394419469 ... LastLast
