Dropped $380 on meyle HD thrust arms, some meyle lower control arms, and a ball joint splitter tool from fcp euro.
Of course only afterwards did i look more into front end shimmy problems on the 540i and surprise surprise, there can be tons of causes so the $380 i just spent isn't really guaranteed to solve it.
hooray
Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
GN92489
540i msport touring; jet black on grey
Progress Thread (general)
Progress thread (touring specific)
I crossed the not at all important and yet totally shareable moment of (mostly) all the same odometer digits. I dropped the ball and missed the trip odometer synchronization but I'll do my best to get it right when they're all 3's
1995 525i 5-speed - Thread
Dropped mine off at the shop. Got simultaneous engine and transmission failsafes due to blown F1 fuse in ebox.
From what ive gathered, might be a short somewhere with the thermostat.
Unfortunately i dont have the time to diagnose lately..so ill have to pay
Had my 540 towed to the shop. Freaking water pump went. At least she got me back to my office.
Sent from my SM-N950U1 using Tapatalk
Just FYI my 530i had the infamous shimmy while braking and I assumed it was the upper control (thrust) arms too due to past experience. The car happened to need a four wheel brake job, which I just did with front and rear pads and rotors. Well it brakes beautifully now with no more shimmy or vibration - so the front brake rotors were definitely warped or had uneven wear. Something to consider.
this is inconsistent shimmy while at speed or braking, so i doubt it's rotors/pads.
it'll shimmy on some roads between 45 and 60 then be totally fine on others at those same speeds, quite annoying
GN92489
Nice, you're really piling on the miles! I'm way behind now
Identical to the right side, but I haven't taken any yet, because the car and headlight are in two different places right now.
Sounds like control arms to me, but it's worth checking your tire balance, wear, and alignment too. I found on the old Sumitomo HTR Z3s I was running a while back that I would get steering wheel shimmy when the tires had 20-30% tread life remaining.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
Put summer tires on.
Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS, E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
^whats with all the oily drips in the driveway?
The hits just keep coming.
i'm pretty sure i have a sticking driver side front caliper. Put my car in the air to to the thrust arms and noticed the driver side wheel was way hotter than the passenger side, and was much more dusty, also the wheel was locked enough that i could undo the lug nuts without holding the brake pedal. uh oh.
here's the passenger side wheel
and here's the driver side, note way more brake dust
not sure if this is contributing to my front end shimmy though, since i have detected absolutely no "pulling" to the left while driving at any speed
GN92489
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
Stuff For Sale :
All types of E39 OEM Used HVAC Buttons
Other E39 Parts, see my ebay! [Click]
Nate J.
Washed & waxed Frankenbimmer on Sunday...including the black, factory primered, made in Taiwan hood.
He looks a hundred times better now.
I was going to wait until I get the car painted before getting new grilles...but the black hood is growing on me.
Should I just slap some chrome grilles on with the black hood & call it good?
Or, should I just wait, without kidneys, until it's all painted? Thoughts?
Sent from my 2PZC5 using Tapatalk
GN92489
Not recolored, is the black one out of my alpine white touring. The plan is to use the black carpet and cargo area pieces out of my alpine white car.
I have e38 front seats and M5 extended leather dash,door cards and console. I spent $400. to have the whole seat done, the bench part was beat to hell. I should of taken a before picture. Would have been $200. in dye and supplies to do what I wanted so I just wrote the check.
The M5 leather has all been dyed and touched up by Clemster it looks brand new. I also have all new black headliner for it also.
and new rear cargo trim, and new speakers, and a new Dynavin N7 and new antenna and,and n and
yep
Nate J.
replaced the alternator tensioner assembly, the whole thing cuz might as well
also got under the car to replace the control arms, i spent about an hour trying to pry the lower control arm ball joint post out before giving up, it's currently dripping in pb blaster.
anyone know a really good ball joint seperator that fits this? The one from FCP euro is really underwhelming and basically doesn't work. jaw doesnt open wide enough to do the lower control arm ball joint and its too bulky to get to the thrust arm ball joint
https://www.fcpeuro.com/products/bal...cta-tools-4013
also think i'll need to drop the sway bar a little bit to get to the bolt head holding the thrust arm to the car
edit: might be able to do the lower control arm with this method....i think my largest c clamp is big enough...
https://lh6.googleusercontent.com/_-...10428-1852.jpg
GN92489
In regards to the starter issue you were having. How would you describe what would happen the times it would stick?
Last summer every once and a while I would get a terrible gravelly metallic noise upon startup but never found any lead on what it could be.
Over the winter I did a M54 intake swap and replaced the starter while I was in there thinking it might be my noise source.
Was I correct?
-Tim
Sent from my LGUS992 using Tapatalk
